help with the clutch    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> help with the clutch
Page: [1]
Login
help with the clutch - 3/8/2006 9:17 PM
thecool1
Score: 100
Last Login: 5/16/2006
Status: offline
how do i take my clutch apart so i can check and see if the spring is broke. my engine keeps stalling when i hit the breaks and stop the car from moving. anyone know of some good diagrams?
_____________________________
Himoto Eldorada 1/10th
Hide Signatures
       Post #: 1
RE: help with the clutch - 3/8/2006 9:21 PM
jeeperscreapers
Score: 100
Last Login: 6/26/2006
Status: offline
spring just wraps around it..... its under those metal gears that are attached to the flywheel on the motor... theres a hex screw right on the tip of it
Savage X , Sure Fire . 32 , Hot-Rod Pipe , Escalade body , HEAVY Mods for HEAVY Bashing
Hide Signatures
(in reply to thecool1)
       Post #: 2
RE: help with the clutch - 3/9/2006 11:08 PM
cartronicshn
Score: 100
Last Login: 6/8/2012
Status: offline
Just be carefulwhen you take it apart, if the spring is loose inside, it will come out flying
VOLCANO ALUMINUM STX, LIGHTNING VX, TORNADO XP, HURRICANE XL, SMARTECH MEGA, TAMIYA BLACKFOOT, XP PRO, 3 CRAWLERS, WAITING..
Hide Signatures
(in reply to jeeperscreapers)
       Post #: 3
RE: help with the clutch - 3/9/2006 11:31 PM
thecool1
Score: 100
Status: offline
ok..lemme get this right first before i start taring apart...cause im new to this.
the box with the black gears that are visible..thats not the clutch right? thats the differential or something?
is the clutch located on the part that comes out the bottom of the engine?
Hide Signatures
(in reply to cartronicshn)
       Post #: 4
RE: help with the clutch - 3/9/2006 11:35 PM
cartronicshn
Score: 100
Status: offline
It's in the front part of the engine
Hide Signatures
       Post #: 5
RE: help with the clutch - 3/9/2006 11:39 PM
Xeller8
Score: 100
Last Login: 4/26/2006
Status: offline
I can't remember if you have the car or the truck...but since you said car thats what I'm assuming you have but the clutch bells all look the same so here is a picture that I posted for someone in the truck thread the other day....it about 3/4 of the way down that page...
http://www.rcuniverse.com/forum/m_3705430/mpage_27/key_/tm.htm
1/8 Redcat Hurricane XP Buggy/.27 motor (4.43cc)/tuned exhaust
1/10 Redcat Volcano STX truck/.18 motor (3.0cc)/tuned ex
Hide Signatures
       Post #: 6
jeeperscreapers
Score: 100
Status: offline
wellllllll i'm new to but im learning fast!!! it's all really quiet simple ok the actuall clutch on the 2 speeds is in that black box in the middle where the 2 visible black gears are.... but what your problem sounds like is the clutch slice as its called in the parts list which is located where i stated above
Hide Signatures
       Post #: 7
RE: help with the clutch - 3/9/2006 11:42 PM
Xeller8
Score: 100
Status: offline
Those don't have the clutch bell on the very end of the crankshaft??
< Message edited by Xeller8 -- 3/9/2006 11:45 PM >
Hide Signatures
       Post #: 8
RE: help with the clutch - 3/9/2006 11:50 PM
jeeperscreapers
Score: 100
Status: offline
the clutch slice with the spring is right infront of the flywheel coming directly off the motor
Hide Signatures
(in reply to Xeller8)
       Post #: 9
RE: help with the clutch - 3/10/2006 12:15 AM
thecool1
Score: 100
Status: offline
mmmmk guys...ill give it a try..thansk for all the help.
Hide Signatures
       Post #: 10
RE: help with the clutch - 3/10/2006 10:39 PM
chopper22980
Score: 100
Last Login: 2/15/2008
Status: offline
hey thecool1 i sent you a pm on how to take the clutch apart and to put it back together.did you not read the pm?just curious,cause its pretty detailed.let us know how you do with it.
