RE: How light can you go!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> RE: How light can you go!
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: How light can you go! - 4/3/2006 3:56:26 AM
sensei
Status: offline
I cut the wing tube holes utilizing the root rib template and a template that slid into the slots you see in the middle of the wing, next I took a 10/32 extension drill and penetrated the root rib to the wing center slot rib, next I slid a piece of nyrod though the root rib hole to the center slot hole, this allowed me to slide a piece of 020" nichrome wire through the wing. I then pulled the nyrod out of the wing ; leaving the wire exposed on both ends, I then connected both ends of the wire to the hot wire bow, added the power source and followed my templates in a circular motion, and thats really it. Yes I will show pictures of the wing cores after the weight reduction and prior to application of the sheeting.
_____________________________
Fly It Like You Stole It!!!
(in reply to DENNIS C)
       Post #: 26
RE: How light can you go! - 4/4/2006 12:38:23 PM
lsnover
Status: offline
Sensei:
This is all very intersting, but if your willing to go to this much effort, why not just build a kit and do it to your liking?
FWIW, I'm using a Can because it's quieter, not because it has more power. In fact some indications are they produce less power.
Cheers!
Lee
(in reply to sensei)
       Post #: 27
RE: How light can you go! - 4/4/2006 12:43:55 PM
lsnover
Status: offline
quote:
ORIGINAL: lsnover
Sensei:
Any chance of you making some extra wing sets for sale?
Cheers!
Lee
(in reply to lsnover)
       Post #: 28
RE: How light can you go! - 4/4/2006 2:39:19 PM
sensei
Status: offline
Hello Isnover,
If I could have purchased a kit of a 50 cc size Yak, believe me, I would have. I could not even find one. On my 100 and 150 cc engines adding canisters have proven to turn more RPM, however header length plays a critical part in all this.
Bob
       Post #: 29
RE: How light can you go! - 4/5/2006 3:07:49 AM
sensei
Status: offline
Here are a couple more pictures of the wing construction.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sensei -- 4/7/2006 1:50:16 AM >
       Post #: 30
RE: How light can you go! - 4/8/2006 4:56:22 AM
rcfury
Status: offline
I think that is straight up awsome. Keep up the good work. I really like the job on the wings. How much did the stock wings weigh?
Nathan
AMA# 794162 + R/C combat association (RCCA #788)
       Post #: 31
RE: How light can you go! - 4/9/2006 1:54:28 AM
sensei
Status: offline
Hello RC Fury,
Thank you for the complement. The left wing had a weight of 1 lb. 9 oz's and the right wing was 1 lb. 11 oz's Totaling 3 lbs. 4 oz's. The new wings are looking like they will come in around 2 lbs. Time will tell.......
(in reply to rcfury)
       Post #: 32
RE: How light can you go! - 4/11/2006 3:10:15 AM
OnTheEdge
Status: offline
Very nice work. Quite impressive. Best of luck on achieving your diet goals (the folks at Weight Watchers would be proud )
.................Mark
Avoid zen aerobatics...when the ground........and the plane.......become as one.
       Post #: 33
RE: How light can you go! - 4/14/2006 4:04:08 PM
sensei
Status: offline
The competition grade sheeting for the new wings came in yesterday afternoon, so now I can get these things finished up.
(in reply to OnTheEdge)
       Post #: 34
RE: How light can you go! - 4/14/2006 4:38:14 PM
whaturi
Status: offline
i have a chance to get one of these yaks for a good price from a guy. the horozontal stab incidence is off and he said some of the wing ribs are loose from the tube. i was thinking of possibly taking this on as a winter project and also and introduction to giant scale. i'll keep an eye on your progress\results.
very impressive work.. i can't wait to hear what the wingloading ends up at.
would you be willing to cut and sell foam wing cores for people?
       Post #: 35
RE: How light can you go! - 4/15/2006 10:27:48 PM
sensei
Status: offline
Hello Whaturi,
Thanks for the complement, I do not wish to turn my hobby into a small business, however if you want to learn to cut wing cores, I would be happy to walk you through it.
Sincerely
Bob Sawyer
(in reply to whaturi)
       Post #: 36
RE: How light can you go! - 4/15/2006 11:13:34 PM
DENNIS C
Status: offline
quote:
ORIGINAL: sensei
bob what is competition grade balsa. where do we get it from.
"Opinions are like Buttholes EveryBody has one "
       Post #: 37
RE: How light can you go! - 4/16/2006 1:02:30 AM
sensei
Status: offline
Hello Dennis,
Competition grade balsa is considerably lighter than regular grade balsa, it is also considerably more expensive. You can purchase it from several sources but I purchase mine from Sig Manufacturing. Here are a couple more pictures just prior to the sheeting operation. Notice the .125 carbon spar cap tubes, all four tubes have a weight of 20 grams. If in-bedded in a proper bond line will yield a much higher compression and tension factor than hardwood weighing two or three times the weight.
Click for fullsize
Click for fullsize
< Message edited by sensei -- 4/16/2006 2:12:39 PM >
       Post #: 38
RE: How light can you go! - 4/16/2006 1:57:38 AM
CAPtain232
Status: offline
Hey Bob,
Don't get me wrong, I am not bashing your work..... I am just curious.
After you get the sheeting on and then get the covering on, I would like to know whether or not you get flat spots where the holes are. I am much like yourself, I like to make things light.....Even if it means only removing an oz or 2. I know that if you can get an oz here and an oz there, they eventually add up to a pound. When I cut holes in foam, I like to HONEYCOMB it so that there are no large openings for the wood or covering to pull a flat spot....Obviously though, honeycombing takes much longer. Even the layout for honeycombing takes longer.....But the time is usually worth it. I will sometimes cut large holes in a FLAT surface such as the rear side of a wing, rudder or elevator.
If you would, explain your hot wire setup...... I am getting ready to put one together. Planning on using a transformer to reduce voltage to 10 or 12 volts and a dimmer switch.
KEEP UP THE GOOD WORK BUD
< Message edited by CAPtain232 -- 4/16/2006 2:03:40 AM >
CUSTOM GIANT SCALE BUILDER
PROTOTYPE MODEL BUILDING for full scale aircraft
current project can be seen at http://www.geversaircraft.com
       Post #: 39
