Pica 1/6 P51 mustang RETRACTS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> Pica 1/6 P51 mustang RETRACTS
Page: [1]
Login
Pica 1/6 P51 mustang RETRACTS - 3/18/2006 7:38:45 PM
Wulf
Status: offline
Anyone-I am planning on using Retracts in the Pica 1/6 Mustang I`m building.I have never done this before and I`m looking for advice on which retracts to use to make instalation as simple as possible-I`m sure there are threads somewhere on this subject but, I can`t find any as of yet.I am thinking on using the Robart 622s and have ribs cuttout more or less the fit these with dimensions taken from Robart drawings .I have not bought the units yet and am seeking advice--Maybe someone has some photos? .It looks like it`s going to be a tight instalation.Any help will be much appreciated .
_____________________________
Wulfmann
       Post #: 1
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 6:43:41 AM
DavidAgar
Status: offline
You may want to give this a good look. Good Luck, Dave
http://204.96.183.34/RCU/retract1.htm
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
(in reply to Wulf)
       Post #: 2
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 4:09:04 PM
rcmiket
Status: offline
I would go with Robarts the make a set just for the Pica. There's really nothing to the instal. Mike
(in reply to DavidAgar)
       Post #: 3
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 4:40:50 PM
rcmiket
Status: offline
I don't know if these are any help. This is the set up with the Robarts in my Pica. I'm refinishing the plane as we speak. Mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to rcmiket)
       Post #: 4
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 5:37:59 PM
Wulf
Status: offline
Ya Mike that gives a good idea of whats going on -Thankyou
What no# Robarts are those??622s??
Wulfmann
       Post #: 5
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 6:15:24 PM
rcmiket
Status: offline
Yep 622's . I've had then for so long I had to check the web site @ Robart. I really like them and have never had a problem. If memory serves they have a set of drawings for the Pica this way you can modify the ribs as nesseary. Hope this helps. Mike
(in reply to Wulf)
       Post #: 6
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 8:12:48 PM
Wulf
Status: offline
Yessir it helps alot-thanks
Wulfmann
       Post #: 7
RE: Pica 1/6 P51 mustang RETRACTS - 3/19/2006 11:18:34 PM
spad
Status: offline
Hi - could you confirm the span of the Pica Mustang featured here - I have a set of plans for a "B" model of around 72" span and have been puzzling over the retracts solution - RCMIKET, are those units mechanical or pneumatic?
cheers
Rick
"Flying is life, whatever happens before or after is just waiting"
(with apologies to Steve McQueen)
(in reply to Wulf)
       Post #: 8
RE: Pica 1/6 P51 mustang RETRACTS - 3/20/2006 11:29:29 AM
Wulf
Status: offline
Pneumatic retracts and the Span is 74", weight around 14LBs when completed-4"dia wheel per plans-I`m using a Super Tigre G2300 (1.4 cu.in ) for power.
Wulfmann
(in reply to spad)
       Post #: 9
RE: Pica 1/6 P51 mustang RETRACTS - 3/21/2006 11:36:59 PM
spad
Status: offline
thanks Wulfmann - sounds like the same size approx as my plans - I'm planning 1.2 cu.in size motor but cannot decide between a Magnum 120 2 stroke or an SC120FS four stroke - any suggestions?
(in reply to Wulf)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.395RCU4
