DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: offline
quote:
ORIGINAL: Flyboy Dave The rubber shielded bearing is always superior to the metal shielded, or the plain ball bearing. Dave, There are several engine manufacturers that don't necessarily see things as you do. Webra and Rossi are among them. They use a front bearing that is neither shielded, nor sealed. It is a fully open bearing that has nothing to seal the fuel/air/oil inside the crankcase. It is the crankshaft's job to seal the crankcase. A bit strangely, the front bearing in these engines, although open, is not even more susceptible to dust, sand, other FOD than are sealed and shielded bearings, in other engines... If the engine's manufacturer thought his engine was designed too loose to use open bearings (...), do use a bearing with the same type of seal/shield as the original. If your engine had an open bearing, I would not recommend substituting a sealed bearing for it. If anything, the engine's designers knew a thing, or two about this engine, to select the right type of bearing. Don't second guess them.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
