RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  606 607 [608] 609 610 611 612 613 614 615   next >   >>
Login
RE: WACO YMF - 8/7/2012 4:40 PM
Stickbuilder
Score: 346
Last Login: 5/21/2013
Status: offline
Wait, y'all are running a G38 in a 5th scale? Wow! Why didn't you just go ahead and cram in a small block chevy? I guess that's proof that you can overpower anything, but just use judicious throttle............ WOW!!!!!!
Bill, Waco Brother #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to aminiet)
       Post #: 15176
RE: WACO YMF - 8/7/2012 5:04 PM
Lins
Score: 100
Last Login: 5/13/2013
Status: offline
quote:
ORIGINAL: aminiet
If any one is interested, there is a Pica 1/5 scale YMF WACO on E BAY. It looks in excellent condition, it has 5 more days to go.
There is also a Great Planes with engine for $900.00
Also a 1/4 scale with ZDZ 80 in Canada in Canada on another forum site. PM me for link if anybody interested, I'm assuming RCU doesn't want me to post links from other sites. $1600 RTF, or $1200 for airframe only. I don't see what make it is.
Cub Brother #10
Waco Brother #221
Hide Signatures
       Post #: 15177
RE: WACO YMF - 8/7/2012 7:20 PM
miltac
Score: 100
Last Login: 4/22/2013
Status: offline
Flew the Waco again on sunday, the flight went well but upon landing, the landing gear did a little split causing a prop strike throwing the waco back in the air and ending in a nose dive at about 40 degrees. the good news is there not much damage. The prop is broke and some of the balsa skin around the LG is a bit busted up.
Here is a pic I took before the flight, I was planing on taking more after the flight but that didnt work out.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Lins)
       Post #: 15178
RE: WACO YMF - 8/7/2012 9:41 PM
mrdhud
Score: 110
Status: offline
quote:
ORIGINAL: Stickbuilder
Hey Bill,
My intentions were not to over power the Waco but only to give it a little more power. With the G26 the plane was almost 19.5 lbs and although the 26 did get her in the air it was at full power and felt like it was struggling so by changing over to the 38 it gave me that little extra power I was looking for on take offs and I’m still 19.5 lbs. I’m going to take her out in the morning and hopefully get in a few flights before the wind start blowing out of the south. I’ll see if I can get Robert to shoot a video.
Dan Hudson WACO Brotherhood #45
GIT-ER-DUN "Build a WACO"
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15179
RE: WACO YMF - 8/7/2012 9:57 PM
acerc
Score: 221
Status: offline
Be glad to Dan. And by the way Bill I agree with you. WOW
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to mrdhud)
       Post #: 15180
RE: WACO YMF - 8/7/2012 10:06 PM
Dash7ATP
Score: 130
Status: offline
Bill,
Do you know if there is a prop extension for the 1.60 Gemini?  With my current mount, a 1/4 inch extension, I have about 3/8 " prop clerance from the cowl.  And it seems almost no clearance in the cowl for a dummy radial. The left exhaust stack is verty close to the inner lip of the cowl, and the carb is way up there as well.  Setting the engine back a quarter inch or so would help a lot.
Joe
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to acerc)
       Post #: 15181
RE: WACO YMF - 8/7/2012 10:58 PM
rccrasher65
Score: 100
Last Login: 5/20/2013
Status: offline
All I'm going to run is a 120 Saito four stroke in mine if I ever get there.
George Waco brother#209
Hide Signatures
(in reply to acerc)
       Post #: 15182
RE: WACO YMF - 8/7/2012 11:56 PM
Stickbuilder
Score: 346
Status: offline
There are probably a couple out there for the 160. This is not the only OS engine that would use such an extension. Find one with the same thread pitch and diameter and go for it. Or if that fails, turn one from bar stock 6061 T6
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15183
RE: WACO YMF - 8/8/2012 5:47 PM
Jaybird
Score: 112
Status: offline
quote:
ORIGINAL: rccrasher65
I have a Saito 125 in the Great Planes WACO and it's more than enough power. Full throttle take-offs are done in about 16 ft with a steep climb out if wanted. A more "scale" looking take-off can be had at half throttle with a strong climbout. Big loops and such are quite easy. The hard part is getting it slowed down! It has a great glide and will carry a lot of energy on base and final if the thrttle isn't brought back on downwind.
