RE: TROUBLE WITH NEW AXIAL ENGINE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: TROUBLE WITH NEW AXIAL ENGINE Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/23/2007 5:36:24 PM
71goat
Status: offline
I really wish I knew what I am doing wrong with my axial.32 , I just can't keep the temps down , I've e-mail axial about it they told me to adjust the lsn 1 full turn cw, the hsn ccw 1 full turn, still does it (high temps) I've sealed the motor, see no bubbles when doing bubble test thing, Other people on different threads cave me some advice I do what they say but always the same, thinking about putting a hpi carb on to see what happenes.
Anybody else have any ideas????
_____________________________
WOW Unreal people
(in reply to gravediggerracing)
       Post #: 51
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 4:02:35 AM
SAVAGEJIM
Status: offline
Dont worry about 260-270degrees F especially if the engine is not making any bad noises or giving other cues of being way too rich orway too lean. Some big blocks will actilly reach 300degrees F and run at their optimum performance.
I hate stray Tomcats
(in reply to 71goat)
       Post #: 52
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 3:24:07 PM
rrusso
Status: offline
270 is normal for thaT ENGINE
raze O.S .30 vg modded, axial .28 RR,18t,jp-2 pipe...hyper pbs.21 8 port....
(in reply to SAVAGEJIM)
       Post #: 53
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 3:37:35 PM
71goat
Status: offline
Thanks SAVAGEJIM & rrusso
Even during break-in?
WOW Unreal people
(in reply to rrusso)
       Post #: 54
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 3:53:54 PM
SAVAGEJIM
Status: offline
Absolutely, and yes, especially during break-in. Always run the engine at operating temp during brak-in. The instruction manual says to break-in the engine at a lower temp, but they only lie to like that so that you ill have to either buy a new engine or replace the piston & sleeve soon.
ALWAYS break-in the engine at the operating temp that the engine will run at when it is fully broken in. If you break it in at lower temps, you will only take away from the engine's life. Where you could have got 15gallons from the engine, the engine manual break-in instructions will only allow the engine to live for 5-10 gallons!
       Post #: 55
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 4:03:56 PM
71goat
Status: offline
It just has me worried, because the force.32 That I'm breaking in too, I've went thru about 5 tanks before the temps started to hit in the 200, and the force seems to have more power, everything I've read seems to say that the axial should be better, the force pulls the wheels on my mgt with full alum. temps at 200-220. axial in sons warhead, 1min temps 270-300, no wheelies, how do I know what to hot is??
WOW Unreal people
       Post #: 56
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 4:10:33 PM
SAVAGEJIM
Status: offline
The Warhead is a heavy truck, much heavier than the MGT I believe. Additionally, I dont think th Warhead engine is as powerful as your Force engine. A more powerful engine contributes to wheelies. Also, the Warhead might be geard high. A high gear ratio seriously tames wheelies and even eliminates them in some cases. If you want your Warhead to wheelie, try getting lower gears.
As for engine performance and tuning issues, so long as the Force and Warhead engines sound good and run crisply at the pull of the trigger and so long as they do not make and bad noises or do not issue any smoke at all, they are in good tune.
       Post #: 57
RE: TROUBLE WITH NEW AXIAL ENGINE - 6/24/2007 4:16:06 PM
71goat
Status: offline
THANK YOU
WOW Unreal people
       Post #: 58
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/4/2007 6:14:38 PM
RichSavage
Status: offline
I have been having problems with my Axial when the weather heats up. I have found that it dies and becomes hard to start as the weather gets hotter. I was running a hot plug and changed to a cold one but haven't got out to check it out yet. I live in Colorado and with our higher altitude I have even tried richening the high speed some but the engine is only running around 225.
HELP!
I really want to get this going again. Also, I am running a JP-3 pipe and have the engine in a Kyosho ST-USSport truggy.
(in reply to Kemo)
       Post #: 59
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/5/2007 6:27:57 PM
71goat
Status: offline
Well this is a bunch of crap, I have an Axial.32 that has been running hot, the front bearing is leaking, Axial said they will not warrenty it because I was using a OS 8 plug, they said it is the wrong plug for that motor, BUT nowhere in there instructions does it say what kind of plug THEY recommened to use. now I have a piece of crap axial .32 sitting here Very Disapponited in the AXIAL MOTOR
< Message edited by 71goat -- 7/5/2007 6:28:52 PM >
WOW Unreal people
(in reply to RichSavage)
       Post #: 60
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/5/2007 11:00:18 PM
jaywax
Status: offline
quote:
ORIGINAL: 71goat
Don't sweat it. My front bearing leaked a little when I first started running my Spec 1 .28. It will stop after break-in and the engine runs at operating temp. You need to run a standard length plug (long shaft). McCoy #8 and others like it are okay. It will make a difference in the engine. Hope this helps.
Mugen MBX5T Prospec w/STS S21T***KO Propo EX-10 Helio w/Spektrum Pro Module
       Post #: 61
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/6/2007 3:59:56 AM
71goat
Status: offline
I already did the heat cycle break in method, thats when i noticed the bearing leaking, now it always runs hot
WOW Unreal people
(in reply to jaywax)
       Post #: 62
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/6/2007 4:15:11 AM
jaywax
Status: offline
quote:
ORIGINAL: 71goat
Do not tune by temps, some engines run perfect at higher temps. Tune by performance and a nice trail of blue smoke from pipe. Sometimes your temp gun can be off. It happens all the time.
I consider break-in at a minimum of 1/2 gallon. My engine had a little leak at the beginning and I e-mailed Axial about it. They said it was normal on new engines and that it will stop. Mine stopped. You are running the wrong size plug. This will make a big difference in how the motor reacts. You need to run a standard (long plug). Your engine will run hotter when it is new. It will cool down and run more consistent as engine breaks in.
If all fails. Replace front bearing.
< Message edited by jaywax -- 7/6/2007 4:21:23 AM >
       Post #: 63
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/6/2007 4:40:03 PM
71goat
Status: offline
Thanks for the info an support jaywax
Well I decided to take carb off and stick in some soapy water, you'd think I was taking a bubble bath, holy crap now i know why I was running so hot
< Message edited by 71goat -- 7/6/2007 8:09:25 PM >
WOW Unreal people
       Post #: 64
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/26/2007 8:47:23 AM
jasrx
Status: offline
quote:
ORIGINAL: ozzie-crawl
two guys at my local track have axial .28 and they fly one guy has 40 litres threw his and its still going strong. want one myself but in australia your looking at $420 for a 28 $480 for a 32
well then u are geting ripped off , i just brought[ should have it monday] my 28 for $219
FG BEETLE BEAST.
(in reply to ozzie-crawl)
       Post #: 65
RE: TROUBLE WITH NEW AXIAL ENGINE - 7/26/2007 1:56:19 PM
