Hangar Nine P-51
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> Hangar Nine P-51
Page: [1]
Login
Hangar Nine P-51 - 12/8/2002 6:24:25 AM
IRAW50
Status: offline
HI OTTO, I am building the hangar 9 P-51 mustang and i want to use a 4 blade prop, what engine -prop combinatio do you suggest. thanx ... IRA
       Post #: 1
Hangar nine P-51 - 12/8/2002 6:42:44 AM
Otto Kudrna
Status: offline
I am not familiar with the kit. Please give me some specifications to work with. But in any case I will only recommend a 4 blade prop, if you back me up against the wall. The reason being, because they are very inefficient. In general, performance really stinks with them. You will always be better off turning a 2 blade prop in scale diameter. Remember, you cant see the blades when they are turning, but you can see the prop arc. when it is sitting on the ground just put on a dummy prop.
Otto Kudrna, RCV Tech Support Americas
(in reply to IRAW50)
       Post #: 2
Hangar Nine P-51 - 12/8/2002 6:49:12 AM
IRAW50
Status: offline
the kit is an "ARF",65.5"wingspan.55.7" fuselage,745 sq. in wing area,7-8.5lbs wgt.rec eng.60-.78 two stroke,.72-1.0 fourstroke, what would be the most appropriate of rcv engines to use
       Post #: 3
Hangar Nine P-51 - 12/8/2002 6:58:14 AM
Otto Kudrna
Status: offline
The RCV 90-SP would be the perfect engine, turning a Zinger 18x14 two blade cut down to 16 inches. This should give you enough ground clearance and enough prop area to move the airplane very nicely. The engine would be turning in the mid 4000 range with this prop and the correct fuel.
Thank You
Otto
       Post #: 4
great!! - 12/8/2002 7:01:20 AM
IRAW50
Status: offline
OTTO, thanx for the fast reply ,just the info i was looking for..IRA
       Post #: 5
Hangar Nine P-51 - 12/8/2002 9:49:23 PM
Otto Kudrna
Status: offline
Happy To Help
Otto
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.547RCU1