There's guy at one club that tries to get me to trade his BUSA 1/4 scale Fokker D-VII for my WACO...I tell him no thank you everytime.
The Waco draws a crowd on the flight line everytime too. The kit built ones shown here and larger scale ones must be a real show stopper when they arrive at the local field.
Tmac48....outstanding! Wow, the more you look the more there is to see. Beautiful plane.
Jaybird
Hide Signatures
(in reply to rccrasher65)
       Post #: 15184
RE: WACO YMF - 8/8/2012 6:26 PM
rcjunky67
Score: 100
Last Login: 9/12/2012
Status: offline
hey Jaybird, hope all is well in your part of the country. I just wanted to ask wether or not you would do any thing differently if you were to build another one of these birds. also, I have but a meesly saito 150 4c to put on mine. its what i got, you know? anyway , I was just wandering if you would recomend changing anything to handle the little bit of extra weight and torque provided by the bigger motor. and also what prop are you using for your 125. thanks in advance for your advice. take care.  Rob Abel
Robert,AMA#947232 waco brotherhood #222
Hide Signatures
(in reply to Jaybird)
       Post #: 15185
RE: WACO YMF - 8/8/2012 6:43 PM
Jaybird
Score: 112
Status: offline
Hi Rob,
As far as the motor mounting goes it was pretty much by the book. I had a little trouble with the lite ply cowl locating disc assembly getting it to fit together true and there was a lot of test fitting and trimming, but I wouldn't recommend anything different. A big help came from a magazine review in which they cut holes in the front disc so you see through as well as apply epoxy inside to mount the ring. I lucked out in that the combination of the 90 degree exhaust header and stock elbow and muffler fit inside the cowl. The large flexible exhaust tip is the only thing exiting the cowl. I did end up with my battery pack on the supplied tray after the fact for balance and it would have eliminated several assemble/disassemble cycles if I had planned to use it from the start. I would imagine the 150 would be heavier and possibly not require the battery to be moved forward in your case.
I'm running a Master Airscrew 16 x 6 black nylon prop on mine. One reason is for the heavier weight up front and possibly some "flywheel" effect to help low idle and the other reason was for nose over in case that happened as I find the wooden props seem to do more damage to the plane when a prop strike occurs, although I imagine it's less stressful for the engine when it breaks. This plane however doesn't exhibit any nose over tendancies like my other WWI biplanes do so it may not be a concern. In fact I've picked a wooden prop to test with to see if I can get a slower idle and perhaps slow the plane down on landing.
There were other elements of the kit that I did differently if you are interested in those.
Jaybird
Click for fullsize
Click for fullsize
< Message edited by Jaybird -- 8/8/2012 9:37 PM >
Hide Signatures
(in reply to rcjunky67)
       Post #: 15186
RE: WACO YMF - 8/8/2012 9:35 PM
mrdhud
Score: 110
Status: offline
Made it out to the flying field this morning and got in two flights. Here’s a short video Robert took not any fancy flying a few take offs & landing. I was
http://www.youtube.com/watch?v=f1xF0A4mSvY&list=UU2JkaaZdvCdk2tWRIuT4rgQ&index=1&feature=plcp
Hide Signatures
       Post #: 15187
RE: WACO YMF - 8/8/2012 9:38 PM
Jaybird
Score: 112
Status: offline
I had a similar morning last weekend...just plain fun to fly! I'm surprised how agile it is for a bulky biplane.
Jaybird
Hide Signatures
       Post #: 15188
RE: WACO YMF - 8/8/2012 9:42 PM
acerc
Score: 221
Status: offline
Dan,
What's that funny noise coming from the plane on landing's?
And you need a new camera man.
