olds455
AK, USA Status: offline
I like it. Thier is a obvious increse in power. The motor is thier micr 370p fireball. I just looked on ebay and thier selling for $10, I bought mine local for $15. i did have to adjust the proportional som eto counter it. The motor only bogs at the extream pos or neg pitch. I did reset the gear mesh last night but havent tested it yet. I found the flybar is very loose and I think the main head might be dammaged. I tried to get the rpm but my tach is broke, It keep flashing 036,036 or 000. I did however intionally install it with the wrong screws and once it came loose I had to tap the mount holes for the new ones. I dont know if i dammaged it then or with shavings. Im going to get to work on it and test with a fresh bat. Ill let if its still going. I dont think the esc is messing up, I think its pilot error(crashing) Ill try to get some vid if you want.
