RE: %Nitro/RPM Tests
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: %Nitro/RPM Tests
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: %Nitro/RPM Tests - 3/10/2006 2:37:50 PM
Sport_Pilot
Status: online
quote:
ORIGINAL: STG
quote:
ORIGINAL: Sport_Pilot
quote:
ORIGINAL: STG
Similer to my old OS .91 FS. Put a 14-6 on it and you could keep pumping the nitro up to about 25% or so and get small incremental gains like that, but never go over 10,000 RPM.
quote:
15%....................9390
20%....................9660
30%....................9870
500 rpm from 15% to 30% on a 13x6 is not small incremental gain--it is a significant power boost.
Actually the jump between of over 200 RPM is small. The total gain is less than 500 RPM but not small. My old OS .91 showed less gain than that, actually a dog compared to a Saito, TT, or even Magnum .91. Maybe the Surpass II keeps up with those, but not the original Surpass. I was also responding to another post that OS did not do as well on nitro.
quote:
So? It's not the same engine is it?
When you said "small incremental gains like that" I took it to mean that you were gaining a similar power boost between 15% and 25%. 500rpm in the 9500rpm range is a significant power boost with a 13x6 or 14x6 prop.
I have herd time and time again and looking at Dars post here it is again....
quote:
YS are for 20-30%, Saito are for 15-25%, Jett are for 15%, OS and clones are for 5-15%...
That OS and magnum do not benifit much in power gain by jumping to 30% nitro. The test with the OS70 shows a large benifit from 15% to 30%
Bla Bla claims
quote:
Yes.. as long as its a 4 stroke.. it shows what's been known for years. 4 stroke power (regardless of brand) benifits greatly from the addition of large quanities of nitro
This was new news to me. Always learning something new.
That statement is only true of today's popular four stroke engines. Older four stroke engines and some less popular engines (Laser's come to mind) that are designed for low or FAI fuel will not respond to an increase in nitro.
< Message edited by Sport_Pilot -- 3/10/2006 2:47:08 PM >
_____________________________
“I Saw Elvis at 1000 Feet” John Force
(in reply to STG)
       Post #: 51
RE: %Nitro/RPM Tests - 3/10/2006 2:49:10 PM
STG
Status: offline
Bla Bla claims
So you think Dar ought to adjust his nitro optimization ideas to all modern 4 stokes other than YS (and Lazer) 15-25%, YS 20-30%, Laser 5%? According to the data I see on this thread looks like it to me.
< Message edited by STG -- 3/10/2006 2:52:24 PM >
Good Flying to you!
See Blog for RCU Video's
(in reply to Sport_Pilot)
       Post #: 52
RE: %Nitro/RPM Tests - 3/10/2006 3:02:11 PM
Sport_Pilot
Status: online
Yes, but it was bla bla I was responding to. He also said that two strokes do not respond to an increase in nitro.
(in reply to STG)
       Post #: 53
RE: %Nitro/RPM Tests - 3/10/2006 3:16:13 PM
B.L.E.
Status: offline
When you are trying to max out the power with nitro, you are usually looking at max revs. Sometimes you can get better performance with a larger prop, but as often as not you are on the verge of detonation with the larger prop and you will get better performance from the smaller prop. Note I said performance, not efficiency. As for as reving the four stroke engine, I think you are stuck in the early 80's. Todays four stroke engines perform poorly in the 8,000 RPM range and do better in the 9,000 and 10,000 RPM range. The max RPM on most of them have been raised from 10,000 to as high as 13,000. There is a SIG out west that race nothing but four strokes, YS I think. I believe they run over 12,000 and maybe 13,000 or so.
This may be something to watch. Just as pattern rules have pushed the evolution of 4-strokes to what they are today, maybe this will eventually bring about a new breed of 20,000 rpm 4-strokes that won't idle. Jett or Nelson 4-strokes? You never know. I bet these won't be quiet or stingy with fuel.
       Post #: 54
RE: %Nitro/RPM Tests - 3/10/2006 3:44:06 PM
bla bla
Status: offline
Sport Pilot: yes thats what I said, 4-strokes tend to benifit power wise to the addition from the adition of nitro far better than 2 strokes. Remember we're not talking F'ing antique engines here or strange specialist engines just normal run of the mill stuff.
STG.. stop toshing off.
You always seem to be terribly concerned about what people say.
You should experiment for yourself... draw your own conclusions, make your own opinions instead of listening, debating and analysing others.
Become an opinion maker, instead of an opinion spreader.
People, myself included make comments in the best possible faith, based on our own person experiences and yes, they tend to be generalizations. These may or my not agree with what you've "heard". Theres a chance that you and others may experience them as correct and there's a chance that you wont. This is something you'll never know untill you've done it for yourself and for others... not once or twice next time your at the feild this weekend... but over years.
I first started flying RC aeroplane in the mid 70's and the only thing that surprizes me today is that there are constantly many surprizes!
As in life sometimes things work when they're least expected and of course vis verse... What sould be correct wasn't and what appeared to be wrong... worked perfectly.
There IS no right or wrong... it's what works best for you in the perticular circumstance.
Stop Anal-ising.
