RE: WACO YMF    Gallery
Logged in as Guest
Users viewing this topic: nine o nine, Dash7ATP, shaked israel, RKflyingboats
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  624 625 [626] 627 628 629 630 631 632 633   next >   >>
Login
RE: WACO YMF - 11/25/2012 6:03 PM
FMBB
Score: 110
Last Login: 6/17/2013
Status: offline
Bob,
no elevator at all during take off, the Waco will get airborne immediately and might be too slow. I never used a second servo on any of the Wacos quarter or third scale. I never thought that I would need one but may be its better, there is of course the advantage to have two different throws due to expo. Let me know your experience. But do not give elevator directly after brake release. The Waco will lift the tail immediately after the engine will built up higher rpms, so if you give elevator the fuselage will get airborne more or less after 3 to 5 meters which might be a bit to slow so close to the surface (not good for landing gear and prop).
Where have you been stationed over here (Frankfurt, Ramstein or Munich area)?
Peter # Brother 170
Hide Signatures
(in reply to BobH)
       Post #: 15626
RE: WACO YMF - 11/25/2012 8:27 PM
BobH
Score: 116
Last Login: 6/19/2013
Status: offline
Peter, I was stationed at Rhein Main air base. It's no longer there I'm told. It was back in the late 60's during the cold war. I visited Berlin too and saw the wall etc. Went through East Germany and saw that too... Im glad people came to their senses and stopped all that.
I was reading some tips on taking off the full scale Waco. The FIRST thing they advise is to LOCK THE TAIL WHEEL! It's fully castering for taxi and then locked for take off. Of course you have a bigger heavier bird and it takes more runway.. so it may not be necessary on the model. Interesting never the less
_____________________________
BobH.
Hide Signatures
(in reply to FMBB)
       Post #: 15627
RE: WACO YMF - 11/26/2012 5:55 PM
FMBB
Score: 110
Status: offline
Hi Bob,
so their is a slight chance that we may have seen each other. I was living in Darmstadt a city close to FAB. The Air force had their also a place and a nice NCO Club which we visited some times when it was an Air force club later on it was army. My school was just near by and we liked to go there during our brakes to have a Hamburger and a Coke. In the early 70s I was working for Lufthansa on the opposite side of the landing field. Now I'm living in Munich.
Peter
Hide Signatures
(in reply to BobH)
       Post #: 15628
RE: WACO YMF - 11/26/2012 6:55 PM
Errol Levin
Score: 100
Status: offline
Hi Chris and others,
Have a look at my rudder/tailwheel servo setup. I made my own servo arm from carbon fibre. The distances between the ball links are exactly the same as the distances on the tail wheel arm and the rudder horns as per the drawings. This means the wires run exactly parallel and also means that the tail wheel has a lot less throw than the rudder. I hope I am making sense. The servo is a Futaba BLS351 (15.6Kgs @6.0V) which is more than adequate for both. This may help you in your deliberations. It is these deliberations that take hours of your building time and drive one mad.
Regards
ERROL #204
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ceije)
       Post #: 15629
RE: WACO YMF - 11/26/2012 10:52 PM
Stickbuilder
Score: 346
Status: offline
Errol,
Nice work with the carbon fiber. What are those velcro pieces for, batteries maybe?
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to Errol Levin)
       Post #: 15630
RE: WACO YMF - 11/27/2012 3:49 AM
Dash7ATP
Score: 130
Status: online
Making the windshield Frame, Installment #2.
As I said in my previous post, I did not like my first attempt at making a fiberglass windshield frame. The biggest problem I think was I was using a cloth that was too heavy and it would not lay flush with the surface at the corners. The other problem was using frisket film as a release agent for the windshield. That in itself was not an issue, it did work as intended, but I didn't have the frame stuck down to the airframe well enough to get good sharp corners at the bottom edges. I had left extra frisket film at the edges hoping it would stick to the film on the fuselage and it didn't.
