mglavin
CA, USA Status: offline
quote:
ORIGINAL: tail strike Michael, When using my HFP-10 and set the center at 0 some of my HS 5645MG servos you can't put the servo arm on the output shaft and have the arm 90% to the servo case. It will be off just a little. I am wondering if I can take the top of the case off and rearrange the gears so the servo arm will be 90% to the case? I know you will say just adjust it with the programmer till it is centered. I have done that but when I put the servos in my plane one on each half of my elevator they will travel in sink from center up to the end point, but from center down one side travels a little faster than the other side and goes a little farther down than the other. Please help I'm going bald. For best results talk to the paw I'm a little confused, are you programming the servo to 90* perpendicular to the case with the arm in place that’s being used in the model or utilizing a different arm? Something that typically is realized after programming the servos for neutral is the realization that their TX does not output the `1500us control signal at neutral, therefore the servo does not center as programmed simply because the signals differ. The fix is to learn what it takes to accommodate the TX output and program accordingly. To start with make sure the TX sub-trim and trims are zeroed and that the TX ATV/EPA's are equal in both directions in all rates. Chances are the model and or TX setup is the source of the unequal surface deflection. Slight variables realized in model construction, control arm placement and pivot point height and linkage cause this problem atypically. I'd suggest that you validate the surfaces travel arcs are identical to ensure equal throw. This is done with the linkage in place and attached to the servo while moving the surface through its travel arc manually. You'll need a 4" photo copied protractor that is taped in place and centered on the servo output shaft and a device to measure surface throw. The goal is to realize equal servo arm angle and equal surface throw in either up/down direction. You will not realize equal percentages between the two as the linkage ratio will prevent same. Some patience will be required initially but once you understand the methodology its all good. When its all said and done more likely than not you’ll find that when equal throw and servo arm angles are realized the servo arm is NOT 90* perpendicular to the servo case, it matters not as this is the true center of the surface travel arc, which is our primary concern.
_____________________________
Michael Glavin RCU Community Moderator Hitec * Multiplex Field Representative