Robert
Hide Signatures
       Post #: 15189
RE: WACO YMF - 8/8/2012 9:49 PM
mrdhud
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Dan,
Not sure better check the wheel collar and make sure it hasn’t come loose again and don’t mess with my camera man LOL
Hide Signatures
(in reply to acerc)
       Post #: 15190
RE: WACO YMF - 8/8/2012 11:04 PM
rccrasher65
Score: 100
Status: offline
Nice Dan, very nice, Plane looks great. George
Hide Signatures
(in reply to acerc)
       Post #: 15191
RE: WACO YMF - 8/10/2012 3:40 AM
rcjunky67
Score: 100
Status: offline
as always thanks for the info Jay , it will help. the 150 is also a little taller  from the crank centerline to the top of the rocker covers , so I'm certain I'll have to make some relief holes in the cowl for clearance. DANGIT!!! oh well, whatcha gonna do? as I'm not sure what the weight difference is between the 125 and the 150, and I'm not sure how that big a$$ muffler will fit inside the cowl. I know I'd much rather run a flexible pipe out the bottom than too have to make a great big hole for it to clear. thanks again for your help  brother, she's still on the back burner on low for now, as I've got to get three more servos yet. and we're in the process of looking for a new house. this none just is not big enough for all our needs . take care and I'll be in touch again when we get settled and I get started putting everything together. C_YA  blue skies everyone!!!!!!!!.........
Hide Signatures
       Post #: 15192
RE: WACO YMF - 8/10/2012 7:17 PM
mrdhud
Score: 110
Status: offline
Hello all,
I’m posting this video for Chris (ceije) this was his birthday gift from his wife pretty nice wife I’d say. Happy birthday Chris.
Hide Signatures
       Post #: 15193
RE: WACO YMF - 8/10/2012 8:00 PM
Dash7ATP
Score: 130
Status: offline
Great video. do we have any photos of the plane?  Red, white and blue.  I'd like to see the color scheme if possible.
I hae received your letter, Dan.  Thanks.
Joe
Hide Signatures
       Post #: 15194
RE: WACO YMF - 8/11/2012 12:19 AM
rcjunky67
Score: 100
Status: offline
HAPPY BIRTHDAY CHRIS, thats so freaking cool!!!!!...  this wifey of yours,she got a sister? just kidding , congrats and many happy returns bro. and to think , I'll probably get a hammer or something for mine in november, dang. well, happy b-day anyway.blue skies
Hide Signatures
       Post #: 15195
RE: WACO YMF - 8/11/2012 1:46 PM
ceije
Score: 100
Status: offline
Gents, Just a little slow on homework -posting-. Yeah, after 2 years of talking about taking a flight I think my wife got fed up and took maters into her own hands. Here are some pics of pre flight. Sorry all, its not a YMF its a restored 1940 UPF-7. STILL A WACO!!!
regards
chris melhus, ceije 196
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15196
RE: WACO YMF - 8/11/2012 11:15 PM
airplanegeek
Score: 100
Status: offline
Really guys, I have three daughters at home - and they don't even sound this bad...leave joe alone....Sorry, but what happened to building Waco's
Hide Signatures
(in reply to JoeAverage)
       Post #: 15197
RE: WACO YMF - 8/12/2012 12:42 AM
acerc
Score: 221
Status: offline
I for one would like to say, " Sorry Joe". I thought all  version's of the Waco were welcome here. And there has been plenty of item's sold to one another through out this thread as well.
Robert
Hide Signatures
       Post #: 15198
RE: WACO YMF - 8/12/2012 2:28 AM
da Rock
Score: 265
Status: offline
LIGHTEN UP FOLKS...............
Good flying wit ya today
Hide Signatures
(in reply to acerc)
       Post #: 15199
RE: WACO YMF - 8/12/2012 2:37 AM
da Rock
Score: 265
Status: offline
A couple of previous posts are meant to embarrass other members. They're somewhat mild, but nonetheless break this rule: Please resist the urge to curse, flame, degrade, insult or embarrass someone in your post. We encourage the free flow of your ideas, but believe that they can be communicated (and received) much more effectively if you keep things civil. If you have to vent, take it offline. We carefully monitor posts and will ban individuals who engage in offensive conduct within the forums. Thanks. (RCU Policies)
This has been one of the most pleasant and interesting threads on the forums. There is no value being sarcastic and insulting.
Do not break into a discussion about who said what and how you're not at fault. They will be deleted. Consider again the rule above, that you agree to every time you post.
Hide Signatures
(in reply to da Rock)
       Post #: 15200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
