RE: Return of Lunchbox..
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Return of Lunchbox..
Page: <<   < prev  16 17 [18] 19 20 21 22 23 24 25   next >   >>
Login
RE: Return of Lunchbox.. - 11/9/2006 5:13:42 PM
Lunchboxer
Status: offline
Looks really good for a bash body!! It will get scratched up a lot more soon I am sure.. hee hee!! Welcome to the club!!
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to adey)
       Post #: 426
RE: Return of Lunchbox.. - 11/9/2006 5:18:06 PM
adey
Status: offline
Yeah I know.. got a bit carried away: now the nights are getting darker earlier here! Won't stop me bashing it believe me!
Will spend lots of time on the other body.
(in reply to Lunchboxer)
       Post #: 427
RE: Return of Lunchbox.. - 11/9/2006 5:19:08 PM
Lunchboxer
Status: offline
You put ballbearing on your Lunchbox, I hope?
Any mods planned?!
(in reply to adey)
       Post #: 428
RE: Return of Lunchbox.. - 11/9/2006 5:21:14 PM
adey
Status: offline
Ball bearings are on their way from Australia (eBay purchase).
May go for oil shocks then; I've spotted a good price on eBay for these too.
       Post #: 429
RE: Return of Lunchbox.. - 11/9/2006 5:27:46 PM
Lunchboxer
Status: offline
Sounds good.. keep us posted...
Maybe do the 3rd shock conversion?!? hee hee
(in reply to adey)
       Post #: 430
RE: Return of Lunchbox.. - 11/9/2006 5:47:12 PM
adey
Status: offline
Yeah that looks good... my axle springs are already knackered... one does less of a job than the other, so rear end sits lower on that side.
Saw someone mentioning doing it with the standard 'shock' that comes with the 'box.. that would save a purchase if it worked. Would be mega bouncy though I suspect.
       Post #: 431
RE: Return of Lunchbox.. - 11/9/2006 6:02:33 PM
Lunchboxer
Status: offline
No idea, I got 5 oil shocks on my Lunchbox, so.... hee hee.. but it is currently not running now.. I don't have electronic on it now.. and one of the front wheels is cracked.. (after brushless abuse.. ha ha ha!)
(in reply to adey)
       Post #: 432
RE: Return of Lunchbox.. - 11/17/2006 3:16:54 AM
broncojd
Status: offline
AHAHAHAHAHAHA!
finally, the oil-filled shocks came and are installed. HOLY COW...can i get some camber?!
these are the stock front shocks from the traxxas stampede, rustler, bandit, and sport. i used front traxxas shocks on the front and back of the 'box. i got the shocks from the new XL-5 stampede that come with white springs. i painted them to match the body of the lunchbox. however, they are friggin' STIFF! what weight oil do you guys use in your lunchboxes? when i replace the oil i'll put in some spacers to fix that camber.
up next: the wheels for the 2.2 tires i recently bought and some of the oil shock brackets to attempt the 3rd shock.
check the pics...pretty sharp if i say so myself.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to adey)
       Post #: 433
RE: Return of Lunchbox.. - 11/17/2006 3:45:30 AM
rcxboy
Status: offline
Maybe some shorter springs and thinner oil?
(in reply to broncojd)
       Post #: 434
RE: Return of Lunchbox.. - 11/17/2006 3:56:12 AM
Lunchboxer
Status: offline
Definitely need some spacer inside to limit the travel a little bit!! Or just shorter springs!!
(in reply to rcxboy)
       Post #: 435
RE: Return of Lunchbox.. - 11/17/2006 4:03:01 AM
broncojd
Status: offline
quote:
ORIGINAL: Lunchboxer
i'm going to put a spacer in them when i replace the oil.
what weight oil do you use?
       Post #: 436
RE: Return of Lunchbox.. - 11/17/2006 4:33:27 AM
Lunchboxer
Status: offline
Depends on track condition and temperature..
Just playin'.. I just use standard Tamiya soft/medium oil...
       Post #: 437
RE: Return of Lunchbox.. - 11/18/2006 3:58:27 PM
rcluke
Status: offline
Hey all lunch box fans out there,
Lunchboxer i love the idea of having a 5th shock absorber on the gearbox,
but i have found a much easier and cheaper alternative.
Where the gearbox fits into the runners, (while your box is upside down), drill 2 small holes just above the gearbox mount(the bar in the runners, im not sure what its called), then screw a small screw into the hole (do this on both sides). Then when you turn your box back onto its wheels, the gearbox bar will be 'locked' at the very top of the runners.
this makes for stiffer wheelies.
Another little idea, which i have just done on m own box, is if you tip your box upside down again. Take the wishbones off, take the battery tray off. Then you will notice that there is a big hole / space. (underneath where Tamiya reccomend putting the reciever). Find an old socket set, the fill the space with sockets. Make sure you DO NOT fill the space too high, or your battry wont fit in. Cover over the sockets with tape, again so your battery fits in. Re assemble your car. This should now decrease the chance of rolling through a corner.
loving the forum and your box's guys, keep up the good work,
rc luke
My Rides; Team Associated TC5, Team Losi XXXCR, Tamiya F103
NOVAK OR NOTHING
