RE: WACO YMF    Gallery
Logged in as Guest
Users viewing this topic: RCBOATMANIAC
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  613 614 [615] 616 617 618 619 620 621 622   next >   >>
Login
RE: WACO YMF - 9/20/2012 9:35 PM
rccrasher65
Score: 100
Last Login: 5/20/2013
Status: offline
    Yea I've noticed, also noticed the they have no problems with their email like we do, seems funny, that this forum has the problem, and no other, just emailed RCU for some answeres, we'll see what they say.  Its finally fixed, Thanks RCU.
< Message edited by rccrasher65 -- 9/21/2012 6:17 PM >
_____________________________
George Waco brother#209
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15351
RE: WACO YMF - 9/21/2012 3:21 PM
ceije
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: georgewaldrop
quote:
ORIGINAL: rccrasher65
George, did you say the cost of the 1/4 scale plans from the AMA are $135.00 shipped, that sounds expensive for a set plans.
George,
Actually no...That was a quote of a response TO me BY ''chris melhus ceije 196'', AND it was a price for [as I understand it] two sets of enlarged plans (enlarged from the 1/5 Pica Waco plans), one set at 1/4 and the other at 1/3 PLUS it included enlarged templates of the Pica parts as well as enlarged templates of the modified wing tip ribs by Dan Hudson...possibly a bit on the high side, but not terribly so, since you are talking about enlarging plans at two different scales from a third [original] scale and all the templates included...if they are accurate, they would be good plans and it would involve a fair amount of labor all things considered.
again, let me see if i can break this down a little more $35.00 per set of plans X 2, 1/4 scale and 1/3 scale= $70.00 plus $35.00 for enlargement services plus charges for Dan's rib/wing modification and then there's tax =around $125.00. i origionaly said $135.00 i was a little off, sorry didn't mean to scare anyone.
Hide Signatures
(in reply to georgewaldrop)
       Post #: 15352
RE: WACO YMF - 9/21/2012 4:25 PM
Dash7ATP
Score: 130
Last Login: 5/23/2013
Status: offline
FINALLY!  This opened right up through my email link!
Joe
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to ceije)
       Post #: 15353
RE: WACO YMF - 9/21/2012 4:29 PM
georgewaldrop
Score: 105
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: ceije
Chris,
Broken down this way, it seems even cheaper! $35 per set is not out of line for almost any plans, but I haven't seen many 1/4 or 1/3 scale plans commercially available for anywhere near $35 in a good while...sounds like a deal to me! Thanks for the clarification/update!
George Waldrop~AMA-L1307~IMAA-LM207~Have a Blessed Day!
Waco Brotherhood #151 ~~ Carl Goldberg Ultimate Brotherhood #58
Hide Signatures
(in reply to ceije)
       Post #: 15354
RE: WACO YMF - 9/21/2012 5:42 PM
rccrasher65
Score: 100
Status: offline
Joe, I finally got word the problem has been solved,  I guess you know already by your post, my email link opened up instantly also. Thanks RCU.
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15355
RE: WACO YMF - 9/22/2012 9:26 AM
Stickbuilder
Score: 346
Status: offline
Guys, the problem with using enlarged plans from the Pica is that you will wind up with a very big model of the Waco that is not very scale. The wing plan is all wrong and some of the fuse and tailfeathers are wrong too. You would be just as well off using the Pepino plan set and hoping for a scale outline.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to rccrasher65)
       Post #: 15356
RE: WACO YMF - 9/22/2012 9:43 AM
georgewaldrop
Score: 105
Status: offline
I was remembering the comments about the inaccuracies on the Pica plan...did you ever get your true scale 25% scale plans done Bill? One of these days I WILL get another Waco built!
< Message edited by georgewaldrop -- 9/22/2012 6:01 PM >
Hide Signatures
       Post #: 15357
RE: WACO YMF - 9/22/2012 5:48 PM
WacoNut
Score: 175
Status: offline
I started tearing into my crashed 1/3 Waco today, very depressing job to say the least. The firewall did not sustain any damage but from just behind the wirewall back to the front of the wing saddle will need to be totally rebuilt. I believe I can join new parts into the remaining fuselage and get it back into shape.
