bla bla
rajul. A set rutine or flying a program is nothing more complicated than having ever manuvour pre decided in advance including take off and landing. The key is to fly exactly what you have decided to fly with nothing added and nothing taken away. I'ts what you'd have to do when to enter even a simple aerobatic contest. For example. Take off starts witha taxi out down the runway. Stop. take deep breath. Advance throttle and make take off run. try and break grown exactly infront of you. Fly straight away at an even angle...wings level. At end of run way make 90 degree turn, at a decent distance make a 270 dgree turn to bring you onto a the down wind pass. Thats called a trim pass. At the end of the trim pass perform a simple turn around manuvour... Stall turn etc. (I don't know how well you fly so forgive me) As the aeroplane flys past up wind perform a loop or two then fly straight and perform an other turnaround. Next pass perform a roll, turn around next pass inverted...etc etc. when you'r practicing the rutine can be made out of as many numbers of the same manouver as you want for example 10 loops and ten rolls...just remember some like to be performed into wind..some can be driven down wind. Try and string 20 such things together including take of and landing. perform those 19 manuvors then land. Taxi back, take of again and do exactly the same thing. If you bum out a manuvour... get control, fly straight and carry on with the set program. The point is to not bum out!!!! You have to make the aeroplane do exactly what you've decided it going do and not let it decide for you...even though the wind, your' skills and bad luck be be against you. These programs can get far more complex as you progress. The point is that after you've flown and progran 100 times you'll be one, two even three steps ahead of the aeroplane. This is a critical mindset. You can start learning to do this from day one. As stated... when you see the guys flying F3A or even a free style program at TOC they're all flying a pre set sequence thats been practiced 1000's of times.
