Help! brakes and throttle???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Help! brakes and throttle???
Page: [1]
Login
Help! brakes and throttle??? - 3/12/2006 5:55 AM
Noob2Nitro
Score: 100
Last Login: 9/14/2006
Status: offline
I just got back into Nitro. The last car I ever had was a Turbo Burns, YEARS ago! So basically, I am a NOOB. I don't remember how to set the motor up now. It runs but when I apply the brakes, it closes down the carb, shutting the engine off. Any tips? Please help, I wanna play!
_____________________________
Drive & stay alive! www.topspeedtoys.com
Hide Signatures
       Post #: 1
RE: Help! brakes and throttle??? - 3/12/2006 6:03 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
you need to leave the throttle in the nuetral position, then adjust the carb so there is about 1mm opening on the carb. make sure though that your in the neurtral position on the transmitter.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to Noob2Nitro)
       Post #: 2
RE: Help! brakes and throttle??? - 3/12/2006 6:20 AM
jeeperscreapers
Score: 100
Last Login: 6/26/2006
Status: offline
i actually had to adjust my carb with the brake applied instead of in neutral, bcus the carb was closin when i hit the brakes and not reopening in neutral
Savage X , Sure Fire . 32 , Hot-Rod Pipe , Escalade body , HEAVY Mods for HEAVY Bashing
Hide Signatures
(in reply to ehroof)
       Post #: 3
RE: Help! brakes and throttle??? - 3/12/2006 6:25 AM
Noob2Nitro
Score: 100
Status: offline
It's kinda weird. It's like, in neutral and carb is open 1mm but when I push the trigger forward, it closes the carb all the way.
Hide Signatures
(in reply to jeeperscreapers)
       Post #: 4
ehroof
Score: 105
Status: offline
sounds like you have to reverse the servo's on the tranmistter, there should be a switch on the transmitter. When you appy throttle it brakes and shuts down, when you apply brakes, the carb should open up if this is the problem.l
Hide Signatures
       Post #: 5
RE: Help! brakes and throttle??? - 3/12/2006 6:49 AM
Noob2Nitro
Score: 100
Status: offline
Hm, throttle servo is set to normal. When I squeez the trigger, she goes. When I push it up to apply the brakes it closes the carb so much that no air can get in
Hide Signatures
       Post #: 6
RE: Help! brakes and throttle??? - 3/12/2006 6:52 AM
ehroof
Score: 105
Status: offline
you need to open the idle screw more, it shouldnt go low enough to stop the idle. turn clockwise until when you apply the break it doesnt stall. your transmitter is fine.
Hide Signatures
       Post #: 7
RE: Help! brakes and throttle??? - 3/12/2006 6:53 AM
Noob2Nitro
Score: 100
Status: offline
Ok, I'll try now!
Hide Signatures
       Post #: 8
RE: Help! brakes and throttle??? - 3/12/2006 7:19 AM
Noob2Nitro
Score: 100
Status: offline
Can you check this photo I put up? You can see inside the carb. Also, is the Idle screw the black philpps head you see near the opening?
http://www.ubpaa.com/CAR.JPG
Hide Signatures
       Post #: 9
RE: Help! brakes and throttle??? - 3/12/2006 8:22 AM
Noob2Nitro
Score: 100
Status: offline
YAY!, I got it, I just forgot how to do this stuff. Thanks for pointing me in the right direction.
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
