RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  630 631 [632] 633 634 635 636 637 638 639   next >   >>
Login
RE: WACO YMF - 12/30/2012 11:58 PM
skylarkmk1
Score: 210
Last Login: 6/20/2013
Status: offline
Joe,
No Clue. I have Adobe Reader X (10.1.4) and do not have any problems with the PDFs of the Pica Plans.
You may hve to try other PDFs and see if they open correctly. If they do you need a new copy of the plans PDFs. If not you need a new copy of Adobe.
_____________________________
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15776
RE: WACO YMF - 12/31/2012 7:57 PM
hopkimf
Score: 100
Last Login: 6/18/2013
Status: offline
Barth 1/3 YMF still moving ahead. Gotta love the Germans with their attention to detail. Every part numbered, even spars and wing sheeting. It is fitting together pretty well. But since everything is cut to size, I had a hard time clamping sheeting for LE center section once opposite side was in place. So I cut a wider sheet that was easier to clamp in place. Probably should have used sandbags instead. Will probably do that for long wing sections. Better ideas?
Mike Hopkins Waco Brotherhood # 132
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15777
RE: WACO YMF - 12/31/2012 8:08 PM
aminiet
Score: 115
Last Login: 6/14/2013
Status: offline
Wrap around with 2" maskig tape.
SO MANY WACOS, SO LITTLE TIME.......
Hide Signatures
(in reply to hopkimf)
       Post #: 15778
RE: WACO YMF - 12/31/2012 9:53 PM
chuck l
Score: 108
Status: offline
Mike,
Please use 3M tape, it would help to pay my pension. With tape, you will find that is doesn't stick to balsa reliably, just wrap around so the ends overlap.
Chuck
WACO Brother #233
Hide Signatures
(in reply to aminiet)
       Post #: 15779
RE: WACO YMF - 12/31/2012 10:55 PM
hopkimf
Score: 100
Status: offline
Guys, thanks for the tip. This monster is larger than anything I've attempted to date. I need to soak the sheeting to keep it from cracking, so I'll wrap it around as needed. Chuck L..... We drive by 3M HQ in MSP going to visit relatives in MN. I think they're doing just fine.
Mike H 132
Hide Signatures
(in reply to chuck l)
       Post #: 15780
RE: WACO YMF - 12/31/2012 11:09 PM
WacoNut
Score: 175
Status: offline
Mike,
Glad to see your build is going good. I am well into the rebuild of my AMR 1/3 fuse. Much easier the 2nd time around.
Chuck,
I buy enough 3M fine line masking tape to do my part of securing your retirement The Waco eats up a couple rolls without any problems come painting time. Hopefully this is the last time I will have to pint this plane.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 15781
RE: WACO YMF - 1/1/2013 12:53 AM
mogman
Score: 100
Status: offline
Mike,
As well as wetting the sheeting to go around the leading edge, you can also set your monocote iron on high and use that to steam the sheeting to ease the bending. Works well with thin plywood as well.
You can also "dry glue and iron" the sheeting. Put a thin coat of white carpenters glue on both surfaces, let dry 5-10 mins., place wood in position, wet and iron with a hot (300') monocote iron. The heat softens the glue and then thermo-sets it. No taping, no waiting for glue to set. Just hold the part for 15-20 seconds...all done. If you have to remove the sheeting (within a reasonable time), simply re-heat and gently pull away, re-position, re-heat and good to go. I've just finished sheeting a large glider fuse with 1/64 ply panels using that method...works a treat!!
Cheers,
Dave.
W/B #180
Hide Signatures
(in reply to WacoNut)
       Post #: 15782
RE: WACO YMF - 1/1/2013 1:08 AM
chuck l
Score: 108
Status: offline
What is the correct mixture for softening the sheet before bending, 50/50 water ammonia?
Chuck
WACO Brother #233
Hide Signatures
(in reply to mogman)
       Post #: 15783
RE: WACO YMF - 1/1/2013 1:47 AM
WacoNut
Score: 175
Status: offline
Chuck,
I have used plain water and Windex and 50/50 ammonia water mix. All 3 will work but the water ammonia mix dry's the fastest followed by Windex then water.
Another tip for you that I discovered while building my 25% Waco was bending ply sheeting. If it is a failrly small piece (1/64-1/32) you can put it on a dinner plate and cover it with water and set it in the microwave on high for a minute and a half and it will make the plywood very flexible. You can then form it however you want and secure it until dry and it will hold the shape once dry.
I do plan on trying the method Mogman mentions about the dry glue method.
