rainedave -> RE: Bridi UFO Build (all wood) (9/12/2006 2:53:15 AM)
I got a lot more glassing done this evening. I'm almost done. Just one more session for the fuselage. I still need to glass the nose around the engine cut-out and I want to add two strips along the back of the fuse between the stab and the fin. You can see the bare wood on that area in one of the pics. I don't really think there's any need to glass the fin. I'm just going to coat it with epoxy resin to seal the wood for the primer. It's solid balsa whereas everything else, including the rudder and elevators, is hollow. I'll also paint resin inside the engine bay and nose gear retract area. Considering I haven't glassed in ages I didn't have too much trouble. Mainly I was afraid I'd screw something up. I don't know how you undo glassing mistakes. I assume you just re-build the entire ruined part. So, that kept me on my toes. You better have a plan laid out, too, because you don't have time to stop and figure anything out or cut a new piece of fiberglass. I used z-Poxy finishing resin and Sig 3/4oz cloth. I'm not familiar with other products, but I will say that the Z-Poxy sands very easily. It hardly clogs the sandpaper and I was using 220. I image 80 or 100 would cut right through the cloth. The section from the back of the wing saddle to the fin got two layers of glassing. I had sanded some areas very thin when shaping the corners. I'm confident that it's strong enough now. What really surprised me is how little weight the glassing added. I was careful to wipe off as much resin as I could while it was wet, but still, I expected it to add more weight than it did. The rudder, which is built up and sheeted with 1/16" balsa, is hardly any heavier than it was. The next stage is to make the wing fillets and fairings at the stab and fin. I'm glad I glassed before adding these. It will be a lot easier to add them now, than trying to glass over them. Concave curves are a pain to glass. I'm really looking forward to shooting the primer. Hopefully by this weekend.
