RE: Bridi UFO Build (all wood)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Bridi UFO Build (all wood)
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Bridi UFO Build (all wood) - 3/18/2006 1:46:49 PM
rainedave
Status: offline
Thanks jlkonn! I didn't have any 2" x 2" balsa blocks so using Elmer's Carpenter's Glue I clamped up two 1" x 2" blocks. This actually worked out better since the glue seam gave me a visual centerline down the side of the block. I sanded all four faces smooth and traced the tip outline onto one face of each block. Then, using Super 77, I attached the planview pattern on the top faces. I used my scroll saw to make the planview cut first. Then I cut to the shape of the airfoil. It's a little tricky since the block no longer has a flat surface to rest on the saw. You just have to hold it tightly and pivot the block as you push it through the saw. At this point I glued the blocks onto the wing. I put masking tape around the wing right at the edge of the blocks for protection. Then, using a razor plane and 100 grit sandpaper I shaped the blocks. I didn't use templates to check the profile, I just went by eye. The two things I have to look out for are not removing enough material which gives the tip a bulged look from the front; and removing too much material which would create flat surfaces on the top and botom. The tip should have a gentle curve. I have to constantly look at it head on and stop using the razor plane when I'm between those two extremes. It can then be fine tuned with the sandpaper.
The stab parts are ready to glue up. It uses an interesting method with alignment spars that fit into notches in the ribs. I laminated the spars using a strip of 1/16" sheet sandwiched between the main spar material. The LE and TE rest on blocks and the whole thing is built suspened above the board.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to jlkonn)
       Post #: 26
RE: Bridi UFO Build (all wood) - 3/18/2006 7:19:44 PM
mmattockx
Status: offline
I have an addition to this that I got from Dean Pappas, illustrious FM columnist (I think it was his, anyway). He suggested laminating two pieces of balsa, but sandwiching a piece of 1/32" ply cut to the plan view shape of tip, then shaping down to the ply, but not into it. This gives a nice centerline reference and a good hard point at the outer edge of the tip that prevents dings over time. If you also cut out the inside area of the ply it adds almost no weight and a good bit of functionality. The shaping part is still up to your eye, though...
Mark
_____________________________
Waco Brotherhood #4
(in reply to rainedave)
       Post #: 27
RE: Bridi UFO Build (all wood) - 3/19/2006 3:14:29 AM
rainedave
Status: offline
mmattockx, that is a nice idea. I wish I had known about it. Oh well, I'll know to do it next time.
The stab halves are almost done. The elevators will be next. The plans show them made of 5/8" x 2 1/4" tapered sheet. That's a pretty big piece of balsa. I'm thinking it might be lighter to build them up and sheet them. It would be easier, too, than trying to plane a uniform bevel on a sheet that large. Something to think about.
Here are a few more pics of the stab halves.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to mmattockx)
       Post #: 28
RE: Bridi UFO Build (all wood) - 3/19/2006 3:59:43 AM
rainedave
Status: offline
Ok, here's a quick drawing of how the elevators could be made.
Click for fullsize
       Post #: 29
RE: Bridi UFO Build (all wood) - 3/19/2006 4:13:57 AM
mmattockx
Status: offline
Thank you, but the credit goes to Mr. Pappas.
I really liked your method of laminating the stab LE and TE to get the alignment tab. Excellent idea and one I will remember for my Dirty Birdy build.
I could never bring myself to use that huge slab of balsa for a control surface. I would have to build them up, just to let me sleep at night. I agree with your layout, but I would skip the diagonal pieces and use 1/16" sheeting instead of the 1/8. That is just too heavy for anything but fuse sides, to my eye... I would probably skip sheeting it completely, though and simply frame them up with 1/4" sticks and leave it open bay for a film covering. I have looked at the ailerons on my Dirty Birdy plans and they even look too big to be solid and I will likely build them up if I go with a built up wing. I really like foam, though, so I may forsake tradition and do a sheeted foam core wing anyways. Ah well, decisions, decisions...
Mark
Waco Brotherhood #4
       Post #: 30
RE: Bridi UFO Build (all wood) - 3/19/2006 12:53:35 PM
8178
Status: offline
quote:
ORIGINAL: rainedav
Very nice work rainedav!
The rudder on my Tiporare was made that way and sheeted with 1/16” balsa. I added some solid balsa inside the frame at the bottom so I had a place to install the control studs. It is very light and has worked out well.
       Post #: 31
RE: Bridi UFO Build (all wood) - 3/19/2006 2:26:57 PM
rainedave
Status: offline
Thanks guys! Now that you say it, mmattockx, 1/8" is overkill. I've redrawn the elevators using 1/16" sheeting. 8178, I might just go ahead and build up the rudder as well using the same method.
Click for fullsize
(in reply to 8178)
       Post #: 32
RE: Bridi UFO Build (all wood) - 3/19/2006 4:36:32 PM
rainedave
Status: offline
I went ahead and whipped up a drawing for the rudder. I'll still use 1/2" sheet for the fin.
Click for fullsize
< Message edited by rainedav -- 3/19/2006 4:39:25 PM >
       Post #: 33
RE: Bridi UFO Build (all wood) - 3/19/2006 11:55:22 PM
rainedave
Status: offline
The elevators were a snap, and I'm sure they weigh a lot less than the solid boards shown on the plans. I capped the ends with 1/32" sheet to make them look a bit neater.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 34
RE: Bridi UFO Build (all wood) - 3/20/2006 12:07:53 AM
jlkonn
Status: offline
Dave...
Do you like do this professionally?
JLK
A goal without a plan is just a dream.
AMA 97605
       Post #: 35
RE: Bridi UFO Build (all wood) - 3/20/2006 12:37:31 AM
roncoleman
Status: offline
Rainedav
My hat is off to you. You are one fast scratch builder. Outstanding
work also. I understand why JLK put the question to you.
< Message edited by roncoleman -- 3/20/2006 12:38:38 AM >
       Post #: 36
RE: Bridi UFO Build (all wood) - 3/20/2006 3:39:48 PM
rainedave
Status: offline
Wow, thanks for the very nice comments, both of you. I've only built a few planes for other flyers and I have to say, it wasn't all that enjoyable. Besides, if one of my models blew apart in some outside maneuver, I'd feel somewhat responsible for any damage it might cause.
Since I was in the groove of building up the elevators, I went ahead and made the rudder. It is very light and extremely rigid. I used the drawing I posted above.
Click for fullsize
(in reply to roncoleman)
       Post #: 37
RE: Bridi UFO Build (all wood) - 3/31/2006 9:44:00 PM
rainedave
Status: offline
I've started work on the fuselage. The top block and sides are about ready to be glued together. The plans show two hefty, long hardwood engine mounting rails and they add a lot of rigidity to the front of the fuse. Since I'll be using a nylon engine mount on the firewall I decided to add conventional lite-ply side doublers from just behind the wing saddle to the nose. Everything else will be built according to the plans.
Click for fullsize
Click for fullsize
       Post #: 38
RE: Bridi UFO Build (all wood) - 3/31/2006 11:12:09 PM
Roary m
Status: offline
