RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  617 618 [619] 620 621 622 623 624 625 626   next >   >>
Login
RE: WACO YMF - 10/22/2012 10:30 PM
Dash7ATP
Score: 130
Last Login: 5/18/2013
Status: offline
Too bad you didn't have a camera! That would have been a neat photo. However, you could have gotten the pilot in trouble with the FAA if it had been published.  They don't like that kind of stuff close to people on the ground.  I know it happens, though. I did happen to see a very low level pass by an L-39 Jet at one of the Florida Jets meets I attended a few years back.  He was right on the deck about a hundred feet in front of the flight line. WOW!
Joe
_____________________________
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to WacoNut)
       Post #: 15451
RE: WACO YMF - 10/23/2012 12:44 AM
WacoNut
Score: 175
Last Login: 5/19/2013
Status: offline
The low passes down the runway happen all the time everywhere(at least the grass strips around here). Doesn't seem like anyone worries about it too much.
I may try and actually stitch the fabric on my 1/3 Waco when I recover it this winter. May be a bigger headache than I anticipate but you never know until you try. My wife has retired so maybe she can stitch it for me
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15452
RE: WACO YMF - 10/23/2012 1:30 AM
Dash7ATP
Score: 130
Status: offline
I have a friend who just finsihed a 1/4 scale Balsa USA SE-5. He actually did the stitching on his plane. That's a lot of work, but it looked great!
Dash
Hide Signatures
       Post #: 15453
RE: WACO YMF - 10/23/2012 1:53 AM
jymster
Score: 100
Status: offline
quote:
ORIGINAL: Dash7ATP
Dash
It is often necessary to use real rib stitching on WWI aircraft, as they usually have under cambered airfoils, which means that the fabric wants to pull off the rib when it is shrunk tight. Also, for a 1/3 Waco it would be better not only for scale effect, but the aerodynamic "suction" forces are getting closer to the full scale. It is also easier to do as the models get bigger. For 1/6 and 1/5 scale, it would not be necessary structurally, but still gives a nice scale effect. However, there are other easier, "cheat" methods, which I am sure you all know anyway.
James.
WACO Brotherhood #228
Ryan STA/STM Brotherhood #26
Hide Signatures
       Post #: 15454
RE: WACO YMF - 10/24/2012 11:04 AM
Stickbuilder
Score: 346
Status: offline
Been thinking about using real rib stitching on this one too, but as with most small models, the more you add the porkier it becomes. May just have to wait for the 27% to do all that. Of course, you can build one that size too heavy too. Don't need a hundred pound model.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to jymster)
       Post #: 15455
RE: WACO YMF - 10/24/2012 3:19 PM
BobH
Score: 116
Status: offline
Rib stitching actually goes pretty fast once you get started. I've done and I've faked it too. You can always tell which is which.
BobH.
Hide Signatures
       Post #: 15456
RE: WACO YMF - 10/24/2012 3:31 PM
Cricklewood
Score: 100
Last Login: 5/11/2013
Status: offline
Does anyone have or can you guide me to information on doing real rib stitching? I am getting ready to build a 1/4 scale Sopwith Pup, hopefully do my Pica Waco after that, and would consider doing real stitching but know nothing about it. Any help/guidance would be appreciated.
Chris
WB #133
Hide Signatures
(in reply to BobH)
       Post #: 15457
RE: WACO YMF - 10/24/2012 7:36 PM
nine o nine
Score: 105
Status: offline
Here you go Crick. www.youtube.com/watch?v=q3nnDg-6CBs
Mitch
Hide Signatures
(in reply to Cricklewood)
       Post #: 15458
RE: WACO YMF - 10/24/2012 9:39 PM
Stickbuilder
Score: 346
Status: offline
Mitch,
Thank you for that post. I may just give it a try.
Hide Signatures
(in reply to nine o nine)
       Post #: 15459
RE: WACO YMF - 10/25/2012 12:10 AM
Jim Henley
Score: 120
Status: offline
Thanks Mitch, I doubt I will ever need to stitch the rib to the covering fabric, I have always wondered how it was done.
