RE: Bridi UFO Build (all wood)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Bridi UFO Build (all wood)
Page: <<   < prev  6 7 8 9 10 11 12 [13] 14 15   next >   >>
Login
RE: Bridi UFO Build (all wood) - 1/31/2008 4:20:55 PM
JPBIII
Status: offline
Well after thinking about it, I believe I have built some wash in or out in the wing.
I guess I will start over. Thanks for all the great input.
After I took the wing off the board it just didn't look right.
(in reply to rainedave)
       Post #: 301
RE: Bridi UFO Build (all wood) - 1/31/2008 4:45:21 PM
rainedave
Status: offline
One more option:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK258&P=7
When using these it's helpful to tape a few sections of hacksaw blade together (the thickness of the ribs) and saw notches in your LE and TE. It helps to keep the ribs aligned and square.
David
Click to see fullsize image.
Click for fullsize
< Message edited by rainedave -- 1/31/2008 4:52:32 PM >
(in reply to JPBIII)
       Post #: 302
RE: Bridi UFO Build (all wood) - 2/1/2008 2:28:21 PM
JPBIII
Status: offline
Well I started over this time using a tapered jig to keep the ribs centerline parallel to the building board. I am much happier with the results.
       Post #: 303
RE: Bridi UFO Build (all wood) - 2/1/2008 2:37:57 PM
rainedave
Status: offline
Glad to hear that. It's worth the extra work in the long run. I don't think any computer radio can trim out wash-in in one wing panel and wash-out in the other. The good thing is now you'll never build a twisted wing again. FWIW, I learned all this the exact same way as you.
David
       Post #: 304
RE: Bridi UFO Build (all wood) - 2/8/2008 8:02:56 PM
rainedave
Status: offline
I bought a new spray gun. The $10 Harbor Freight gun was fine while I was learning to spray, but it wasted tons of material and just didn't lay down a uniform pattern. What do you expect from a $10 Chines knock-off?
Anyway, I spent some time at some of the auto refinishing forums and found out about a $75 HVLP mini-gun that has an excellent reputation. No, it's not a $300 SATA, but from everything I read it comes very close. It's made by Astro Pneumatic and it's model #4020. The best thing about it is that it's designed to operate at 4CFM or less. That's about what my small Craftsman compressor puts out at 30psi. Another nice thing is that, being an HVLP gun, most of the material ends up on the surface you're painting, not in the air as with conventional guns. That's because the nozzle pressure is only 10psi (inlet psi is set to around 40). It can spray a 4 1/2" fan which is plenty large enough for sixty-size models. I can't wait to try it out.
I also found out the hard way that it was the red lacquer auto putty that was causing my dope adhesion problems. So, I brushed a very thin coat of finishing resin over the wing fillets and the putty. I'll scuff it with some 320 and the dope should start sticking. Once I get the fuse re-painted I can start with the clear coating. The new gun should make that go pretty fast. The old Harbor Freight gun had about a 2" fan and it took forever to do a wing. But, that's ok. I'm learning as I go.
David
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rainedave -- 2/8/2008 8:05:45 PM >
       Post #: 305
RE: Bridi UFO Build (all wood) - 2/8/2008 11:28:00 PM
rcpileit-RCU
Status: offline
Okay, so where can we find these Astro Pneumatic paint guns?
George
quote:
ORIGINAL: rainedave
David
       Post #: 306
RE: Bridi UFO Build (all wood) - 2/9/2008 9:04:15 PM
LS171Malibu
Status: offline
Found it here.
http://search.cartserver.com/search/search.cgi?cartid=a-6834&category=datapaint&maxhits=20&keywords=4020-1
http://www.spraygunworld.com/products/Astro/Astro%20Pneumatic%20-%20AP4020-10-12.html
_____________________________
Blake
(in reply to rcpileit-RCU)
       Post #: 307
RE: Bridi UFO Build (all wood) - 2/10/2008 12:07:04 AM
rcpileit-RCU
Status: offline
Thanks!
I was hoping Rainedave might have had a NC source. Good old internet ordering will have to do it appears.
George
(in reply to LS171Malibu)
       Post #: 308
RE: Bridi UFO Build (all wood) - 2/10/2008 12:21:09 AM
rainedave
Status: offline
Hi George, there was an auto supply eBay Store that was selling them for $75 which is where I got mine. But, they are not selling them now. Spray Gun World is a good place.
I used mine today. WOW!!! I can't believe what I was missing by using that cheapo HF gun. It's simply a night and day difference. My 1.5hp Craftsman compressor was more than adequate. The dope was going on smooth and even. I had it set for about a 3 1/5" fan; the job goes so much faster now. I am totally happy with this gun.
David
       Post #: 309
RE: Bridi UFO Build (all wood) - 2/10/2008 12:25:33 AM
rcpileit-RCU
Status: offline
Thanks David!!
Once again knowledge is shared and lessons learned.
George
       Post #: 310
RE: Bridi UFO Build (all wood) - 2/10/2008 6:47:53 PM
mred33
Status: offline
So how about giving us the address of the guy on e-bay. He may have them posted in the future and we can get one then. Also, how about some more pictures of the new paint job so we can see how it is coming out.
Ed
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
       Post #: 311
RE: Bridi UFO Build (all wood) - 2/10/2008 7:25:29 PM
rainedave
Status: offline
Here you go Ed. It was about $9 less than any other place I found.
http://stores.ebay.com/Autobody-Supply-Express
I'll post some photos later today.
David
(in reply to mred33)
       Post #: 312
RE: Bridi UFO Build (all wood) - 2/10/2008 7:48:29 PM
rainedave
Status: offline
I decided to try out the gun on another project first to get the feel of it and learn the adjustments. I'm trying to finish up the prototype build for the new Midwest Tri-Squire kit from Early R/C Models.
Anyway, the Astro 4020 lays the dope down so smooth I can't believe it. I have complete control over the width of the fan and the amount of paint being sprayed. I know that for folks who have always used quality guns this is to be expected. I could have saved so much time and dope if I had purchased a decent gun to begin with.
Here are some photos of the little Tri-Squire I just finished painting a while ago. The wing and stab are covered with red Esaki silk.
David
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 313
RE: Bridi UFO Build (all wood) - 2/10/2008 8:39:03 PM
alcarafa
Status: offline
Dave I think your wife is going to kill you if you stain that table cover
< Message edited by alcarafa -- 2/10/2008 8:40:13 PM >
       Post #: 314
RE: Bridi UFO Build (all wood) - 2/10/2008 11:07:47 PM
mred33