I used to always struggle with getting the L/E wing sheeting down and secure. One thing I have been doing on the last several builds is gluing the sheeting along the top spar and let it dry. Raise the sheeting and apply glue to the tops of the ribs then use a smooth 2" dia. metal pipe and start at the top spar and roll the sheeting down towards the L/E keeping firm pressure as I go. Once I reach the L/E apply some thin CA at the joint. It helps to have an extra set of hand while doing this especially on a large panel. It works well for me.
Later!!
Anthony
Hide Signatures
       Post #: 15784
RE: WACO YMF - 1/1/2013 9:59 PM
froghair1
Score: 100
Last Login: 6/16/2013
Status: offline
What a great day to fly WACO'S . Very light winds right down the runway for two hours, unfortunately, wind picked up and shifted to 90 deg to runway. All in all a great way to start a new year. Wishing all the brothers had just as good a day and 364 more of the same.
froghair1 waco brotherhood #127 if it aint broke, dont fix it
Hide Signatures
       Post #: 15785
RE: WACO YMF - 1/2/2013 12:09 AM
WacoNut
Score: 175
Status: offline
Must be nice,
33deg and windy here today with 6" of white crap on the ground.
Hide Signatures
(in reply to froghair1)
       Post #: 15786
RE: WACO YMF - 1/2/2013 12:57 AM
airplanegeek
Score: 100
Last Login: 6/15/2013
Status: offline
I managed to get the waco out of the rafters and dust it off....does that count as a New Years flight?
Hide Signatures
       Post #: 15787
RE: WACO YMF - 1/2/2013 1:14 AM
chuck l
Score: 108
Status: offline
I finished fitting the tail feathers on the Barth third scale Waco, they need sanding and covering before that can be permanently attached. The tail feathers are made as a separate assemble so they can be removed for transporting. Each elevator half is driven by its on servo. It's certainly a big plane, that's a 35% Extra next to it.
Click for fullsize
WACO Brother #233
Hide Signatures
(in reply to airplanegeek)
       Post #: 15788
RE: WACO YMF - 1/2/2013 3:25 AM
hopkimf
Score: 100
Status: offline
Chuck,
Looks great. Keep up the good work. Sure looks lighter than one I'm building.
Mike Hopkins Waco Brotherhood # 132.
Hide Signatures
       Post #: 15789
RE: WACO YMF - 1/2/2013 9:21 PM
Dash7ATP
Score: 130
Status: offline
Finishing issue
This question goes out to those who have used the MinWax Polycrylic over your fabric. I just bought a quart yesterday and I'm appying it over three coats of 50-50 thinned Nitrate dope.  I went over the surface very lightly with a 400 grit sandpaper and thid cleaned it off with a damp cloth to remove all dust.  I am getting a lot of very fine specs in my finish.  I went to my camel hair brush after I tried the sponge brush, Same results but to a lessor degree.. Are these specks dust or tiny bubbles.  Thery were not that easy to sand out.  I did not notice any of this with the dope.  Using this on the wings and tail surfaces don't pose the sanding over  the  ribs issue as I have pinked tape over all of those areas,  but the fuselage doesn't have the tape over the stringers, so I could very easily get the fuzzys there.
While I have only done the elevators and rudder as of now, I'm tempted to go back to the dope, as I still have almost an entire quart of Nitrate.  It's just hard to use it in the house, as my wife doesn't like the smell, and it's too cold to open the garage door....Brrrrrr............
So, what is the issue here?
TIA
Joe
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
       Post #: 15790
RE: WACO YMF - 1/2/2013 11:18 PM
Stickbuilder
Score: 346
Status: offline
They are tiny air bubbles. You didn't by chance shake the can did you? Don't do that, just stir it. They will easily sand out.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 15791
RE: WACO YMF - 1/3/2013 12:08 AM
WacoNut
Score: 175
Status: offline
Joe,
As Bill said stir not shake. I always gently stir the PloyC and go slowly with the brush to minimize the bubbles. If you are brushing across the fabric and you hear a zipper sound you are going too fast. When you give it a light sanding it will sand off the top of the bubble and the next coat will fill the space. The bubbles will basically be the thickness of the coat you just applied. These bubbles will appear less and less with each coat as the surface gets smoother. After 4-5 coats you should have a very smooth surface.
Did you try thinning the PolyC with water? Try a test sample thinned with approx 15% water and see if thet brushes down easier. I have done several planes this way and I pan on doing my 1/3 Waco again with this method.
Good Luck and let us know how it works out.
