RE: KMP / YT Me 109 E Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP / YT Me 109 E Build Thread
Page: <<   < prev  76 77 78 79 80 [81] 82 83 84 85   next >   >>
Login
RE: KMP / YT Me 109 E Build Thread - 11/14/2012 4:48 PM
Dave Bugz
Score: 100
Last Login: 5/23/2013
Status: offline
To me 16.2lb seems heavy, mine comes in at 14lb. I changed the wooden dale pushrod for a carbon one, far less Flex. What servos are you using? If the problem occured exiting a dive it could be that either the servo was not "strong" enough to hold the elevator, the dale Flexed not allowing enough elevator.
Just a thought
Dave
Hide Signatures
(in reply to w1nd6urfa)
       Post #: 2001
RE: KMP / YT Me 109 E Build Thread - 11/17/2012 7:19 AM
w1nd6urfa
Score: 100
Last Login: 5/21/2013
Status: offline
Hi Dave, thanks for your reply
14 lbs is my goal for the re-build, I will use lighter wheels and will move the batteries to balance without nose weight
Elevator pushrod: the previous owner is a very respected scratch builder, as you can see in the pics there was a piece of wood used as a guide at the front end, there could ofcourse be some flex at the other end?
I will also use carbon pushrod in the re-build
Servos are JR DS 589 digital, strong stuff
Still puzzled ...
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
A designer knows he has achieved perfection when there is nothing left to take away (Antoine de Saint-Exupery)
Hide Signatures
(in reply to Dave Bugz)
       Post #: 2002
RE: KMP / YT Me 109 E Build Thread - 11/17/2012 7:55 AM
Brad330l
Score: 140
Status: offline
hi w1nd6urfa, did you have to use full up elevator to complete your loop and cuban? It could be high speed snapping/stalling.
The lack of gear door would not effect the wing too much to the point of what you describe I think, but get them on ,,, they look great
I still love flying mine but am now waiting on new RX batteries before more of it.
Good luck with the repairs,
Brad
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
       Post #: 2003
RE: KMP / YT Me 109 E Build Thread - 11/17/2012 8:09 AM
w1nd6urfa
Score: 100
Status: offline
Hey Brad
I can't be 100% sure of course, but I don't believe I used full up as it was only the 4th flight and I was still being gentle on the controls. What I do remember is that when it snapped I instictively let go of the controls to let it stabilise on its own as it still had altitude ... it proved to be not enough!
I've been inspecting the crash damage and it revealed some structural issues that I will be tackling in the re-build. I will post pics for your comments.
Cheers
Nick
Hide Signatures
(in reply to Brad330l)
       Post #: 2004
RE: KMP / YT Me 109 E Build Thread - 11/17/2012 6:04 PM
Dave Bugz
Score: 100
Status: offline
hi w1nd6urfa, sorry to go on but with the wooden dales if you hold the rod and push the elevator there will definately be movement, i have a wooden one on the rudder and carbon on the elevator and there is definately a big difference.
The JR DS 589 digital on the elevator for a plane weighing 16lb is OKish ? but with the flex in the rod, there will be a lot of force on the elevator exiting a dive. All other surfaces will be OK as they wont be loaded as much as the elevator.
Good luck with the rebuild.
Dave
Hide Signatures
       Post #: 2005
RE: KMP / YT Me 109 E Build Thread - 11/18/2012 6:44 AM
w1nd6urfa
Score: 100
Status: offline
Since I will be repairing the horiz stabs what I could do is install 2 mini servos in the stabs, 1 for each elevator. I have done similar mod in the ESM B-25 and has worked fine - been flying it hard over 1 year.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2006
RE: KMP / YT Me 109 E Build Thread - 11/18/2012 12:29 PM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: w1nd6urfa
I don't recommend this surfa. Keep the weight up the front and just change that dowel out for a carbon arrow shaft and all should be good. This model needs to be kept light and there is no way I see you will be able to put it on a diet if you put servos in the tail.
I use an arrow shaft and it works fine.
