RE: Monster GT anyone have one?
Tower Hobbies
Logged in as Guest
Users viewing this topic: d3d5
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Monster GT anyone have one?
Page: <<   < prev  334 335 336 337 338 339 340 [341] 342 343   next >   >>
Login
RE: Monster GT anyone have one? - 7/2/2008 7:09:31 PM
kevbow
Status: offline
I have a mgt 4.6 with the thunder tiger .28 motor. Just broke it in and it seems to be running pretty slow. I leaned out the high end needle a quarter turn from factory setting and the low eend needle I leaned not even and eight of a turn. Smokes pretty good but seems like it's sluggish and most of the time won't even shift into 2nd gear. Truck is brand new.....does anyone know what would be a good setting for my engine?
(in reply to redfox03)
       Post #: 8501
RE: Monster GT anyone have one? - 7/2/2008 7:27:23 PM
BuzzBomber
Status: offline
Take it slowly while you are breaking in the engine, at least for the first dozen tanks or so. When tuning, let it get up to temperature before fiddling with the needles. If it will idle and accelerate without dying, your low end shouldn't be TOO far off, so leave it alone until you get the high speed closer to dialed in. Right, so once up to temperature, make some passes, letting it come up to full throttle. If after a few passes it doesn't seem to be picking up RPM, bring it in and lean out the high speed 1/8th turn. Make a few more passes, and if necessary keep repeating the process. You shouldn't need to lean out to less than two turns out on the needle, and keep alert that there is always some smoke. If it seems to be dying off at full throttle, you've leaned it too much and should richen up the needle immediately. Your shift point may also need adjustment, but I think running over-rich is the main cause of the sluggishness you are describing.
_____________________________
Matt Smith
If you're not having fun with this hobby, you're missing the point.
(in reply to kevbow)
       Post #: 8502
RE: Monster GT anyone have one? - 7/2/2008 9:34:06 PM
docphysics
Status: offline
Yea, slowly keep leaning it out, till the engine is fully broken in, and the RPM's will keep coming up, and it will shift. Don't start messing with the transmission yet.
Brakes are an unnecessary option!
(in reply to BuzzBomber)
       Post #: 8503
RE: Monster GT anyone have one? - 7/3/2008 4:11:42 PM
Elite_Tux487
Status: offline
As long as your not getting excessive smoke at idle and such you probably aren't too rich. Take a look at this guide. It should help you get the basics of tuning down. http://www.rchobbies.org/cars_eng-tuning.htm
MGT 4.6 - RC10GT w/ os.18 - Evader St - Maximum St - Stampede http://www.myspace.com/Elite_Tux
(in reply to docphysics)
       Post #: 8504
RE: Monster GT anyone have one? - 7/11/2008 7:49:13 PM
BEARBYSR
Status: offline
Hello everyone, new to this thread, just bought the MGT 4.6 from tower and will be gettin next week. I have been racin nitro stadium trucks for the last few years and wanted something to bash around with with my son. I have been thru a few breakins over the years and know the procedures pretty well. Is there anything you guys can think of that I should know about the MGT before breakin or any tips? This will be my first nitro mt and not real familure with them. Thanks.
Oh, how ya doin docphysics
O.S. POWERED DTX NITRO EVADER/ DTX RAZE/MGT/EVADER EVST
(in reply to Elite_Tux487)
       Post #: 8505
RE: Monster GT anyone have one? - 7/11/2008 8:08:35 PM
docphysics
Status: offline
The manual comes with detailed instructions for engine break in. That's what I did.
I am doing well.
(in reply to Snaut Rocket)
       Post #: 8506
RE: Monster GT anyone have one? - 7/11/2008 8:17:01 PM
Snaut Rocket
Status: online
Almost forgot a new pipe would help with noise and performance.
Lst2 pipe can be had cheap.
But dont ask me how to put it on.
Lots of holes in the desert. Lots a problems buried in those holes. Monster Gt 4.6: with brushless setup soon to come.
       Post #: 8507
RE: Monster GT anyone have one? - 7/12/2008 6:02:55 AM
goldwing1800l@sbcglobal.net
Status: offline
i have (2) mgt and they have been great truck but lately i keep burning the speur gear out right in the center on both of them dont know what started that hummmmm
(in reply to alvinl)
       Post #: 8508
RE: Monster GT anyone have one? - 7/12/2008 8:11:04 AM
scottywilkes
Status: offline
thats usually asign that the slipper is to loose, i reckon your slipper pegs have worn down to far and the plates are just pinching on the spur, so it slips alot and creates heat which melts the spur away around the slipper pegs
MGT;Mach 427, FT NTC3;RBC12, RTR NTC3, Tamiya F103, NEVST, RC18T, Jato;STS28
       Post #: 8509
RE: Monster GT anyone have one? - 7/12/2008 3:28:27 PM
Status: offline
Yes that what i was thinking but i tighten the crap out and in all the way down and back off 1/4 turn and i get one or two runs out and spur gear burning hot right in the center i will try and turn it in some more and tighten it and try again if that dont work i dont know what else it could be i have one with the O.S vg .30 and the other with the LRP spec 3 they have been great truck for about a year now then this problemdid go through a couple trannys
(in reply to scottywilkes)
       Post #: 8510
RE: Monster GT anyone have one? - 7/12/2008 4:08:30 PM
