rainedave
NC, USA Status: offline
Hi Digger44. First, your Extra looks beautiful. Awesome building! I wish I had thought to paint a sq. foot of Koverall as a sample. I will do that this week. Your info on Koverall and Monokote matches the charts I've found online: http://www.fatlion.com/sailplanes/weights.html http://webpages.charter.net/rcfu/HelpsHints/IOCWeight.html http://www.modelflight.com/weight.html I do know from my own experience that dope is an extremely light finish, especially when used on silk. I doubt there is any way that dope could add pounds of weight to a 27% model. But, like you said, there are a lot of variables in painted finishes. Looking at those charts I'm estimating that Koverall and dope would weigh maybe 4 or 5 grams more per sq foot that opaque MK. I don't know what the overall surface area of your model is, but on 5000 sq inches of surface area that would be about a 5oz to 6oz difference, if my math is correct. Clearly, Koverall is heavier than silk and dope, which is lighter than Monokote. It's a shame Japanese Esaki silk is so darn expensive, although some people use Thai silk which is a lot more affordable. Based on the wing area of your Midwest Extra (1162), adding 5ozs to the overall weight adds .62ozs to the wing loading. I don't think I would be able to "feel" that difference in flight. When you factor in wind, temperature and fuel differences I doubt it could possibly be noticed. Personally, the Koverall/dope route is more than worth the weight gain. The finish will not sag, wrinkle, bubble or peel up over time like every Monokote job I've ever done has. Granted, I'm not very good at using iron-on coverings. You probably don't encounter those problems. Plus, you will have a model that will look unique and really stand out at the field. Thanks, David
