joebob
Joined: 8/2/2002 From: Crestview, FL, USA Status: offline
I honestly think you could frame this kit up in less than 16 hours. Mine took about 20, but I used wood glue for the fuse sheeting and had to let it dry for a couple hours for each side. It builds REALLY quick. The only problem I found was that the plans had shrunk slightly and when I got the fuse framed up, the sheeting didn't quite line up at the rear. Not enough to even worry about, though. I've flown the Katana and the larger Fusion, and I must say that, to me, the the Fusion is just about the perfect plane. It grooves around like a pattern ship, but will also 3D with the best of them.
_____________________________
Joe Andrews
