ccpm setting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> ccpm setting
Page: [1]
Login
ccpm setting - 3/7/2006 2:30:42 PM
timothy thompson
Status: offline
i have a jrxp622 heli radio what numbers are used in the three servos as for as pos or neg degrees. see post above this one
       Post #: 1
RE: ccpm setting - 3/7/2006 4:00:12 PM
jh4db536
Status: offline
i thought you have 4 other helis and know how to setup?
those ECCPM %'s are supposed to be the LIMIT for all cyclic & collective control surfaces, from there you set rates/expo. max positive and negative pitch for the collective without binding +/-10degrees. max aileron & elevator throws until the swashplate no longer mixes correctly or maybe about 6-7 degrees cyclic pitch.
you need a pitch gauge obviously
(in reply to timothy thompson)
       Post #: 2
RE: ccpm setting - 3/7/2006 4:38:22 PM
timothy thompson
Status: offline
i have a jr venture 30 that i set up succesfully. the manual was specific for the radio so it was easy. a have a raptor 60 easy to set up. the trex is my first shot at putting together a heli with not everything included. The motor arms and the align esc works however I need to program the esc and tou begin by going to full throttle and a series of beeps turn on. I think im not getting enough head speed. im at 2100 measured with an optical tach.
I wonder if i dont have enough power as it will skate around and hop but not hover. I need to know what % values to set cp 1 2 and 3. the trex manual is of little help
(in reply to jh4db536)
       Post #: 3
RE: ccpm setting - 3/8/2006 6:21:14 AM
H0ndaJunkie
Status: offline
Have you tried trextuning.com for info?
_____________________________
If you can't afford it, sell stuff until you can.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