BR blabla
       Post #: 55
RE: %Nitro/RPM Tests - 3/10/2006 3:59:48 PM
Sport_Pilot
Status: online
Ok, bla bla. I agree with you, I took your comment as an absolute.
Some things like the max rev limit of four strokes are a comomise much we value our equipment, how we enjoy them (fast or slow for example), and how much money we want to risk. For example if I won the $6000 plane from AMA I would sell it. Too many $$ in the air at one time.
(in reply to bla bla)
       Post #: 56
RE: %Nitro/RPM Tests - 3/10/2006 4:12:17 PM
STG
Status: offline
quote:
ORIGINAL: bla bla
Stop Anal-ising.
I am a tester and I do share my results. Unfortunately, although I would like to test everything, I do not have the time or the money to do so. Things that I haven't tested I do the next best thing, look at others test results and experience and try to figure out what is what from the knowledge base I have built. Yes a lot is not black and white.
Before I read this thread I had read many others stating that high nitro and OS or Mag does not yield significant results. When club members would ask me about higher nitro in the OS or Mag I would tell them that I have not seen results showing a significant increase. Now after hearing from you and others I will say that some report a significant increase with the newer OS70, OS91 and even the older OS120.
quote:
Stop Anal-ising
I do not like your tone. If you do not want to read thru my post learn to skim.
< Message edited by STG -- 3/10/2006 4:13:36 PM >
Good Flying to you!
       Post #: 57
RE: %Nitro/RPM Tests - 3/10/2006 7:18:50 PM
Spicoli
Status: offline
Dar,
"YS are for 20-30%, Saito are for 15-25%, Jett are for 15%, OS and clones are for 5-15%...
If you use less, you will get less power, a less stable idle and less reliability.
More and you get slightly more power, with a big hike in fuel consumption and some consequences..."
Have you actually tried different nitro levels in the above engines? I doubt it.
Jett will run fine on 5%
Saito runs great on 30% with no"big hike in fuel consumption"
If you are relying on what is in their manuals.
OS 5-20% nitro
Saito 10- 15% nitro
Jett 5-15% nitro
YS 15-20% nitro
(in reply to DarZeelon)
       Post #: 58
RE: %Nitro/RPM Tests - 3/10/2006 8:31:24 PM
DarZeelon
Status: online
Kelly,
I currently own no OS engine and I never owned any four-stroke.
But as the 'engine expert' where I fly, I have more playing experience with four-strokes and with their fuels, than many of the respective owners/'throttle pushers' of these same engines. I also learn better than most, from what I do.
Any YS, except the 1.40-1.60, will run badly with lower nitro fuel. Even 15% is insufficient, except for the 1.40-1.60.
And less than 15% is wrong for all of them, period. A nitro-hog...
I know OS two and four-stroke engine will run pretty well on 5% nitro.
Saitos will run markedly better on 15% and more and with 5%, you would be seeing inadequate performance and reliability.
Jetts... I hope to own one some day, but since Dub does not recommend a range of percentages, but one single percentage of 15, I believe Dub Jett is competent enough to optimize his engine to run with 15% nitro.
I have never seen a Jett run on 5%...
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to Spicoli)
       Post #: 59
RE: %Nitro/RPM Tests - 3/10/2006 9:14:43 PM
Richard L.
Status: offline
The YS 63 runs best at around 11,500 rpm on 20% nitro and idles at 2000 rpm. The larger YS four strokes like it between 9000 and 9500 rpm static.
By the way, a YS four stroke would run just fine on 15% nitro
< Message edited by Richard L. -- 3/10/2006 9:15:35 PM >
http://www.WarbirdObsession.com/
Tamiya Panther, Tamiya King Tiger(3), Tamiya Tiger I, HL Tiger(3), HL Panzer III(2), HL Panther, HL Pershing, HL Bulldog, WSN T-34/85, HE Leopard 2A5
       Post #: 60
RE: %Nitro/RPM Tests - 3/11/2006 12:35:54 AM
Spicoli
Status: offline
Dar,
"Dub does not recommend a range of percentages, but one single percentage of 15, "
You are wrong.When I said "Jett 5-15% nitro" I was not just pulling those numbers out of the air.Ask him yourself.
Have you ever used 30% Cruelpower in a Saito ?
< Message edited by Spicoli -- 3/11/2006 12:44:28 AM >
(in reply to Richard L.)
       Post #: 61
RE: %Nitro/RPM Tests - 3/11/2006 2:51:35 AM
downunder
Status: offline
quote:
ORIGINAL: DarZeelon
We humbly sit at your feet waiting for pearls of wisdom to fall down on us.
Please explain, master, if Jett's can only be run with 15% nitro then why in their operating instructions do they say to use a propellor with 1" less pitch if using zero nitro? This simple grasshopper can only assume that, while Jett's may be optimised for 15% nitro, they also allow for using less, even zero, nitro.
*rattles prayer wheel in hopes of enlightenment*
       Post #: 62
RE: %Nitro/RPM Tests - 3/11/2006 5:41:16 AM
DarZeelon
Status: online
True, Brian.
...Also the 'pearls of wisdom' thing.
