RE: Return of Lunchbox..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Classic Cars & Trucks >> RE: Return of Lunchbox..
Page: <<   < prev  292 293 294 [295] 296 297 298 299 300 301   next >   >>
Login
RE: Return of Lunchbox.. - 3/15/2012 3:00 AM
Hwa224
Last Login: 4/3/2013
Status: offline
 LBXnut,
You should post your video on Youtube. It reminds me of this video:
Talk about a chipping paint job, right? But I love the sound his LB makes when accellerating.
lunchie,
Nice to read you finally got your parts in. I hope you and your children enjoy the LB!
The suspension should definitely be softer than what you seem to have. Dampers don't dampen a thing if the suspension and the springs are so stiff!
< Message edited by Hwa224 -- 3/15/2012 3:01 AM >
_____________________________
Lunch Box (Venom ESC + Venom 13t motor) | DB01 Baldre (EZrun 60a + LRP X12 6.5t 5500kv brushless)
Hide Signatures
(in reply to Hwa224)
       Post #: 7351
RE: Return of Lunchbox.. - 3/15/2012 1:27 PM
StevenJV
Last Login: 4/30/2012
Status: offline
Thank you for reviewing my post fellas with such detail.
Thanks for the servo reminder and the comments about the battery/charger.  Good to know the controller is a solid choice too.
My updated list after review:
SUMMARY
TRUCK 109.98 Tower
Steering servo 11.99 Tower Futaba S3004 Standard Ball Bearing Servo
Battery pack 19.99 Tower DuraTrax Onyx NiMH 6C 7.2V 3000mAh Stick Standard Plug
  141.96
  (15.00) Tower discount over $125
Battery Charger 49.70 Hobby Partz Thunder T610 NiCd/MH(1~18 cells) & LiIo/LiPo/LiFe: 1~6 series Balance Charger/Discharger w/ LCD Display+Auto-Fan
BEARINGS 9.95 VXB
RADIO 39.95 Hobby Partz FlySky FS-GT3B Digital 3ch 2.4ghz TX & RX LCD Transmitter & Receiver
  226.56
< Message edited by StevenJV -- 3/15/2012 1:47 PM >
Hide Signatures
       Post #: 7352
RE: Return of Lunchbox.. - 3/15/2012 5:04 PM
Hwa224
Status: offline
I believe with the T610 charger, you'll need to buy a power supply seperate.
I myself recently purchased the Thunder AC6.
The AC6 comes with the power cord. The difference between them is that the AC6 charges at 5 amps max doesn't come with built-in fan and so it's cheaper. (The Thunder T610 charges at 10 amps max which makes it relatively future proof if your batteries ever get bigger.) I haven't received the AC6 yet, but I believe the AC6 comes with an array of connectors which includes the Tamiya/molex connector, whereas the T610 comes with bullet plugs, and so you'll have to either solder the molex yourself or buy the Tamiya connector with 4mm banana plugs seperate or get that style of bullet plug and solder it onto your battery.
Tamiya connector:
http://www.hobbypartz.com/thunder-tamiyaconnector.html
The AC6:
http://www.hobbypartz.com/thac6smbachw.html
If I'm honest, I'd rather have purchased the T610. But I will be charging my batteries at 1c, and for a 5000mah LIpos that = 5 amps. So I'll be good for now.
< Message edited by Hwa224 -- 3/15/2012 5:21 PM >
Hide Signatures
(in reply to StevenJV)
       Post #: 7353
RE: Return of Lunchbox.. - 3/16/2012 1:18 PM
StevenJV
Status: offline
Thanks Hwa224, I added the Tamiya connector to my order, only $3 for just in case and have everything on its way to me.  And thanks for explaining some of that diff in chargers.
I remember the charger I used to have was like carrying a toaster around.  These are pretty fancy and the costs...they sure have changed.  Way less then what I paid back in the day.
Hide Signatures
       Post #: 7354
RE: Return of Lunchbox.. - 3/19/2012 11:47 AM
Bootnut
Last Login: 3/27/2012
Status: offline
quote:
ORIGINAL: Timmy2Tracks
quote:
ORIGINAL: lbshelfqueen
i really really need those alloy uprights.. any idea where i can get some?
Here ya go, my man. They make nice stuff, and ship qucikly.
http://www.junfac.com/shop/index.php?main_page=product_info&products_id=420&zenid=5fccb7766bea243a6f0b73b415f1513b
If i get these, what axels do i use? cause the ones on the lunch box are attached to the plastic thing upright? do Junfac sell axels to push into these new uprights? or another model i can get them off?
