RE: Monster GT anyone have one?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Monster GT anyone have one? Page: <<   < prev  332 333 334 335 336 337 [338] 339 340 341   next >   >>
Login
RE: ... - 5/5/2008 8:34:40 PM
Dirty South Racing
Status: offline
Didn't want to read back through all the posts, so what is the best replacement glow plug?
(in reply to Evader ---> MGT)
       Post #: 8426
RE: ... - 5/5/2008 9:25:53 PM
docphysics
Status: offline
OS 8's work great!
_____________________________
Brakes are an unnecessary option!
(in reply to Dirty South Racing)
       Post #: 8427
RE: ... - 5/5/2008 9:48:41 PM
Snaut Rocket
Status: online
at a gallon and a half and im still on the same os 8
Why do they sterilize the needles for lethal injections?
Groundpounders is muy bueno come and join us
(in reply to docphysics)
       Post #: 8428
RE: ... - 5/6/2008 12:23:08 AM
Elite_Tux487
Status: offline
Well.. I broke a few parts today..bad ass bashing session btw. I found a nice abandoned construction site with 15 foot high jumps. Ill post pics of the carnage later. So far that I can see I broke, front and rear lower a arms, bent shock shaft, broken body post, bent turnbuckle, some how the exhaust got caught into the fly wheel or clutch bell and it ate it and sliced a small gouge at the end and started pulling one side off. That just ended up blowing oil ALL over the truck. I ran the truck for 5 tanks with just half a lower A arm up front on the left and one shock on one that left side. For the body posts..I guess tower is out of stock, are there any other substitutions that will fit?
MGT 4.6 - RC10GT w/ os.18 - Evader St - Maximum St - Stampede
(in reply to Snaut Rocket)
       Post #: 8429
RE: ... - 5/6/2008 12:44:53 AM
Evader ---> MGT
Status: offline
Go to your LHS and get aluminum tubing. Bring a tower and see what size fits the body post holes.
I did this for an SUV body and it worked great. Perfect snug fit, oober strong, and really cheap. Like $4 for all four posts since the tubes come in lengths of about a foot.
I with I knew the diameter of the tube so you could order some. I'll try and measure it later.
92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
(in reply to Elite_Tux487)
    %20MGT&top=500 title="Search users posts" target=_blank>   Post #: 8430
RE: ... - 5/6/2008 1:29:17 AM
Elite_Tux487
Status: offline
How are you cutting the hole for arm that holds the body clips? I don't believe there are dremel bits that small to cut holes. The diameter of the posts I believe is 5/16 in.
Oh and how thick of a wall do you recommend?
< Message edited by Elite_Tux487 -- 5/6/2008 1:45:23 AM >
       Post #: 8431
RE: ... - 5/6/2008 3:19:37 AM
Elite_Tux487
Status: offline
Heres the mess before and after I hosed her down..lol
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 8432
RE: ... - 5/6/2008 8:19:49 AM
Dirty South Racing
Status: offline
Does anyone happen to have the part #s of the LST pipes that people are running on there MGT 4.60 SEs and do I need a new header to make them fit?
       Post #: 8433
RE: ... - 5/7/2008 2:43:30 AM
Hardin Valley Magic
Status: offline
I am having a little problem with my carb!!!!! I am used to airplane engines with the spin style carb cylinder. The problem is the slider sticks or has a hard time closing. I took it off the motor and am having a hard time getting it to slide smoothly. It is like it will pull out so far then is very hard to move in either direction. I was wanting to sand it GENTLY with some 400 grit sandpaper and water. But I was affraid to....What do ya'll suggest?????
Monster GT 4.60 s.e.,Traxxas Nitro Rustler, 4600 Sidewinder Evader ST.
       Post #: 8434
RE: ... - 5/7/2008 3:36:34 AM
Snaut Rocket
Status: online
quote:
ORIGINAL: Dirty South Racing
Go ebay and get the lst2 pipe off of there.
Cheapest way and comes with a header to make a fit.
And doc better not post that darn pic.
