bigdsti
CO, USA Status: offline
I'll still send the Optic back after the new unit comes in. When I was taking it apart last night I left it on to see if there were any loose connections I could jostle around. Nothing. There's no loose wires or connections anywhere, not even in the battery pack. I think the problem is that the circutry was registering *too high* of a voltage. When it was on, it would register the pack at 11.1 or 11.2v (freshly charged), then start kicking on and off and flipping out. Now when I turn it on (after draining the pack a bit), it's down to 10.X volts and it's working perfectly. My NiCd pack will register at 11.X voltages when freshly charged, so (many months ago) I tried plugging in a slightly drained LiPo to see if it would work because I was in a pinch for time, and it did the exact same thing... The power light came on, but nothing functioned, and the LCD screen didn't work. I think the voltage was slightly too high for the unit to function properly. I know a freshly charged NiCd pack will have a higher-than-normal voltage, and I think that's the culprit, something on the board is somehow overly sensitive to a fully charged pack, and anything higher than 10.X volts.. I'll try to recharge the pack tonight and see if the problem repeats itself, if so, bingo. (Frustrating, but still bingo.)