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15460
RE: WACO YMF - 10/25/2012 12:22 AM
jymster
Score: 100
Status: offline
quote:
ORIGINAL: nine o nine
Mitch
The only thing to not is that the type of rib stitching and type of knot can vary between aircraft. Always good to check how it is done on the full size of your chosen prototype.
James.
Hide Signatures
       Post #: 15461
RE: WACO YMF - 10/25/2012 1:49 AM
Cricklewood
Score: 100
Status: offline
Mitch,
Thanks for the link. Now I need to find where one can get of those needles in a smaller scale.
Chris
WB# 133
Hide Signatures
       Post #: 15462
RE: WACO YMF - 10/25/2012 2:24 AM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: Cricklewood
Mitch,
Chris
WB# 133
Most good fabric / sewing stores should have something like that. Or, a sail maker if you should happen to have one near by.
I was thinking about doing the stitching on my 1/5 scale Waco..  If I were to do it, I would just go around the rib and move to the next stitch without doing a knot at each location.  My only question right now is how to finish off each end without having a big knot there.  I'm looking at using a dacron line sold for fly fishing backing on the reel. It's 20 lb test and should show up under the pinked tape well, and it's cuts easily. It's also available in 30 # and I think 40#, If you need more bulk.
I tried making my own sticth sheets as mentioned earlier but the paper I used didn't work too well. I got it from an old rubber kit. The string didn't bond very well with it. I bought a sheet of silkspan today ( OO) and it's more absorbant, so hopefully it should work better. I'll give a progress report when I have one.  I'm thiniing the silkspan side should go on the rib with the pinked tape directly over the stitch. Correct???
Joe
Hide Signatures
       Post #: 15463
RE: WACO YMF - 10/25/2012 3:37 AM
Cricklewood
Score: 100
Status: offline
Joe,
Thank you for the mention of the sailmakers needle. I dug into my old sailing rigging gear and discovered that I have a curved needle that may just do the job. I will look into the fly fishing backing line to see hat they have.
Chris
WB# 133
Hide Signatures
       Post #: 15464
RE: WACO YMF - 10/25/2012 4:32 AM
Tony V.
Score: 100
Last Login: 5/17/2013
Status: offline
http://www.joann.com/collins-quilter-s-curved-needles/prd2798/?green=2dddae00-1022-e7d099-3ccc-a110218a06d9
These may work.
Tony
Tony, AMA 120246
WACO Brotherhood #71
Hide Signatures
       Post #: 15465
RE: WACO YMF - 10/25/2012 12:45 PM
nine o nine
Score: 105
Status: offline
Don't overthink the rib stitching guys as it's not at all necessary for models. The effect is all you're looking for so this is my suggestion. It's easy to just make a stitch around each rib and tie it off with any knot and poke the knot inside so it won't show.
What most don't realize (and it'll only show on very close inspection) is that there's a reinforcing tape applied over and under each rib BEFORE the stitching is used. Over the whole procedure the pinked tape is applied.
It's much extra work but the subtle look of stitches and tapes adds a visual dimension that separates hand built models from the ARFs.
As far as special needles: make one from narrow guage music wire with a short 180 bend for the eye....simple. Mitch
Hide Signatures
(in reply to Tony V.)
       Post #: 15466
RE: WACO YMF - 10/25/2012 1:52 PM
Cricklewood
Score: 100
Status: offline
Mitch,
I am not clear on your comment:
"What most don't realize (and it'll only show on very close inspection) is that there's a reinforcing tape applied over and under each rib BEFORE the stitching is used. Over the whole procedure the pinked tape is applied."
Do you mean that a a reinforcing tape is applied to the rib, the covering is put on and then a second reinforcing tape is put over the covering or there is a reinforcing tape over the covering on each side, top and bottom, of the wing?