Anthony
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15792
RE: WACO YMF - 1/3/2013 12:38 AM
Dash7ATP
Score: 130
Status: offline
Bill and Anthony,
Bill, no I didn't shack the can, but stirred slowly.  I thought they might be small air bubbles, but a fefw were more difficult to sand out.  They could have been dust particals.  After two coats on the elevators, I'm beginning to see a nice build-up in the finish. I'm going to put at least one coat on the wings tonight, maybe two.  I have heard of putting some windshield washer fluid in latex to help it flow out.  Have you tried that on the PolyC?
As for the fuselage, I'm going to go with KlasKoat primer on the solid surfaces to try for the metal finish. Then I'll finish up with the PolyC on the fabric... I still have to attach the stab.  I thought it best to wait until I had averything else done on the efuselage to avoid banging it around.  I should be able to do that within a day or two.
I'm giving some serious thought to KlassKoat to my color coats.  Considering that the model is all white fabric and priomer, it shouldn't take much paint to get a good finish.
Thanks for the quick answers.  I'll be busy tonight for some time.  That brushing to avoid the bubbles takes time.
Joe
Hide Signatures
       Post #: 15793
RE: WACO YMF - 1/3/2013 12:44 AM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: skylarkmk1
Joe,
Hi John,
I still have hade no luck on the .pdf  plans. Every other .pdf file I have tried to open gave me no problem.
On another compuiter problem, I just recently went to Google Chrome as my brouser.  Now, my YouTube videos all stutter when opened.  I also can't get a DVD to play.  It may be telling me it's time to get a new computer.  I just can't stand the thought of getting all new programs and having to learn a new operating system (now on windows XP0.
Thanks for your thoughts,
Joe
Hide Signatures
(in reply to skylarkmk1)
       Post #: 15794
RE: WACO YMF - 1/3/2013 12:45 AM
hopkimf
Score: 100
Status: offline
WacoNut,
I have an old Ikon Monocoupe D145 covered with Solartex and never coated. Would it be a candidate for a number of coats of PolyC?If so, how many coats? It's a good old plane and I should do something to protect the fabric. It's winter here and I have time to do stuff. This is the wrong place for question, but ..
Hide Signatures
       Post #: 15795
RE: WACO YMF - 1/3/2013 12:50 AM
WacoNut
Score: 175
Status: offline
Joe,
Double check the date on your can, I have seen some of this stuff that has been on the shelves for a long time and you may see it starting to form some solids in the solution. If so the best option may be to strain the can before doing more coats.
I also do not brush out of the can but poar it into another container(butter bowl) and thin in there and keep the lid on after each use. You will see a plastic film start to form in the bowl where it has started drying. When this happens clean the bowl thoroughly before the next use.
Once you get the hang of how to work with PolyC it is a very good option over dope.
Later!!
Anthony
Hide Signatures
       Post #: 15796
RE: WACO YMF - 1/3/2013 1:28 AM
jlhambright
Score: 100
Last Login: 6/7/2013
Status: offline
Dear sirs, I have been reading your thread for several months now. It would be an honor if I could join the brotherhood. I started a 1/5 Waco, plans/templates from AMA. Just finishing up tail feathers, will start on lower wing next. I think I'll modify the tips as done earlier on this thread.
I want to make the stab adjustable; does anybody have an idea about the connection of the two stab sections? Have been looking at 5/32" brass tube with 1/8" music wire down the center, but haven't figured the best connection inside stab. Probably really simple, I am just an amateur compared to the fine craftsmen on this thread.
I have a DLE 30 to use in it so should have plenty of power also plan on using NC40112 for documentation, nice color scheme, I like it. Any comments, concerns or advice would be welcomed. Thanks, johnH
Hide Signatures
       Post #: 15797
RE: WACO YMF - 1/3/2013 1:41 AM
airplanegeek
Score: 100
Status: offline
N40112 is a fine ship to use. It is owned by my father and I fly it regularly. If you look back through I have posted pictures of me and Dad with our planes. AS for your stab idea, I am not the best to comment on that. Good luck with the project. Anxious to see the results.
Hide Signatures
(in reply to jlhambright)
       Post #: 15798
RE: WACO YMF - 1/3/2013 1:53 AM
jlhambright
Score: 100
Status: offline
Glad to hear from the owner, maybe in the future I could ask you a few questions about the plane. I have Bob Banka documentation foto
pac, but only 24 pic and no cockpit shots. I still have lots of questions about small things.
JohnH
Hide Signatures
       Post #: 15799
RE: WACO YMF - 1/3/2013 1:55 AM
airplanegeek
Score: 100
Status: offline
Here are some shots
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
