patternman
MO, USA Status: offline
love to have you. Re: muffler. After 4 years of tinkering with mufflers, and loosing three in our field somewhere, I have come up with several fixes that work. Yes, all thread will work, double nutting on both ends, but it expands at a different rate than the muffler and the tail cone still gets loose. I kept the muffler intact, did not try to tighten it up much, and drilled a little hole through the nut and the bolt and put a pin through it, so the nut will not turn off the bolt. I had to get a hardened little drill bit. I also drilled three holes around the joint of the two halves, tapped them, and put a short screws through the tapped holes, with lock tite, then ground off the heads. This makes it kinda permanent, but I'm never taking it apart again. these two tyes of fixes have worked for me several seasons and many trips around the poles. the original mufflers, with no reworking, did not last five laps. the bolt expands, the nut loosens, the rear cone falls off. I lost three in quick succession. My hobby shop stocked up on them once he knew he had a steady customer, but now has three mufflers sitting on the shelf.