I found one broken glue joint in the left stab so the tail feathers will be stripped of covering and inspected as well. The top and bottom wing tubes have been bent and are stuck in the corresponding center sections. These will need to get cut off and pulled out(hoipefully that easy). The end rib in each panel fractured when the wing tubes bent. I will remove all the covering from the wings and repair any structural damage.
The cowling did not fare well from the crash and will need replaced. The boot cowl has some minor damage that can be fixed. The rest of the fiberglass parts are in good shape. I will get an inventory of all the formed parts I need to replace and get them from AMR. I think with 3-4 weeks worth of work I can have the Waco ready for covering.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 15358
RE: WACO YMF - 9/22/2012 10:28 PM
Stickbuilder
Score: 346
Status: offline
The Pica is way out of whack as far as the framework goes. The basic outline is pretty good, but getting the thing built to any degree of being scale requires a lot of rethinking. The entire wing plan is junk as is the tail.
The one that I'm doing from the original plans is going to be a 27% version and the top wing span is 97.4 inches.
Hide Signatures
       Post #: 15359
RE: WACO YMF - 9/23/2012 4:22 AM
skypup50
Score: 100
Last Login: 12/13/2012
Status: offline
I was thinking of putting a saito 170 radial in my 1/5 Pica Waco but discovered that it looks like it won't fit without changing the firewall. And it would still not fit under the cowl. I looked at the specs for the saito 120 radial which is designed for 60 to 90 planes. It produces 8# of thrust on a 14 " prop. Since the kit was originally designed for 90 to 120 four strokes would the 120 radial fly it in a scale manner? Thanks for the help.
Hide Signatures
       Post #: 15360
RE: WACO YMF - 9/23/2012 9:46 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: skypup50
I was thinking of putting a saito 170 radial in my 1/5 Pica Waco but discovered that it looks like it won't fit without changing the firewall. And it would still not fit under the cowl. I looked at the specs for the saito 120 radial which is designed for 60 to 90 planes. It produces 8# of thrust on a 14 '' prop. Since the kit was originally designed for 90 to 120 four strokes would the 120 radial fly it in a scale manner? Thanks for the help.
I think that you would be better off both financially and making the airplane more flyable to consider a small gasoline engine. The 3 cylinder 170 while being a very neat little engine is vastly underpowered for its size, and is notorious for dropping a cylinder at low speeds. I don't know if the 120 version has the same problems, but with only a 14" prop, it is going to look very strange. 8# of thrust is not very much either. I'd look to something else entirely. The Saito 3 bangers make a good paperweight. I have one.
Hide Signatures
(in reply to skypup50)
       Post #: 15361
RE: WACO YMF - 9/23/2012 2:47 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Stickbuilder
quote:
ORIGINAL: skypup50
I think that you would be better off both financially and making the airplane more flyable to consider a small gasoline engine. The 3 cylinder 170 while being a very neat little engine is vastly underpowered for its size, and is notorious for dropping a cylinder at low speeds. I don't know if the 120 version has the same problems, but with only a 14'' prop, it is going to look very strange. 8# of thrust is not very much either. I'd look to something else entirely. The Saito 3 bangers make a good paperweight. I have one.
I appreciate your candor, I have a saito FG-21 (gasser) on a Spacewalker 120 which would work and has the four stroke sound. I have been thinking of the OS FT 160 twin. That things has a lot of power, can swing a large prop and sounds great. How about that? I've been looking at the evolution 7-35 7 cylinder radial also, it would fit but not sure how much power it would have.
Hide Signatures
       Post #: 15362
RE: WACO YMF - 9/23/2012 10:53 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: skypup50
quote:
ORIGINAL: skypup50
The FT 160 is a great choice for this plane. Be sure to install a glow driver that will turn on at about 1/4 throttle.
Hide Signatures
       Post #: 15363
RE: WACO YMF - 9/23/2012 11:37 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: skypup50
quote:
ORIGINAL: skypup50
I'm not sure which driver works best?
Hide Signatures
       Post #: 15364
RE: WACO YMF - 9/24/2012 2:37 AM
ceije
Score: 100
Status: offline
Skypup, there are several companies that have drivers, I have stayed with mc Daniels they have service if needed. I have several of their drivers and they are what's comfortable for my application. Sullivan I believe also has a driver, and I'm sure the guys with more experience can give you more info. A little research and you should find a solution to suit your needs.
