Minimum take off distance
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> Minimum take off distance Page: [1]
Login
Minimum take off distance - 3/15/2006 4:35:02 AM
wvarn1957
Status: offline
This may not be the correct forum for my question, but I'll start here. Our club is in the process of developing a new field. In addition to grass and concrete runways, we are going to begin digging a pond for float planes. Our present plan is 400' X 50' by 1'deep. I would appreciate any input on whether or not this will be adequate.
_____________________________
W W Varnado
       Post #: 1
RE: Minimum take off distance - 3/15/2006 4:43:09 AM
Chip_Mull
Status: offline
Make it deeper wider and longer.
Let's launch, first one up takes lead and we'll brief on Guard!
(in reply to wvarn1957)
       Post #: 2
RE: Minimum take off distance - 3/15/2006 5:15:24 AM
TEAMERICA
Status: offline
Yup, you might get by chincing on the deep part but unless you are the National Spot Landing Champion, you can never have enough surface area. The consequences of overshooting or missing the bull's-eye are breakage. Plus, float planes are notorious for hooking on either take-off or landing and you will quickly find yourself pointing in a different direction than you started.
It would be easier to build a runway next to a lake rather than the other way around.
Logic will not be tollerated!
Revver Brotherhood #141
       Post #: 3
RE: Minimum take off distance - 3/15/2006 4:08:56 PM
britbrat
Status: offline
400' long is not overly generous, but will work in many cases. However, 400' wide would be a much better idea.
< Message edited by britbrat -- 3/15/2006 4:10:20 PM >
(in reply to TEAMERICA)
       Post #: 4
RE: Minimum take off distance - 3/16/2006 12:13:22 AM
JimCasey
Status: offline
When you get a crosswind, 50 feet would be challenging for landing. Every time I was in Houston, it was windy. 1' deep means that you'll expose the bottom whenever there's a dry spell.
Taking off is not the problem. you can start really close to the bank. Landing takes some space. Some airplanes just like to sail along forever in surface effect.
< Message edited by JimCasey -- 3/16/2006 12:16:17 AM >
Jim Casey/Seaplane Nerd
http://www.smilesandwags.com/Floats.html
(in reply to britbrat)
       Post #: 5
RE: Minimum take off distance - 3/16/2006 1:00:11 AM
cyclops2
Status: offline
ALL the REAL pilots put a epoxy coating or clear adhesive plasticsheet on the bottom for those times when you HAVE to land in a lot stronger wind than you took off in.
Land on the GRASS area ANYTIME. Different but it works. For my China Clipper flying boat.
High legged float plane.? Not to sure even with fast flat landing.
(in reply to JimCasey)
       Post #: 6
RE: Minimum take off distance - 3/16/2006 3:25:55 AM
JimCasey
Status: offline
>>Real<< Pilots can land where they intend to land.
(insert sound of Tim Allen making macho grunting noise)
(in reply to cyclops2)
       Post #: 7
RE: Minimum take off distance - 3/17/2006 12:34:18 AM
lupy
Status: offline
I would think 300X75 would be better in most cases, Depends a lot on what you are planning on flying. Asuming your club can stand the thought, it might make $$ sense to make it big enough for some boat races and increase the membership, and or rend the pond to another club. At least around here, it's getting hard to find a place that will allow loud boats.
       Post #: 8
RE: Minimum take off distance - 3/17/2006 12:34:42 AM
wvarn1957
Status: offline
Thanks for your input. We have modified plan to increase the length to 500' long and 75' wide. However increasing the water depth beyond 1' isn't fesable.
thanks
W W Varnado
       Post #: 9
RE: Minimum take off distance - 3/17/2006 2:52:50 AM
sebo
Status: offline
Just curious. Is the pond going to be concrete or is it going to be lined with a plastic of sorts?
       Post #: 10
RE: Minimum take off distance - 3/17/2006 3:23:29 AM
wvarn1957
Status: offline
Lupy,
loud boats wouldn't be a problem. The site is a 20 acre dry bottom retention basin and the nearest residential area is more than 2 miles away. It is also adjacent to a light industrial area and a drinking water resivoir. No chance of any residential areas ever be built any closer than about 1 1/2 miles.
Interesting though, even though the Houston area has a lot water around there soes not seem to be a lot of model boating. Maybe I'm just not aware of it.
Sebo,
Initially the pond will just have a clay bottom. when we have finished the development of the "land based" field, we'll see how much money we have left. Concrete is out of the question $$$$ so we will probably go with a 35 mil polyethylene liner. That will have to wait a while probably.
< Message edited by wvarn1957 -- 3/17/2006 3:24:31 AM >
W W Varnado
(in reply to sebo)
       Post #: 11
RE: Minimum take off distance - 3/18/2006 2:41:50 PM
5487
Status: offline
wvarn1957,
< Message edited by 5487 -- 3/18/2006 2:44:30 PM >
       Post #: 12
RE: Minimum take off distance - 3/18/2006 2:43:10 PM
5487
Status: offline
wvarn1957,
What side of Houston will y'all be building your pond?
H5487
Houston - West side
       Post #: 13
RE: Minimum take off distance - 3/18/2006 2:55:50 PM
wvarn1957
Status: offline
5487,
The field is located near the intersection of Red Bluff Road and Genoa-Red Bluff Road in Pasadena.
W W Varnado
(in reply to 5487)
       Post #: 14
RE: Minimum take off distance - 3/18/2006 3:05:20 PM
5487
Status: offline
That's close to where I work (LaPorte.)
       Post #: 15
RE: Minimum take off distance - 6/30/2006 9:19:48 PM
Pilotx1
Status: offline
why cant you go deeper than 1foot?
(in reply to 5487)
       Post #: 16
Page:   [1]
Page: [1]
