RE: Return of Lunchbox..
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Return of Lunchbox..
Page: <<   < prev  180 181 [182] 183 184 185 186 187 188 189   next >   >>
Login
RE: Return of Lunchbox.. - 5/28/2008 2:01:52 PM
Lunchboxer
Status: offline
A good way to do the 3rd shock? It should be really secured, but the rear axle flexes.. so I am not so sure about having the shock mounted this way (through the steel pin) is the way to go?! Hmm...
Click to see fullsize image.
Click for fullsize
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to Lunchboxer)
       Post #: 4526
RE: Return of Lunchbox.. - 5/28/2008 2:56:57 PM
broncojd
Status: offline
if they left room for it to move then it'll be all good. if the shock is flush against the axle...then maybe not.
       Post #: 4527
RE: Return of Lunchbox.. - 5/28/2008 2:57:10 PM
Dante77
Status: offline
I think most users here do it this way, but I also prefer the U-bracket-with-ball-connector solution.
quote:
ORIGINAL: Lunchboxer
< Message edited by Dante77 -- 5/28/2008 3:00:43 PM >
LB brushless, Street LB, Blitzer Beetle, Dyna Blaster 2x, Bear Hawk, Frog, F101 CUDA, Hilux, Wild One, Monster Beetle 2x
       Post #: 4528
RE: Return of Lunchbox.. - 5/28/2008 3:06:25 PM
Lunchboxer
Status: offline
But even with room, the fact is that the axle really isn't meant to move smoothly inside of the ball cup / connector when moving beyond a certain degree of flex.. so that's why I am not so sure about this approach...
Maybe it is not an issue.. but I am just thinking outloud..
I use ball connector... ha!
quote:
ORIGINAL: broncojd
(in reply to broncojd)
       Post #: 4529
RE: Return of Lunchbox.. - 5/28/2008 5:01:07 PM
alaskadf300
Status: offline
I actually moved and altered my third's mounting. It was limiting movement having the upper mount straight above the shock, so I put it on the "firewall" as many have done, but also used a very heavy spring and have removed the shock shaft. This makes for a spring that won't come off, but is free to snake around any which way that's needed. True, there is no damping effect, but rear articulation is radical now compared to stock.
Summer-Tamiya Lunchbox/Winter-Kyosho Blizzard/Indoors-micro baja/Shelf-Tamiya Rough Rider
       Post #: 4530
RE: Return of Lunchbox.. - 5/28/2008 5:01:08 PM
rcluke
Status: offline
thats how i had mine on my 'box
cut straight through the gearbox with a hack saw
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05
NOVAK OR NOTHING
       Post #: 4531
RE: Return of Lunchbox.. - 5/28/2008 5:41:45 PM
Lunchboxer
Status: offline
I am the opposite.. I got no spring, only damper.. ha!!
quote:
ORIGINAL: alaskadf300
(in reply to alaskadf300)
       Post #: 4532
RE: Return of Lunchbox.. - 5/28/2008 7:00:13 PM
pastimesteve
Status: offline
Lunchboxer this is how I've done the 3rd shock on my midnight pumpkin, but I haven't run it yet, so who knows if it will hold up. I think you've raised some excellent points and you certainly have more experience with this stuff than I do, so we'll see.
I'm also curious about alaska's change to mounting the 3rd shock bracket on the "firewall." I would think that would put the shock at a very strange and unproductive angle, but what the heck do I know!
Also, I have the CRP kit on the way, so I'm anxious to get that installed.
Steve
       Post #: 4533
RE: Return of Lunchbox.. - 5/28/2008 7:05:04 PM
Lunchboxer
Status: offline
Well, try it out and let us know how you like it!! It is what this hobby is all about.. you can do crazy modification to your cars.. and don't have to worry about much..
(in reply to pastimesteve)
       Post #: 4534
RE: Return of Lunchbox.. - 5/29/2008 3:31:32 AM
alaskadf300
Status: offline
I only used the term firewall as it's the first vertical bulkhead between the motor and the interior, mine's mounted just the same as the pic at the top of this page. The only difference, is that I am using a spring that's unwilling to come off the lower and upper pivots and forms a sort of "S" shape when the rear is moving about. I'll try to post a pic when I have the opportunity. Now I'm planning on painting the wheels flat black and the body some solid color that I have yet to decide on, oh, and a dual wheeled wheelie-bar that articulates with springs.
< Message edited by alaskadf300 -- 5/29/2008 3:35:29 AM >
       Post #: 4535
RE: Return of Lunchbox.. - 5/29/2008 4:32:56 AM
alaskadf300
Status: offline
       Post #: 4536
RE: Return of Lunchbox.. - 5/29/2008 7:30:22 AM
Dante77
Status: offline
Sorry about my ignorance, but what is that big blue blob in the center of your chassis?