Chris melhus, ceije 196]
Hide Signatures
       Post #: 15365
RE: WACO YMF - 9/24/2012 4:06 AM
jymster
Score: 100
Status: offline
I use these guys: www.microsens.at . They are the smallest and lightest onboard glow on the market, and run off LiPos.
WACO Brotherhood #228
Ryan STA/STM Brotherhood #26
Hide Signatures
(in reply to ceije)
       Post #: 15366
RE: WACO YMF - 9/25/2012 2:09 AM
Jim Henley
Score: 120
Status: offline
I have used a Sonic-tronics (Mc Daniel) for many seasons, they are reliable and if you have questions or need help, give them a call.
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
(in reply to jymster)
       Post #: 15367
RE: WACO YMF - 9/25/2012 5:33 PM
georgewaldrop
Score: 105
Status: offline
Bill,
I would be in for a set of those plans when you get them available...I have thought about the larger kits, but honestly don't want to spend the money to buy a kit that large...nice as they are, I'd rather build it from good plans. Thanks for the info...I knew the wings were not correct on the Pica, both in some of the rib profile/contour and the spar placement, and probably other places. I didn't know (probably read it here, but I have slept since I did!) the tail was out of whack...what is off on it (besides the non adjustable stab)? :<)
Hide Signatures
       Post #: 15368
RE: WACO YMF - 9/25/2012 6:02 PM
skypup50
Score: 100
Status: offline
Guys
I have one on backorder. I found a source for methanol for diluting the fuel to get the 7% lubrication required. This radial really is amazing.
http://www.horizonhobby.com/products/7-cylinder-35cc-4-stroke-glow-radial-engine-EVOE735
http://www.youtube.com/watch?v=o9adZ3e2cL0&list=PLE_J70ARj49zUqAU_H5EyMxDIINXTCAam&index=20&feature=plpp_video
Hide Signatures
       Post #: 15369
RE: WACO YMF - 9/26/2012 1:07 AM
jymster
Score: 100
Status: offline
Hi skypup, I have the 77cc radial and it is a really well made engine. So far seems very good quality, especially for the price. I guess time will tell, though. I am currently fitting it to my 97" Gee Bee Y.
James.
Hide Signatures
       Post #: 15370
RE: WACO YMF - 9/26/2012 2:11 AM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: jymster
Hi skypup, I have the 77cc radial and it is a really well made engine. So far seems very good quality, especially for the price. I guess time will tell, though. I am currently fitting it to my 97'' Gee Bee Y.
James.
Thanks James. I appreciate your comments. Did you use 100% methanol for break-in? I found a place to get some today.
Hide Signatures
       Post #: 15371
RE: WACO YMF - 9/26/2012 2:23 AM
jymster
Score: 100
Status: offline
I presume you mean fuel with methanol + oil, but no nitro? You definitely need oil! Yes, I always mix my own fuel anyway, so can make whatever mix I need. I buy methanol in 20L (5.3 gal) drums, oil in 3.8L (1 gal) and nitromethane in 4L (>1gal). Saves a fortune, compared to premix fuels.
i started off with 10% oil and am reducing from there. I have not quite finished running it in yet. Will do this in the model.
Hide Signatures
       Post #: 15372
RE: WACO YMF - 9/26/2012 2:39 AM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: jymster
Yes, That's what I meant. The place I will buy my methanol manufacturers model fuel. I guess I could get the other ingredients too. How much is a gallon of nitro?
Hide Signatures
       Post #: 15373
RE: WACO YMF - 9/26/2012 2:43 AM
jymster
Score: 100
Status: offline
Well, i am in Australia, so I am sure the price will be different. But I pay around AUD$75 for a 5L (1.3 gallon) bottle.
Hide Signatures
       Post #: 15374
RE: WACO YMF - 9/26/2012 3:05 AM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: jymster
Worth its weight in gold, isn't it (nitro)? If I buy this 7-35 radial I won't need to worry too much about fuel cost. I wouldn't expect to fly the plane very often. I have a Spacewalker with a Saito FG-21 petrol for sport flying. The Waco would be more for show and that engine would really be perfect if it doesn't overheat.
Hide Signatures
       Post #: 15375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