Cheers,
Brad
Hide Signatures
       Post #: 2007
RE: KMP / YT Me 109 E Build Thread - 11/18/2012 5:07 PM
kahloq
Score: 125
Status: offline
Sorry, but I cleary will disagree with Brad330l. I have two of these ME-109's and they can fly quite well with weight. One of them is glow(saito 180) and the other is electric power 110. On the electric one, I put a scale tail wheel assembly at the rear plus the AUW is higher simply due to the battery weight then the saito 180 glow one. Both fly just fine. The glow one is around 13.5 pounds and the electric one is closer to 15.5. It lands just fine, no issues and in fact is easier to fly.
So...windsurfa...your idea to use two small servos in the horiz stab is just fine. Might require you to move more stuff forward, but quite doable. This airframe can take a lot of weight up front without detriment.
Hide Signatures
       Post #: 2008
RE: KMP / YT Me 109 E Build Thread - 11/20/2012 9:18 PM
Biggles2
Score: 100
Last Login: 5/6/2013
Status: offline
Can anyone tell me what brand of paint KMP /YT use on the me109
Hide Signatures
(in reply to kahloq)
       Post #: 2009
RE: KMP / YT Me 109 E Build Thread - 11/21/2012 1:06 AM
Redback
Score: 115
Last Login: 5/24/2013
Status: offline
Biggles
Doubt you will find the brand. I needed to match after ripping out a retract so I took a piece of covering to the local hardware store to paint match a water base paint. Even with a clear coat on top came out OK
Terry
Hide Signatures
(in reply to Biggles2)
       Post #: 2010
RE: KMP / YT Me 109 E Build Thread - 11/21/2012 9:37 AM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: Biggles2
I'll tell you one thing it is not and that is Warbird Colours!!!!!
My match was terrible !! But not to care, it was underneath so not noticeable on the ground and in the air,,, well I don't care. Close enough. (not really )
Brad
Hide Signatures
       Post #: 2011
RE: KMP / YT Me 109 E Build Thread - 11/21/2012 2:28 PM
glazier808
Score: 291
Status: offline
I'm pretty sure ModelMasters RLM 66 matches the dark grey. That's the only one I found though.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 2012
RE: KMP / YT Me 109 E Build Thread - 11/22/2012 4:02 AM
kahloq
Score: 125
Status: offline
Ive had no problem getting colors match perfectly at my local Home Depot. I take a piece of the plane in that has the color on it and bam...put it under the scanner and 2 mins later ive got a sample size amount needed. If for some reason the color doesnt come out just right they will adjust it for you and/or run another scan twice more if required.
Hide Signatures
(in reply to glazier808)
       Post #: 2013
RE: KMP / YT Me 109 E Build Thread - 12/3/2012 8:57 PM
okie52
Score: 100
Last Login: 3/20/2013
Status: offline
Started on a KMP 109 ARF 5 years ago and its been sitting ever since. I've got a lot of reading to do on this thread.
Hide Signatures
       Post #: 2014
RE: KMP / YT Me 109 E Build Thread - 12/4/2012 7:12 PM
Asanders
Score: 105
Status: offline
I inadvertently snap rolled mine at high speed. Fortunately I had some altitude and was able to recover in time. Scared the crap out of me. I usually make graceful turns and climb outs but this one time I pulled back on the stick too much and too quickly and she did an awesome snap roll, would have been awesome had I planned it. But when that happens when you didnt mean to! Lesson learned.
Oops !!
Hide Signatures
(in reply to okie52)
       Post #: 2015
RE: KMP / YT Me 109 E Build Thread - 12/4/2012 7:26 PM
okie52
Score: 100
Status: offline
Heh...Think you can duplicate it?
Hide Signatures
(in reply to Asanders)
       Post #: 2016
RE: KMP / YT Me 109 E Build Thread - 12/5/2012 4:15 AM
Asanders
Score: 105
Status: offline
I am sure I could not sure I want to, I like my 109 too much hehe.
Oops !!
Hide Signatures
       Post #: 2017
RE: KMP / YT Me 109 E Build Thread - 12/5/2012 3:27 PM
loukos
Score: 100
Status: offline
Here is my YT/ESM/KMP BF 109. Powered by a laser 150, robart retracts
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2018
RE: KMP / YT Me 109 E Build Thread - 12/5/2012 10:04 PM
okie52
Score: 100
Status: offline
I don't blame you.