Hide Signatures
(in reply to Timmy2Tracks)
       Post #: 7355
RE: Return of Lunchbox.. - 3/21/2012 6:34 AM
Hwa224
Status: offline
StevenJV,
Very important information about your FlySky You may have to bind your receiver to your transmitter.
You'll find instructions on how to do this at various websites, but here's information you'll need if your receiver is like the version that I recently received:
(1) With your receiver powered up (a power source through the "vcc" slot) and with the bind plug in the "Bind"/channel 3 slot, your receiver is supposed to blink.
(2) When you hold the transmitter bind button and then turn on your controller, that blinking light turns solid after about 3 seconds.
However, it appears FlySky are getting cheap with their circuits. So instead of the above, what you'll see with the bind plug in the bind slot is a solid light. Hold the bind button on your transmitter, then wait for about 3 seconds or more. The rx and tx are now bound - even though you didn't start with a blinking led etc.. Remove the bind plug and test. The two should be bound.
Hide Signatures
(in reply to Bootnut)
       Post #: 7356
RE: Return of Lunchbox.. - 3/23/2012 6:55 PM
StevenJV
Status: offline
Ok thanks for that.
I was out of town for a few days but all my shipments arrived and are waiting for me to crack boxes.
I've also been waiting for power supplies to get off of "backorder" status at hobbypartz.  I keep watching the G350 to be available while searching for a comparable product in price and specs.
Hide Signatures
       Post #: 7357
RE: Return of Lunchbox.. - 3/26/2012 9:00 AM
lunchie
Last Login: 5/13/2013
Status: offline
NEARLY DONE!
just about ready! all i have to do is make up the body mounts and setup the steering geometry and a few cosmetic things like custom licence plate.
third shock all mounted.
Front shock and rear tray braces all fitted up and the wheelie bar brace...made from 3mm stainless threaded rod.
you can also see my custom gear plate for the radio gear. i just cut down the two "towers" that were used to hold up the mech speed control and bolted the plate to the bottom of the chassis. I may swap it out for a plastic one if i get glitches.
enjoy the pics.
< Message edited by lunchie -- 3/26/2012 9:16 AM >
Hide Signatures
(in reply to Lunchboxer)
       Post #: 7358
RE: Return of Lunchbox.. - 3/26/2012 9:05 AM
lunchie
Status: offline
heres the pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by lunchie -- 3/26/2012 9:13 AM >
Hide Signatures
(in reply to lunchie)
       Post #: 7359
RE: Return of Lunchbox.. - 3/27/2012 1:01 AM
Hwa224
Status: offline
 Still nothing like an immaculate Lunch Box, freshly built. I love the blue dampers. What brand are those?
Hide Signatures
       Post #: 7360
RE: Return of Lunchbox.. - 3/27/2012 1:14 AM
Scratch2k
Last Login: 5/2/2012
Status: offline
quote:
ORIGINAL: lunchie
heres the pics
I love the strut brace, much classier than my trimmed spare back panel insert from an old PC.
Hide Signatures
       Post #: 7361
RE: Return of Lunchbox.. - 3/27/2012 7:36 AM
lunchie
Status: offline
They are 78mm integy. Fronts are shortened 85mm hsp
Hide Signatures
(in reply to Scratch2k)
       Post #: 7362
RE: Return of Lunchbox.. - 3/27/2012 9:02 AM
Bootnut
Status: offline
 Nice bracing! I have the same on my lunchbox and pumpkin wheelie bars, I noticed you have a couple more in other places, something for me to try on a rainy day.
This weekend we had some monster truck races
Midnight pumpkin - Tamiya BZ dirt motor - aftermarket aluminium wheels, stock tires
Lunchbox - Tamiya Sport tuned motor - standard plastic wheels
Both trucks have the same brand oil shocks, 3rd shock mod etc, anyway the lunchbox won the races every time. It’s my favourite truck again hehe.
I also raced the pumpkin against my brothers stock 1/10 Traxxas Grave digger, it was a really even match maybe swaying to the grave digger. So I’m taking the lunchbox next time, maybe some softer springs, I will beat him!
Hide Signatures
       Post #: 7363
RE: Return of Lunchbox.. - 4/1/2012 5:47 AM
lunchie
Status: offline
HELP!
well after the first two batteries i have had the pinion grub screw loosen off and now the servo screw fall out GRRRRRRR!
time for some loctite?
also how long do you get on a stock lunchbox with a 3000mah battery?
my lunchbox feels ssssssssoooooooooo ssssssslllllooooooowwwwwww. i mean really slow.
it lacks punch off the line, and feels like a cheap nicco store car barely able to get through the grass.
do the nimh batteries get better with age/use?? (duratrax onyx 3000mah.)
