RE: Return of Lunchbox..
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Return of Lunchbox..
Page: <<   < prev  195 196 [197] 198 199 200 201 202 203 204   next >   >>
Login
RE: Return of Lunchbox.. - 7/26/2008 12:36:46 AM
lbshelfqueen
Status: offline
i have descison to make.
do i get the novak 8.5t ss5800 and run it at 7.2v for around 39,700 rpm using the 10 tooth pinion
or do i get the carson 12t dragster brushless, run it at 9.6v for around 31,500 rpm but use the 18 tooth pinion.
i dont know what would be best, higher rpm or slightly higher torque from the carson.. hmmmmmmm
_____________________________
1981 (chevy) clod, full chrome pumpkin, fast gold LB, m-02L alfa sprint.
(in reply to tamiya trucker)
       Post #: 4901
RE: Return of Lunchbox.. - 7/26/2008 12:39:13 AM
tamiya trucker
Status: offline
well mine should be up and running again soon..will be standard but thats how i want it...i just need window glass and 2 body mounts
what buggy oil shox fit straight onto the lb?
my oscar is evil...
(in reply to lbshelfqueen)
       Post #: 4902
RE: Return of Lunchbox.. - 7/26/2008 2:19:24 AM
Lunchboxer
Status: offline
Novak 8.5 gets the vote for me because it is easier.... you don't need the 9.6V pack..
For the Carson motor, I assume it is sensorless.. that you'd be power it up using a Sidewinder or a MM? Or? (cause you said you are going to run 9.6V)
quote:
ORIGINAL: lbshelfqueen
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
       Post #: 4903
RE: Return of Lunchbox.. - 7/26/2008 2:20:29 AM
Lunchboxer
Status: offline
You can get the standard shocks recommended by Tamiya... but pretty much almost all 90-100mm shocks would work...
quote:
ORIGINAL: tamiya trucker
       Post #: 4904
RE: Return of Lunchbox.. - 7/26/2008 10:05:23 AM
tamiya trucker
Status: offline
yeah but to get the tamiya ones its like £25 for a pair so it would cost me £50
my oscar is evil...
(in reply to Lunchboxer)
       Post #: 4905
RE: Return of Lunchbox.. - 7/26/2008 12:43:25 PM
Dante77
Status: offline
Hey lbshelfqueen,
I can't really help out with your question, but I have heard nothing but bad about the carson brushless systems.
They are sensorless, cogging like mad and most of them seem to go bad after a few runs. I would suggest to have a look on some forums before you buy it.
LB brushless, Street LB, Blitzer Beetle, Dyna Blaster 2x, Bear Hawk, Frog, F101 CUDA, Hilux, Wild One, Monster Beetle 2x
       Post #: 4906
RE: Return of Lunchbox.. - 7/26/2008 2:12:47 PM
Lunchboxer
Status: offline
I am sure they are 1/2 price here in US... so maybe look at eBay or have me order it from Tower or something...
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGG67&P=Z
Less than 12GBP per set..
       Post #: 4907
RE: Return of Lunchbox.. - 7/26/2008 2:45:01 PM
tamiya trucker
Status: offline
i will look into it in the next few weeks ..i need more funds lol
my oscar is evil...
       Post #: 4908
RE: Return of Lunchbox.. - 7/26/2008 10:18:00 PM
alaskadf300
Status: offline
I know how you feel, I'm waiting to fund a couple Orion 4500mah rocket packs.
Summer-Tamiya Lunchbox/Winter-Kyosho Blizzard/Indoors-micro baja/Shelf-Tamiya Rough Rider
       Post #: 4909
RE: Return of Lunchbox.. - 7/26/2008 11:01:02 PM
lbshelfqueen
Status: offline
sometimes when i run a brushless system in my lunchbox it stutters a bit.. as if the batery is dead flat.
is this because the motor is sencing it is slightly jammed because of the low gear ratio?
would sensorless cure this?
(in reply to alaskadf300)
       Post #: 4910
RE: Return of Lunchbox.. - 7/27/2008 3:20:27 AM
alaskadf300
Status: offline
what BL system are you running in the LB?.
       Post #: 4911
RE: Return of Lunchbox.. - 7/27/2008 3:24:55 AM
Lunchboxer
Status: offline
Sensorless will be less smooth if anything else, though.... I have never had problem w/ sensored system.. for sensorless, you need good batteries..
       Post #: 4912
RE: Return of Lunchbox.. - 7/27/2008 8:25:30 PM
Dante77
Status: offline
Are you running an AM Radio on your Box? This caused serious stutter on my brushless box (Novak like yours) when reaching a certain distance.
quote:
ORIGINAL: lbshelfqueen.