Chris
WB# 133
Hide Signatures
       Post #: 15467
RE: WACO YMF - 10/25/2012 3:02 PM
skylarkmk1
Score: 210
Status: offline
I believe what Mitch is saying is that the wing is covered, a narrow strip of reinforcing tape (same width as the rib is applied, helps prevent tearing of the fabric at the stitch, rivit or screw), and then the pinked tape. Here is another video on rib stitching http://www.wicksaircraft.com/rib_stitching_video.html provided by Wicks Aircraft Supply http://www.wicksaircraft.com/index.html where you can clearly see the first reinforcing tape applied to the wing with the stitching being done over the tape.
P1 - Rib stich on NC 14081.
Click to see fullsize image.
Click for fullsize
< Message edited by skylarkmk1 -- 10/26/2012 3:49 AM >
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 15468
RE: WACO YMF - 10/25/2012 7:26 PM
nine o nine
Score: 105
Status: offline
As John explained....a reenforcing tape (same width as the rib capstrip) goes on after the fabric, then rib stitches, then pinked tape (usually 2" wide). Modelers usually leave off the reenforcing tape unless your doing for museum quality as it hardly shows even on full scale. Sorry if I wasn't clear Chris. Mitch
Hide Signatures
(in reply to skylarkmk1)
       Post #: 15469
RE: WACO YMF - 10/25/2012 8:09 PM
Cricklewood
Score: 100
Status: offline
Mitch and John,
Thank you for the explanation. Mitch, probably more my brain not being clear than your description. Now I just need to get to building the plane to try it on.
Chris
Hide Signatures
       Post #: 15470
RE: WACO YMF - 10/25/2012 8:11 PM
Stickbuilder
Score: 346
Status: offline
Spent most of the day at Monster Planes, and our own Dave Collis AKA Mogman WB 180 was the first plane in the air. We had to wait a while to get clearance to fly since there are some VIP people (or so they claim) in Tampa, and the Paradise field is right on the edge of the 30 mile circle that the FAA imposes when Barry or Mitt and even the Veep and the Next Veep are in the area. We got that lifted and Dave fired up his 40% Waco and lifted off. Beautiful scale flight. Pictures when Janelle gets home and loads them for me.
Hide Signatures
       Post #: 15471
RE: WACO YMF - 10/25/2012 9:32 PM
n6iap
Score: 100
Status: offline
Are any of the members going to be at Monster Planes on Sunday? My schedule does not permit me to get there any other day. I would like to meet some of the Brotherhood if you are there.
jimm
The two most useless things a pilot has; the runway behind you and the altitude above you.
CORSAIR Brotherhood # 71 / Club Saito Member #704 / Waco Brotherhood#205
Hide Signatures
       Post #: 15472
RE: WACO YMF - 10/25/2012 10:51 PM
ceije
Score: 100
Status: offline
jimm, sorry your going to be disappointed, Monster Planes runs from the 25th through the 27th the field will be open for those who hang around on the 28th i beleive till 3 p.m. you might want to try and adjust your sked. and try to go Sat. afternoon, there should still be a few members hanging around.
regards,
chris melhus, ceije 196
Hide Signatures
(in reply to n6iap)
       Post #: 15473
RE: WACO YMF - 10/25/2012 11:58 PM
jymster
Score: 100
Status: offline
As John explained....a reenforcing tape (same width as the rib capstrip) goes on after the fabric, then rib stitches, then pinked tape (usually 2'' wide). Modelers usually leave off the reenforcing tape unless your doing for museum quality as it hardly shows even on full scale. Sorry if I wasn't clear Chris. Mitch
Here is a good image to demonstrate:
Click for fullsize
Hide Signatures
       Post #: 15474
RE: WACO YMF - 10/26/2012 10:39 AM
Stickbuilder
Score: 346
Status: offline
As promised here are a few shots from Monster Planes. The one of Dave's landing is the only action shot. That is Dave with his Waco in one of the other photos. The P-38 is meaningful to me, since Dad flew them toward the end of WW 2 and early into Korea.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
