armycopter
ME, USA Status: offline
Well I finally got my 37 airborne again! It's been a long wait, however, the battery finally showed up, along with my Align balance charger. My new brushless motor and esc are all mounted with an Align 10T pinion. I had to attach a dean's connector to the ESC so that the battery would connect, but that was no problem. The only problem with the whole, "soldering thing," was that I melted a hole in my canopy by accident because I wasn't watching where the solder iron tip went. Grrrrrrrr. When I first brought the heli outside and fired it up, I must have had the ESC/Motor leads reversed because the main gear would spin but the blades didn't. I quickly reversed the leads and the blades spun up just fine. It sounds like a totally different bird!! The outrunner motor with the high headspeed makes it sound incredible! I picked it up to a hover with no problems. Flew it around my front yard, across the street into my neighbors yard, and back again. When i put it down, it kind of "fell over," and banged up the main blades a tiny bit. When I went to take off again, the aircraft just spun and wouldn't allow me to put any tail rotor pitch it. As it turns out, the small allen screw that holds the tail rotor to the shaft had come loose. I guess I'll have to put a little loctite on it. Other than that, it's an amazing aircraft. So much power, sounds great, gyro works great, servos work great. Granted a 10 minute flight is not a great indication of how it will perform in the future, but so far, its far better than I thought it would be. It's WAY better than the stock motor and battery. 12C, 1800Mah, 11.1V lipo is what I got. By the way, my align balance charger seems to have fixed the problem I was having with my 7.4V lipo. The 7.4V lipo wouldn't take a charge from my esky balance charger, but took one just fine from the align. Now I'm back in business with my DF4 too! Later guys! I'm hoping to get some good flying in this weekend. It's suppose to be in the 60's and sunny here in Maine!
