RE: Monster GT anyone have one?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Team Associated - Monster GT >> RE: Monster GT anyone have one?
Page: <<   < prev  279 280 [281] 282 283 284 285 286 287 288   next >   >>
Login
RE: Monster GT anyone have one? - 8/26/2007 3:50 PM
scottywilkes
Score: 100
Last Login: 4/26/2009
Status: offline
put it this way, ive taken a few upside down landings, taken a 20 metre tumble down a steep hill, a few nosedives, a few rear enders, a few t bones, ALOT of wheelies and its still holding up AWESOME!
_____________________________
8ightT:Go21, MBX5R:RBC6, FT NTC3:RBC12, 8000kv RC18T, MGT:M427, F103, NEVST, FASST 2.4, Spek 2.4
Hide Signatures
(in reply to Evader ---> MGT)
       Post #: 7001
RE: Monster GT anyone have one? - 8/26/2007 8:38 PM
Snaut Rocket
Score: 100
Last Login: 5/26/2010
Status: offline
congrats guys we just broke 7000 post
And duck up does the zombies fit directly on to the 23mm size wheels. Cause im going to get them in stead of the big joes becuse they are cheaper.
Lots of holes in the desert. Lots a problems buried in those holes. Monster Gt 4.6: with brushless setup soon to come.
Hide Signatures
(in reply to scottywilkes)
       Post #: 7002
RE: Monster GT anyone have one? - 8/26/2007 8:48 PM
snowbl!nd
Score: 103
Last Login: 3/20/2013
Status: offline
You can get 23mm hexes on both maxx size & 40 series wheels...
RC obsession. The quest to discover just how deep those pockets really are...
Life is short - Drive fast.
Hide Signatures
(in reply to Snaut Rocket)
       Post #: 7003
RE: Monster GT anyone have one? - 8/26/2007 10:45 PM
hpi firestorm
Score: 100
Last Login: 2/13/2009
Status: offline
i have a question when my truck is at the last little bit of gas it takes of so what could i do to keep it from doing that?
Hide Signatures
(in reply to snowbl!nd)
       Post #: 7004
RE: Monster GT anyone have one? - 8/26/2007 10:51 PM
Snaut Rocket
Score: 100
Status: offline
I dont understand your question. when your at the leat bit of gas you truck takes off. that doesnt make no sense.
Hide Signatures
(in reply to hpi firestorm)
       Post #: 7005
RE: Monster GT anyone have one? - 8/26/2007 10:54 PM
hpi firestorm
Score: 100
Status: offline
i starts to rev high and starts to go a little bit faster
Hide Signatures
       Post #: 7006
RE: Monster GT anyone have one? - 8/26/2007 11:13 PM
CTDave
Score: 100
Last Login: 5/11/2013
Status: offline
Sounds like it is leaning out when the gas runs out.Try richening up the hs just a tweak and see if it helps.
Hide Signatures
       Post #: 7007
RE: Monster GT anyone have one? - 8/26/2007 11:16 PM
hpi firestorm
Score: 100
Status: offline
ok
Hide Signatures
(in reply to CTDave)
       Post #: 7008
RE: Monster GT anyone have one? - 8/28/2007 5:56 AM
Coadster67
Score: 100
Last Login: 9/13/2008
Status: offline
Well, My MGT is oficially famous here in welland.
I was at the skatepark doing some backflips offa the quarter pipes and stuff, and a paper guy came along and got a couple of good shots of my truck and I, as well as the truck catching some massive air. Then when he left, my throttle started sticking. disconnected it offa the servo and its binding up quite a bit. so i fugure ill pull it apart and clean it and whatnot. BTW can i use "nitro Blast" to clean out my carb or should i use WD-40?
Formerly Funtana_man
Hide Signatures
       Post #: 7009
RE: Monster GT anyone have one? - 8/28/2007 6:08 AM
BuzzBomber
Score: 100
Last Login: 12/17/2012
Status: offline
nitro blast is fine. lube it with some after run or marvel mystery oil when you're done.
Matt Smith
If you''re not having fun, you''re missing the point.
Hide Signatures
(in reply to Coadster67)
       Post #: 7010
RE: Monster GT anyone have one? - 8/28/2007 6:09 AM
Snaut Rocket
Score: 100
Status: offline
I would use hpi nitro cleaner but its probably the same thing as the stuff you got.
