No Luck With Camcorder
Tower Hobbies
Logged in as Guest
  Printable Version
Miniature Aircraft USA Ion-X - RTF
Seller:  1surfer
Details:   $5,000.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> No Luck With Camcorder
Page: [1]
Login
No Luck With Camcorder - 12/6/2002 9:10:28 AM
RADIOFLYERDAVE
Status: offline
BOUGHT A SMALL VHS-C CAMCORDER TO MOUNT ON MY 90'' SPAN AIRPLANE. IT HAS AN OS108 ENGINE. WHEN I TRIED IT FOR THE FIRST TIME I USED 3 LAYERS OF 1/2'' LATEX FOAM FOR INSULATION FROM VIBRATION. STILL, THERE SEEMED TO BE A HIGH FREQUENCY VIBRATION. NOT A SHAKE LIKE YOU MIGHT EXPECT, BUT A WAVE IN THE PICTURE THAT CHANGED WITH THE SPEED OF THE ENGINE. ANYONE HAVE SOME IDEA WHAT I SHOULD DO, OR DO I JUST NEED TO FORGET THIS IDEA?
_____________________________
DAVID EDWARDS
       Post #: 1
Re: No Luck With Camcorder - 12/6/2002 9:15:21 AM
Forgues Research
Status: offline
[QUOTE]Originally posted by RADIOFLYERDAVE
BOUGHT A SMALL VHS-C CAMCORDER TO MOUNT ON MY 90'' SPAN AIRPLANE. IT HAS AN OS108 ENGINE. WHEN I TRIED IT FOR THE FIRST TIME I USED 3 LAYERS OF 1/2'' LATEX FOAM FOR INSULATION FROM VIBRATION. STILL, THERE SEEMED TO BE A HIGH FREQUENCY VIBRATION. NOT A SHAKE LIKE YOU MIGHT EXPECT, BUT A WAVE IN THE PICTURE THAT CHANGED WITH THE SPEED OF THE ENGINE. ANYONE HAVE SOME IDEA WHAT I SHOULD DO, OR DO I JUST NEED TO FORGET THIS IDEA? [/QUOTE]
First off, your problem is the vibration is getting to the taping head. You don t have this problem when you tape on the ground from a camera with a downlink.
This is what I did.
http://www.geocities.com/roger_forgues/carrier.html
Evo Engines
http://forgues-research.com
(in reply to RADIOFLYERDAVE)
       Post #: 2
No Luck With Camcorder - 12/6/2002 11:32:02 PM
FLYBOY
Status: offline
We had the same problems with vibration with the camera in flight. Can't wait to do it with the remote camera. Gotta get a new digital video camera first. Think I am going to get the Sony Digital 8. Looks like a nice camera.
Fly it till the wings come off.
       Post #: 3
No Luck With Camcorder - 12/7/2002 12:13:05 AM
SeismicCWave
Status: offline
From my understanding it has something to do with analog video tape head. You can resolve the problem by using a digital video camera. I did that with a video camera on a gas powered helicopter.
       Post #: 4
Go Wireless!!! - 12/8/2002 8:08:03 PM
bigE
Status: offline
I built my cam based on the below web site. The cost is under two hundred dollars, and you get the satisfaction of building the system. Its really not hard at all. Pictures are as good as my camcorder. runs on a 4.8 volt seperate receiver pack. The really cool part is I found a combination 13" TV/VCR at radioshack that can also plug right into a cigarette lighter, so you can watch the feed from your plane real time!!! (No, I havent tried flying while watching the TV yet) Justified it with the wife by saying it was for Our son to watch movies on long trips in the car
Website:
http://www.rc-cam.com/rc-cam4.htm
Camera.. servo added for size comparison
Click to see fullsize image.
Click for fullsize
       Post #: 5
No Luck With Camcorder - 12/18/2002 9:40:00 PM
lvspark
Status: offline
I do not think it is a recording head issue alone. It occurs on some of my videos, and I have the recorder on the ground. I think it is a harmonic vibration. There seems to be a relationship between the engine rpm and the cameras frame rate like you are describing. I am curious if your prop was in the picture? you may want to try a different mounting location. I know it would be hard to balance, since you are moving such a big object, but my videos with the camera further off the centerline seem to be less prone to this wave effect.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.766RCU1
