RE: Monster GT anyone have one?
Tower Hobbies
Logged in as Guest
Users viewing this topic: d3d5
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Monster GT anyone have one?
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Monster GT anyone have one? - 4/17/2006 12:37:36 AM
Pyrotechnic
Status: offline
with my smart temp i have it set so it wont go over 257 degrees. is that too hot???
thanks
_____________________________
the end of a dock is not an obstacle, its an opportunity to get on a boat.
(in reply to Wide Open)
       Post #: 226
RE: Monster GT anyone have one? - 4/17/2006 1:33:31 AM
Rc EnthuSiasTs
Status: offline
The factory specs sais that the engine should run between 250-260. Mine gets to 270 sometimes, It all depends on how your engine runs best. If mine runs at 230, it is too rich and dies on acceleration. That is just my engine. Thanks for the info wideopen.
Mr.pibb+Red Vines=Crazy Delicious
(in reply to Pyrotechnic)
       Post #: 227
RE: Monster GT anyone have one? - 4/17/2006 1:47:05 AM
Wide Open
Status: offline
i would say set it for about 270 or 280. anything much over that would probably be a lean mixture. all engines are different but 257 is not anything to be worried about.
I can divide by zero.
(in reply to Rc EnthuSiasTs)
       Post #: 228
RE: Monster GT anyone have one? - 4/17/2006 1:52:57 AM
Bria1
Status: online
If your getting fuel in the glow plug area of the head and the glow plug is tight, are you sure the glow plug gasket is ok or even there?
www.factorytracksraceway.com
       Post #: 229
RE: Monster GT anyone have one? - 4/17/2006 1:57:09 AM
Pyrotechnic
Status: offline
thanks for the info. about the exhaust, how much smoke is suppose to come out. when i hit the throttle a lot comes out but once i get up to speed not as much comes out. but theres still more than i think neccessary. any ideas??
thanks
       Post #: 230
RE: Monster GT anyone have one? - 4/17/2006 1:59:48 AM
Wide Open
Status: offline
your engine sounds to be running correctly. as you hit the throttle, there should be a distinct trail of smoke, as you get to full, it should thin out a little. id say as long as your engine is running consistantly without faultering or bogging you should be fine!
       Post #: 231
RE: Monster GT anyone have one? - 4/17/2006 1:13:57 PM
Pyrotechnic
Status: offline
i dont have much space to run it at my house so im always on the gas then off. could that be a reason why i over heat??
       Post #: 232
RE: Monster GT anyone have one? - 4/17/2006 2:46:31 PM
Wide Open
Status: offline
no, at least it shouldnt be. racing involves the same thing of always getting on and off the gas. i dont know if youve said this, but does the engine actually quit at the end of the tank? or does it just reach the 257 degrees that you set the failsafe to?
       Post #: 233
RE: Monster GT anyone have one? - 4/17/2006 4:02:01 PM
Pyrotechnic
Status: offline
it just reaches 257 and then i cant move until the engine cools down. but i think i got it figured out. the reason it would over heat so fast is because the temp. probe loop was to close to the exhaust pipe. i just ran it a little while ago with the probe loop turned away from the exhaust and it never went over 230 degrees. i just have to get the shift point right. then ill be good to go.
thanks for the info
       Post #: 234
RE: Monster GT anyone have one? - 4/17/2006 5:36:13 PM
Pyrotechnic
Status: offline
i cant get my mgt to shift into 2nd gear!!! what can i do??? ive tried to adjust the shift point but it doesnt seem to help??? any ideas???
thanks
       Post #: 235
RE: Monster GT anyone have one? - 4/17/2006 8:02:40 PM
