RE: Return of Lunchbox..
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Return of Lunchbox..
Page: <<   < prev  193 194 [195] 196 197 198 199 200 201 202   next >   >>
Login
RE: Return of Lunchbox.. - 7/21/2008 11:37:28 PM
Lunchboxer
Status: offline
Must have hit something pretty hard to break the chassis! I try to avoid any hits..
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to blinky55)
       Post #: 4851
RE: Return of Lunchbox.. - 7/22/2008 12:17:44 AM
Stampede Killer
Status: offline
quote:
ORIGINAL: kistner
I am running the sidewinder with a vxl motor, starting to experience some damage, I noticed cracks in the chassis:
how did that happen? have a bad crash?
< Message edited by Lightfoot -- 7/22/2008 12:33:38 AM >
T-Maxx .15 | Stadium Blitzer | Revo 3.3 (dad''''s) | Super Blackfoot | Micro Baja | Lunchbox | Blackfoot Xtreme
(in reply to kistner)
       Post #: 4852
RE: Return of Lunchbox.. - 7/22/2008 12:32:21 AM
kistner
Status: offline
not really sure, just noticed it. There was a night off jumping off the patio down to a grassy area, about four feet lower. then cruising back up the hill and off again (in the dark with the headlights on ). It goes faster now, I assumed the damage was from faster crashes. This one is an original so maybe the plastic is getting brittle with age. I really don't know. I have been forming an idea of how to fix it up with some aluminum rods. Basically take the rods for body mounts (like lunchboxers) and connect them with another rod running front to back that also ties in with the shocks. What do you think?
Traxxas Rustler - Tamiya Lunchbox - Traxxas Eagle - HPI RS4 MT
''This is all just a bunch of jumbled up nothingness''
(in reply to Stampede Killer)
       Post #: 4853
RE: Return of Lunchbox.. - 7/22/2008 12:35:27 AM
Lunchboxer
Status: offline
Ah, I see.. you are abusing the 20+ yrs old plastic...
Luckily, the chassis is readily available!!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGB36&P=Z
       Post #: 4854
RE: Return of Lunchbox.. - 7/22/2008 12:47:34 AM
kistner
Status: offline
I enjoy the challenge of fixing it myself, if I can. I have the chassis on my tower wishlist if it doesn't work out!
(in reply to Lunchboxer)
       Post #: 4855
RE: Return of Lunchbox.. - 7/22/2008 1:00:31 AM
Stampede Killer
Status: offline
are you running a hornet pinion?
       Post #: 4856
RE: Return of Lunchbox.. - 7/22/2008 1:08:58 AM
kistner
Status: offline
No, just the stocker. I have one, and really want to try it out. But it is also driven by one of my kids (ok, so technically it is his) and the extra speed would probably result in someone getting hurt.
       Post #: 4857
RE: Return of Lunchbox.. - 7/22/2008 6:47:27 PM
frugalman
Status: offline
got a slight problem from spray painting.. arrghh
i'm wondering, do you use generic plastic spray paint from say walmart or target? (or stick to tamiya paint. those are so little and cost so much)
if i grab a lacquer plastic spray paint from walmart, those are ok for the lunchbox hard shell?
f150 | super clodbuster | lunchbox | dark impact
       Post #: 4858
RE: Return of Lunchbox.. - 7/22/2008 6:52:07 PM
Lunchboxer
Status: offline
Use the nice Tamiya paint, man... one bottle, for one shell.. and be happy w/ the high quality finish!!!
(in reply to frugalman)
       Post #: 4859
RE: Return of Lunchbox.. - 7/22/2008 7:18:59 PM
frugalman
Status: offline
quote:
ORIGINAL: Lunchboxer
problem is.. stupid me, i sprayed one coat on one side.. was trying to turn it around and the shell fell off the platform. then it stuck on some blue paint dust particles. OMG!
now i'm trying to cover it, but running out of paint
       Post #: 4860
RE: Return of Lunchbox.. - 7/22/2008 7:23:25 PM
Lunchboxer
Status: offline
................... DOH!!
Good luck! I'd say, sand it down, wash it, clean it, and re-spray... and get a new bottle of paint!
       Post #: 4861
RE: Return of Lunchbox.. - 7/22/2008 7:26:36 PM
lbshelfqueen
Status: offline
i use normal car paint, even on polycarbonate, if you do really fine dust coats its flexible enough.
but on abs (hard shells) i use a coat or 2 of etch primer, wet sand it back with 600 grit then 2 0r 3 dry coats to get a good base then one nice wet coat to get the shine. and its a reeal deep shine too!
1981 (chevy) clod, full chrome pumpkin, fast gold LB, m-02L alfa sprint.
       Post #: 4862
RE: Return of Lunchbox.. - 7/22/2008 7:31:09 PM
Lunchboxer
Status: offline
It really doesn't matter anyway, as you will scratch the heck out of it the first time you drive it.. so just finish the paint job.. and re-finish it 3 months from now.. when it is all beat to death!!
Oh yeah, I run mine w/ lex