Hide Signatures
       Post #: 7011
RE: Monster GT anyone have one? - 8/28/2007 6:18 AM
Coadster67
Score: 100
Status: offline
Uhh, this may sound like a noob question, but how do you get the carb off? i took out the screw but nothings moving
Hide Signatures
       Post #: 7012
RE: Monster GT anyone have one? - 8/28/2007 6:46 AM
Snaut Rocket
Score: 100
Status: offline
Can some one tell me why this wont work with the mgt.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPLZ9&P=SM
Read the spec if you dont believe me. I was going to get this one cause its got more rpm.
Hide Signatures
       Post #: 7013
RE: Monster GT anyone have one? - 8/28/2007 7:14 AM
docphysics
Score: 100
Last Login: 2/27/2010
Status: offline
Cuz you can't start it silly!!!!!!!!!! Its got more revies cuz less mass from no pull starter!
Brakes are an unnecessary option!
Hide Signatures
       Post #: 7014
RE: Monster GT anyone have one? - 8/28/2007 7:34 AM
Evader ---> MGT
MGT&top=20000">2016
---> Posts: 2016
Score: 100
Last Login: 10/16/2011
Status: offline
You need a starter box. Our chassis is a block w/ no holes for the flywheel.
MGT8.0-KB45 8XL1600Kv, MMM ~ Evader EXT-Duratrax Intellispeed 16t w/ Rev, Trinity Co 27t + Pro ~ Rustler VXL-Rhino 3S 4900ma
Hide Signatures
(in reply to docphysics)
    %20MGT&top=500 title="Search users posts" target=_blank>   Post #: 7015
RE: Monster GT anyone have one? - 8/28/2007 9:31 AM
Coadster67
Score: 100
Status: offline
Nvm, figured it out
Hide Signatures
       Post #: 7016
RE: Monster GT anyone have one? - 8/28/2007 12:11 PM
scottywilkes
Score: 100
Status: offline
LOL, the truggy LRp28 is made for flat pan chassis, ie with an accesible flywheel.
In the MGT its not accesible, without major modification to the chassis which would leave it ALOT weaker. So it will fit, but have fun starting it.
Hide Signatures
       Post #: 7017
RE: Monster GT anyone have one? - 8/28/2007 8:37 PM
Drmeff
Score: 100
Last Login: 3/28/2013
Status: offline
Can anyone tell me what threads are on the MGT axles? A nut fell off my wheel and I cant find it anywhere!
Also, are the stock wheel hubs 14mm?
Thanks!
Hide Signatures
       Post #: 7018
RE: Monster GT anyone have one? - 8/28/2007 8:41 PM
Coadster67
Score: 100
Status: offline
I know that the stock hubs are 14 mm.
Hide Signatures
(in reply to Drmeff)
       Post #: 7019
RE: Monster GT anyone have one? - 8/28/2007 10:13 PM
snowbl!nd
Score: 103
Status: offline
Threads are 4mm
Hide Signatures
       Post #: 7020
RE: Monster GT anyone have one? - 8/28/2007 11:54 PM
theeunico
Score: 100
Last Login: 6/28/2012
Status: offline
somebody help,when installing foc what gears do i remove permenantaly?and which one do i leave on there?
Hide Signatures
       Post #: 7021
RE: Monster GT anyone have one? - 8/29/2007 12:23 AM
Coadster67
Score: 100
Status: offline
Here you go, this should explain alot, pretty easy to do actually.
http://monstergt.com/articles/transmission_foc.php
Hide Signatures
(in reply to theeunico)
       Post #: 7022
RE: Monster GT anyone have one? - 8/30/2007 2:49 AM
ferrariowner123
Score: 100
Last Login: 9/25/2010
Status: offline
well i got my wheels today and i dyed the wheels black figured i show them off while there still clean
Click to see fullsize image.
Click for fullsize
Click for fullsize
I think Bigfoot is blurry, that''s the problem. There''s a large out-of-focus monster roaming the countryside.
-Mitch H
Hide Signatures
       Post #: 7023
RE: Monster GT anyone have one? - 8/30/2007 4:07 AM
Snaut Rocket
Score: 100
Status: offline
Hey guys kind of a newb question. (FYI I never dyed things before.) Do you guys pour the dye into a bowl or somthing and dip the part in it, or do you take a brush to it and brush it on.
Hide Signatures
(in reply to ferrariowner123)
       Post #: 7024
RE: Monster GT anyone have one? - 8/30/2007 4:12 AM
duckedup
Score: 100
Last Login: 9/3/2012
Status: offline
http://www.groundpoundersrc.com/index.php/topic,163.0.html - that should help
Hide Signatures
       Post #: 7025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
