RE: Picco 26 Max....the DARK SIDE....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> RE: Picco 26 Max....the DARK SIDE....
Page: <<   < prev  35 36 37 38 39 40 41 [42] 43 44   next >   >>
Login
RE: Picco 26 Max....the DARK SIDE.... - 2/20/2008 10:56:30 PM
HILLFINGER
Status: offline
quote:
ORIGINAL: Drevo14
quote:
ORIGINAL: HILLFINGER
When you make adjustments are you clearing the engine out, you need to drive it a minute or so between adjustments. Most of the time adjustments will not be noticeable as soon as they are made.
When it up to at operating temperature does it run? or are you just having problems getting it to idle.?
ok i didn't know that, so after adjusting the needles i need to wait after about a minute of drive time to see an effect? Yeh im just having problems getting it to idle, the whole time I've kept it between 200 and 220, it just will die as soon as i let of the throttle, or take off the glow warmer, and if i keep the throttle on about 1/4 itll last about 30 seconds before dieing. I noticed some air bubbles in the fuel tubing, so im gonna check the tank and lines for leaks, i doubt theres an airleak in the motor cos i sealed it all up beforehand.
I would try and finish the break in first, then start tuning the engine. Start with the high speed first when it is tuned and running good start with the low side. Usually when mine dies when idling it is because it is to lean.
_____________________________
www.traxxaddicts.com
(in reply to Drevo14)
       Post #: 1026
RE: Picco 26 Max....the DARK SIDE.... - 2/21/2008 5:53:27 PM
Drevo14
Status: offline
Ok thanks but I can't really break it in properly when it's dieing all the time, do you think I should try richening it a bit to see if itll run ok?
(in reply to HILLFINGER)
       Post #: 1027
RE: Picco 26 Max....the DARK SIDE.... - 2/21/2008 11:02:26 PM
HILLFINGER
Status: offline
I would reset the needles back to the factory setting then go from there.
       Post #: 1028
RE: Picco 26 Max....the DARK SIDE.... - 2/23/2008 4:51:11 PM
Drevo14
Status: offline
kk, what are the factory settings btw, because everyone is saying something different, and can you say whether its in full turns or half turns, because some people have been giving them in half turns. Thanks.
       Post #: 1029
RE: Picco 26 Max....the DARK SIDE.... - 2/23/2008 5:42:14 PM
HILLFINGER
Status: offline
quote:
ORIGINAL: Drevo14
High Speed Needle needs to be set flush with the end of the needle housing
Low Speed Needle needs to be 1mm out from flush with the brass sleeve.
The slide in the carb needs to be open 1/16" to do this look inside the carb neck, the slide in there needs to be opened 1/16" turn the idle screw to adjust this.
       Post #: 1030
RE: Picco 26 Max....the DARK SIDE.... - 3/12/2008 8:51:30 AM
MIKEA46996
Status: offline
Wow looks like the Darkside has seen brighter days... Anyway I am bring my money pit out of retirement and need to stomp my little brother he just bought a 3.3. I have been looking at the Picco, but after reading about 20 or so pages I have concerns. Is it a good motor or not I really dont wanna spend the money on the RB that somebody else recommended. Also I know I'm goona get grief for this but I want dual exhaust have been looking at the Integy system. Wanna wheelstand and smoke his *ss on our track. I know this is the Darkside but please be honest here which engine should I go with. Hell it's a Tmaxx guess another couple hundred wont kill me. really need the help guys gonna be ordering this weekend. Don't wanna get pissed at the money pit and shelf her for years again. Backyard bashing and maybe some club racing, ain't gotta be first just gotta beat the little brother.
T-maxx RB523 / T-maxx OS 18TM / RC10GT2 / Revo 3.3 and a butt load of planes Trucks all Spektrum, Planes JR 7202
       Post #: 1031
RE: Picco 26 Max....the DARK SIDE.... - 3/12/2008 11:50:56 PM
EZZZROCK
Status: offline
ok i have a t-maxx with the picco .26 i have had it for about a year now no problems at all i have found that this is on of the better engines that you can put into a t-maxx also i just put the rd duel exhaust on i cant keep this thing on the ground had to put a wheelie bar on it just to keep it from flipping over i have about 6 trucks a 1 truggy and like i said this is one of the better engine i have came across
(in reply to MIKEA46996)
       Post #: 1032
RE: Picco 26 Max....the DARK SIDE.... - 3/13/2008 12:00:05 AM
EZZZROCK
Status: offline
sounds like its running rich
       Post #: 1033
RE: Picco 26 Max....the DARK SIDE.... - 3/22/2008 1:30:54 AM
Retiredtech
Status: offline
Has anyone found a solid backplate for the mighty .26 max yet ???????????????
(in reply to EZZZROCK)
       Post #: 1034
RE: Picco 26 Max....the DARK SIDE.... - 3/22/2008 1:47:49 AM
HILLFINGER
Status: offline
quote:
ORIGINAL: Retiredtech
I haven't seen one made by a company.I have seen a few people that have made there own though.
(in reply to Retiredtech)
       Post #: 1035
RE: Picco 26 Max....the DARK SIDE.... - 3/22/2008 1:52:28 AM
Retiredtech
Status: offline
Yea I have seen a couple on here and other sites but they leave the shaft in or JB weld quarters in there. Do you know of anyone that makes them like the 3.3 has ?
       Post #: 1036
RE: Picco 26 Max....the DARK SIDE.... - 4/24/2008 1:26:13 AM
JamminRoger
Status: offline
We Have a new version of the .26 Max coming out, the JL Racing red dot .26 Max!!! Here is a link to the post, I figured if anyone should know, it's you guys.
JL .26 max engine link
OFNA Tech/Part time racer
       Post #: 1037
RE: Picco 26 Max....the DARK SIDE.... - 4/24/2008 2:03:15 AM
RCCanuck
Status: online
oh man that is a sexy engine.....I may have to be jammin one of these into a Tmaxx....get it Jammin one in LOL...thank you I'm here all week
2.5 Tmaxx// T Maxx-Picco.26//2.5 Race Spec maxx//Savage SS//Brushless Micro T's//Micro DT ...all controlled by Spektrum
(in reply to JamminRoger)
       Post #: 1038
RE: Picco 26 Max....the DARK SIDE.... - 4/25/2008 4:39:55 PM
JamminRoger
Status: offline
where do we buy tickets to your first show?
(in reply to RCCanuck)
       Post #: 1039