Traxxas Jato,Nitro Sport,T-Maxx,Volcano STX,Ofna ultra lx comp buggy,Smartech Speedy Tiger buggy.
Hide Signatures
       Post #: 11
RE: help with the clutch - 3/10/2006 11:38 PM
thecool1
Score: 100
Status: offline
yeah man...i saw. im gonna try it right now..thansk for the PM.
Hide Signatures
(in reply to chopper22980)
       Post #: 12
RE: help with the clutch - 3/11/2006 12:00 AM
thecool1
Score: 100
Status: offline
ok. so i got it off...and the spring came flying out and hit me in the eye. (JP) anyway..i didnt get to see where the spring went cause it came off too quick. does it go in that grove on the outside of those two pieces that seperate? im gonna go get a spring while i wait for your guys response.
Hide Signatures
       Post #: 13
RE: help with the clutch - 3/11/2006 1:07 AM
cartronicshn
Score: 100
Status: offline
told ya , and yes it goes in the groove it's a tight fit. good luck
Hide Signatures
       Post #: 14
RE: help with the clutch - 3/11/2006 1:28 AM
thecool1
Score: 100
Status: offline
ok...so i got the spring on....put it all back together. i took it outside to test it...and i pulled it a few times and got the pull chord stuck out.
how do i get it back in? i swear im gonna go kill myself. lol.
darin please send me a new truck. lol
Hide Signatures
       Post #: 15
RE: help with the clutch - 3/11/2006 3:05 AM
thecool1
Score: 100
Status: offline
i got it running guys. thanks for all your help.
Hide Signatures
       Post #: 16
RE: help with the clutch - 3/11/2006 3:08 AM
jeeperscreapers
Score: 100
Status: offline
NP man ALWAYS ask questions!!!! It makes a newbie like me that knows 1 or 2 things feel great!!!!! LOL!!!!!
Hide Signatures
       Post #: 17
RE: help with the clutch - 3/11/2006 3:34 AM
Xeller8
Score: 100
Status: offline
What did you have to do to get the pullstart working right and get it running??...did what I told you in my last P.M. to you do the trick??
Hide Signatures
       Post #: 18
RE: help with the clutch - 3/11/2006 7:20 PM
thecool1
Score: 100
Status: offline
i took it off the engine...and the recoil spring was broken at the end so it wasnt sitting in that little circle in the senter that holds it. so i just took some pliers and made another tab on the end of the spring and wrapped it back up and put it back in the lil circle and it was fixed
the truck is running pretty good now. doesnt stall or anything.
Hide Signatures
       Post #: 19
RE: help with the clutch - 3/11/2006 9:45 PM
Connormon
Score: 100
Last Login: 5/23/2007
Status: offline
Just a little thing i though you might like cool. I had the same problem with my pull starter...my friend had pulled it out and the spring had gotten bent, so like you i just bent it back into place. But it happened 2 more times...so i looked into new starting mechanisms and i highly recomend the Sullivan Tiger Drive. If you are interested in this your model number, being that you have the 1/10 eldorada, is S680 they cost like 15 bucks just type in Tiger Drive S680 on Ebay if your interested...theres usually a couple being sold.
You would have to buy a starting want to(S686) which is about 10 bucks...but in the end it pays off, no more blisters on your fingers.
You just simply attach the starting wand into a Roto Start Drive or Electric Screw Driver(which is what i use) and stick it in the little hole in the tiger drive and start it up, starts in a second and your hands will thank you.
just thought id say this incase you did want to get a new starter mechanism.
1/10th HiMoto Eldorada
Hide Signatures
       Post #: 20
RE: help with the clutch - 3/11/2006 11:42 PM
thecool1
Score: 100
Status: offline
sounds cool man..maybe ill look into that here soon.
Hide Signatures
(in reply to Connormon)
       Post #: 21
RE: help with the clutch - 3/12/2006 5:07 AM
ehroof
Score: 105
Last Login: 6/6/2013
Status: offline
if this doesnt help i dont know what will
http://gangster-cars.tripod.com/id7.html
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.203RCU1