Hide Signatures
       Post #: 2019
RE: KMP / YT Me 109 E Build Thread - 12/5/2012 10:07 PM
okie52
Score: 100
Status: offline
quote:
ORIGINAL: loukos
Really nice looking. Hope to have mine ready to go by this spring. I'm going with a Saito 180. How have you liked your laser's performance on the 109?
Hide Signatures
(in reply to loukos)
       Post #: 2020
RE: KMP / YT Me 109 E Build Thread - 12/6/2012 1:13 AM
Redback
Score: 115
Status: offline
Hi Loukos,
Like Okie interested to hear how you are going with the Laser. Got one in mine, it hauls it OK but would like a bit more power up my sleeve. Motor is still quite new though and still experimenting with props.
Terry
Hide Signatures
       Post #: 2021
RE: KMP / YT Me 109 E Build Thread - 12/6/2012 10:23 AM
loukos
Score: 100
Status: offline
Guys, thanks for the kind words. The laser is ok, not a power house, I think I over propped mine (16x8), had a bit of an accident on the maiden takeoff, ran off the runway and clipped some shrubs, which broke the rudder..so hasn't flown as yet...I will be using a 15x8 for subsequent flights as recommended by Neil Tidey
Hide Signatures
(in reply to Redback)
       Post #: 2022
RE: KMP / YT Me 109 E Build Thread - 12/9/2012 5:56 AM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: loukos
Hi loukos, is your engine well run in or a new one? Nice engine choice by the way. The smaller prop will defiantly be the go for initial run-in. My Saito 150 loves 16x8 props and I have even run a 17x8 with much lower revs but still acceptable power. It is however much happeir on a 16x8 and well run in.
Maybe after a bit of running your will be fine on 16/8.
With my '109' I got a couple of pretty eventful flights in last week end with two engine failures and subsequent dead stick landings. I think the engine was a bit lean on flight #1 although performing well with lots of smoke but after a sustained climb it cut out. Oh dear, Ok tracked straight to a down wind leg, gear down and don't go too far down wind, no flaps required, keep the nose down, bugger, going to drop short into the scruffy stuff, ease back on the elevator to slow it down,,,,, and it kept on gliding!!!!!! Right to my feet to a three pointer. FEWWW.
So I richened the needle a good couple of clicks and once again engine sounded great so off I go again and having a nice time of it when it was inverted time and ,,,Konck!! Another dead engine!!! Same thing as before except this time (after forgetting to recharge my tiny retracts air tank)
I only had the left main come out. This approach was better and it gave me time to think about keeping the dead leg up while on the touch down but even though I tried it sunk down pretty quickly and nosed up all within about 4 meters and then had the audacity to pop the other leg out and sit perfectly on it's nose. Oh man what have I done??? I quick check revealed no damage except for a bent gear cover. I didn't even break the prop.
Once home I pulled it all apart and did some 'deep maintenance', checking all out. I gave the gear legs a good work over and found that my short mounting screws had de-laminated a section of ply mount. Easy fixed with some resin and longer screws that go all the way through the mount.
One tiny little crack in the rear fuselage (I could have done with my thumb at another time) was 'ZAPPED' and wiped and that was it. Ready to go again after some serious engine tuning. Oh, with the wing off I was able to check that the tank clunk had free movement and it was OK.
All good fun, Cheers,
Brad
Hide Signatures
       Post #: 2023
RE: KMP / YT Me 109 E Build Thread - 12/9/2012 3:21 PM
glazier808
Score: 291
Status: offline
Now that's just the reason I go electric
Glad she's still in good shape Brad, although a little bird told me you have another "Emil" in your life now.
LOL
Casey
Hide Signatures
       Post #: 2024
RE: KMP / YT Me 109 E Build Thread - 1/7/2013 1:56 AM
Redback
Score: 115
Status: offline
Fitted the wheel covers to mine the other day. When they are lined up to fit the wells with the wheels up they take on a very unstreamlined postion with the wheels down!
Have others noticed this (can't see any other way to fit) and if so does it have any major effect on performance with wheels down? The covers must case some extra drag, would appreciate any comments on the effect on flight performance.
Terry
Hide Signatures
       Post #: 2025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