My second layup was done a little differently. After covering the fuselage with plastic film I taped the windshield to it along all of the edges that touched the fuselage with a clear tape.  I then applied two coats of PVA mold release film to all surfaces that would possibly see resin. I'm using Z-Poxy finishing Resin for the layup. This worked very well. I used a much lighter glass cloth, I'm guessing it was about one ounce per yard, and the weave allowed it to mold to the surface quite well. I cut it into strips about an inch wide (too wide) and around five inches long. Given the thickness of the cloth, I figured I'd need about 8 to 10 pieces for the required thickness.
As you can see, the layup went very well. I kept the resin to a minumum by using each layer to soak up the excess resin from the previous coat until I had applied what I thought was enough cloth. I learned another lesson here also.  You will need to try to avoid letting the corners get too thick by letting the strips lay accross each other at the ends. It will be a little messy, but try to make each strip just long enough to lay alongside of the pieces joining it in the corners. You can overlap the end pieces similar to the way bricks come together at corners,  tying the corners together.  This will prevent the neccessity of having to sand down the overly thick corners where your cloth doubled up.
I think you can see what I'm talking about in the photos below  Sorry about the two similar photos).
This layup went very well, and after a lot of sanding to eliminate the heavy corners, I have something I may be able to use.
Click for fullsize
Click for fullsize
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15631
RE: WACO YMF - 11/27/2012 10:59 AM
Stickbuilder
Score: 346
Status: offline
I was going to do my windshield frame like I did the last one from Brass and balsa, but I've decided to do this one from aluminum angle and sheet. I'll see how well it goes.
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15632
RE: WACO YMF - 11/27/2012 4:31 PM
Dash7ATP
Score: 130
Status: online
Windshield Frame Installment 3
This is the current status of my second frame.  At this time, I'm pretty happy with the results, but who knows. The third time is the charm, so they say.  I may do another one before I finish the project.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15633
RE: WACO YMF - 11/27/2012 4:58 PM
Stickbuilder
Score: 346
Status: offline
Here's what I've been doing with my spare time lately........
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15634
RE: WACO YMF - 11/27/2012 4:59 PM
Stickbuilder
Score: 346
Status: offline
and a couple more of them. I know it's not a Waco, but........
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15635
RE: WACO YMF - 11/27/2012 5:00 PM
Jaybird
Score: 112
Status: offline
quote:
ORIGINAL: Stickbuilder
Hey! I recognize that plane and that workshop!
Have you taken a look at my Stearman ride video? Here is a link to the YouTube video. http://youtu.be/Eq8rFSJ_OCQ
Jaybird
Hide Signatures
       Post #: 15636
RE: WACO YMF - 11/27/2012 5:10 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Jaybird
Jaybird
Yep, you lucky devil...
Hide Signatures
(in reply to Jaybird)
       Post #: 15637
RE: WACO YMF - 11/27/2012 5:11 PM
Errol Levin
Score: 100
Status: offline
Hi Bill
Thanks for the compliment. Yes the straps are for two six volt Nicad packs. They will both feed into a Smartfly EQ10 to give me power redundancy. See the pic below.
The smaller unit is a relay for my landing lights.
All my electronics and servos are on removable trays, and are connected with colour coded wires. See coloured shrink sleeving.
This way I can remove the trays to gain access to the inside the plane.
Regards
ERROL #204
Click for fullsize
Hide Signatures
       Post #: 15638
RE: WACO YMF - 11/27/2012 7:21 PM
mrdhud
Score: 110
Status: offline
Bill,
The Ryan’s looking good! Sorry about loosing you on the phone today my phone just went dead. I got the dle 30 from ups today so I’ll look at the weight and fit for the cub.
Jay,
That looked like to much fun. I thought about taking that rid many times. I took my granddaughter up in the other biplane about 10 years ago that was fun.
Dan Hudson WACO Brotherhood #45
GIT-ER-DUN "Build a WACO"
Hide Signatures
       Post #: 15639
RE: WACO YMF - 11/27/2012 7:25 PM
Jaybird
Score: 112
Status: offline
Dan,
It IS great fun. I would recommend it to anyone whether they have any flying experience or not. Rob will have you do however much of the flying you want to do. This was my third flight with him over the last 6 years. I make it part of my scedule whenever we visit that area.