< Message edited by lunchie -- 4/1/2012 5:50 AM >
Hide Signatures
       Post #: 7364
RE: Return of Lunchbox.. - 4/1/2012 4:28 PM
Timmy2Tracks
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: Bootnut
Bootnut: You can slide them (axles) out of the plastic Tamiya uprights, and slide them into the Junfac units. If you tap the metal axles with a punch or a nail, they will pop right out.
< Message edited by Timmy2Tracks -- 4/1/2012 10:34 PM >
Hide Signatures
       Post #: 7365
RE: Return of Lunchbox.. - 4/1/2012 10:24 PM
Hwa224
Status: offline
With 3000mah battery, you should get 30 minutes or more on stock motor. On a 3800mah battery I got more than 40 minutes. And the LB had a good punch to it. Not of course much of any top speed but it was zippy even with the silver can.
Make sure your battery is a genuine 3000mah battery or is not defective.
On grass, however, the silver can is barely able to push the LB.
quote:
ORIGINAL: lunchie
HELP!
Hide Signatures
       Post #: 7366
RE: Return of Lunchbox.. - 4/8/2012 10:16 AM
lunchie
Status: offline
haha so now my 5 year old has broken the body moounts and dislodged the front chrome bumper. need to make up some new body mounts
Hide Signatures
       Post #: 7367
RE: Return of Lunchbox.. - 4/9/2012 1:51 PM
StevenJV
Status: offline
Got my power supply and charger setup.
Exciting to me only but posting an update.
Also did some body painting this weekend and came to work with green paint all over my hands.  I think I got the paint on the wrong body.
Click for fullsize
Hide Signatures
       Post #: 7368
RE: Return of Lunchbox.. - 4/10/2012 4:09 PM
StevenJV
Status: offline
got the paint done with and gave the LB a trial run outdoors
Just need to tighten up the electics inside
paint and glue the wheels
then get ready to fix everything that breaks as soon as my kids have at it.
I think I'm going to pick up a parma body and spend time detailing that and get more experience with painting
Click for fullsize
Hide Signatures
       Post #: 7369
RE: Return of Lunchbox.. - 4/19/2012 8:21 AM
lunchie
Status: offline
come on lunchboxers!!!
where are you all??
dont let the yellow van die!
Hide Signatures
       Post #: 7370
RE: Return of Lunchbox.. - 4/19/2012 4:29 PM
magic2002
Last Login: 5/22/2013
Status: offline
don't worry it is very much alive... so much  even we don't have time to post here..
meanwhile, enjoy... http://www.youtube.com/watch?v=xPVtBlcvb2U
Martin
Hide Signatures
       Post #: 7371
RE: Return of Lunchbox.. - 4/19/2012 5:23 PM
Lunchboxer
Last Login: 5/24/2013
Status: offline
Nice video!!
LB | WW2 | TLT | TB02 | DF03 | TEgg | F103GT | TXT | Hornet | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod | CR-01
Hide Signatures
(in reply to magic2002)
       Post #: 7372
RE: Return of Lunchbox.. - 4/20/2012 5:00 AM
Hwa224
Status: offline
StevenJV,
What a sexy beast your LB is! I like the green..? Looks nice. It looks blue in one of the slides of your pic, unless that's a different body.
In RC, there's a tension, a constant battle between liking the hobby because you have a beautiful RC car vs liking the hobby because running that RC car is fun. The problem is that these two things are almost mutually exclusive. The more you run the car, the more crap it looks, the more it gets damaged, which = ugly RC. LOL.
But a moist microfiber towel can do wonders. And good driving skills.
Hide Signatures
       Post #: 7373
RE: Return of Lunchbox.. - 4/20/2012 1:16 PM
StevenJV
Status: offline
Its a metallic jade green I think. it was a can of spray that looked good enough to me for $5. thank you.  I sprayed a little heavy though, oh well.
this week I picked up a pair of 50520's to swap in and I grabbed an upgraded steering tierod set from a dude who has them prebuilt on ebay.  My stock ones kept getting loose.
I havent quite looked at how the 50520's attach but I know they should work pretty good.  I probably need an extra part or two to attach the top of the shock, guess I'll find out.
oh, and I spray painted those yellow rims black.  no more john deer look.
< Message edited by StevenJV -- 4/20/2012 1:17 PM >
Hide Signatures
       Post #: 7374
RE: Return of Lunchbox.. - 4/28/2012 10:25 AM
giagal
Status: offline
Hi  everybody, I'm new in the forum, I've got a LunchBox and read this post full of great hints.
Great job!
Here is a picture of my Lunchie...
Click for fullsize
Hide Signatures
       Post #: 7375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.953RCU1
