babyhuey
Joined: 9/3/2007 From: St. James, MO, USA Status: offline
Sorry guys, I thought that this thread had died. Did you try reversing your gyro? It sounds like that might be the problem. If you have control of the Helis direction (forward-back, left-right) then those servos are hooked up correctly. Channel three is the esc, four is always rudder, five is the gear channel, six is the pitch, and seven is gyro adjust if you have that feature. Check that your tail blades are rotating in the correct direction and that they are installed correctly. It is hard to belive how often that Walkera screws that up! I'll check back to see if you have more questions. Huey
_____________________________
Tail motors? We don''t need no stinking tail Motors. Walkera 36, Comet , GMP Cobra 50, Kalt Baron Whisper, Koyosho Caliber