Jaybird
Hide Signatures
(in reply to mrdhud)
       Post #: 15640
RE: WACO YMF - 11/27/2012 7:29 PM
VOX
Score: 110
Last Login: 3/16/2013
Status: offline
Hello,
Working with the model continues. I almost finished all the surface of the model, which I will do later imitation screws and sheet cladding...
Albert
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15641
RE: WACO YMF - 11/27/2012 8:51 PM
Jim Henley
Score: 120
Status: online
Bill, are you using Byron's foam stab and fin or did you build those up also? I have the Staggerwing that needs a set of wings framed up.
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
       Post #: 15642
RE: WACO YMF - 11/27/2012 9:15 PM
Stickbuilder
Score: 346
Status: offline
Jim, I used the stab and fin that came with the Byron kit. If I had realized earlier on that I was going to frame up the wings, I'd have framed up the tail group as well. Unlike the wings, they seem to be okay. Get after framing up your staggerwing wings.
Hide Signatures
(in reply to Jim Henley)
       Post #: 15643
RE: WACO YMF - 11/28/2012 10:52 AM
Stickbuilder
Score: 346
Status: offline
Got to looking at the build last night. I may just cut away the tail group and scratch it out too. Don't know why, but it's kinda-sorta like looking at a mountain.............Because its there.
Hide Signatures
       Post #: 15644
RE: WACO YMF - 11/28/2012 3:18 PM
BobH
Score: 116
Status: offline
Peter, I missed you then. I left frankfurt in the spring of 1968 Never revisiting. Maybe I should come back and see how things have changed. Would really be interesting thats for sure
BobH.
Hide Signatures
(in reply to FMBB)
       Post #: 15645
RE: WACO YMF - 11/28/2012 4:12 PM
Jim Henley
Score: 120
Status: online
Bill, you are correct I need to get after framing up those wings, but after all those months of work were lost on the maiden, it will have to go to the back of the queue. After all I still have the WACO to complete.
Jim,
Hide Signatures
       Post #: 15646
RE: WACO YMF - 11/28/2012 6:15 PM
FMBB
Score: 110
Status: offline
Hi Bob,
it changed a lot. New hangars on the West end have been built and offices for all the people involved in air fright. The air base is now used by civilian aircraft and their are two new landing fields on at the west end of the old runways which is only for take offs and one in the north closer to the city across the autobahn also only for landing. They have bridges for the aircraft to cross the autobahn to get to the terminals. Term A, B and C have been built larger and their is a new term 2 in the east of term A,B,C. So you would be astonished how much has changed. You should visit Germany during spring or summer and join the one or other model event or fairy. The Dortmund show which is in April is far bigger then Toledo or New York model show which I both visited this year.
Peter
Hide Signatures
(in reply to BobH)
       Post #: 15647
RE: WACO YMF - 11/28/2012 7:09 PM
aminiet
Score: 115
Last Login: 6/14/2013
Status: offline
I was near Stuttgart in a small town named Swabish Gmund ( probably wrong spelling ) in 1969-70 with the U.S. Army with a Pershing missile battallion. Beautifull country side.
SO MANY WACOS, SO LITTLE TIME.......
Hide Signatures
(in reply to FMBB)
       Post #: 15648
RE: WACO YMF - 11/28/2012 8:59 PM
BobH
Score: 116
Status: offline
Peter, I looked at google earth.. Yes LOTS have changed!.. Maybe some day I'll get back there
If I ever do.. I'll be sure to look you up
BobH.
Hide Signatures
(in reply to FMBB)
       Post #: 15649
RE: WACO YMF - 11/29/2012 3:41 AM
willey
Score: 100
Status: offline
quote:
ORIGINAL: Dash7ATP
I think it looks great! don't touch it. I will be doing/using the same method on my SRE windshield
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Warbirds & Classics
Hide Signatures
       Post #: 15650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.781RCU1
