RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  634 635 [636] 637 638 639 640 641 642 643   next >   >>
Login
RE: WACO YMF - 1/17/2013 1:45 AM
hopkimf
Last Login: 5/16/2013
Status: offline
Bob,
If a plane is flying steady state, the four forces Lift, Weight, Thrust, and Drag are balanced. Take the same plane and add 10 lbs while retaining everything else. Lift is less than weight. It's going down. To overcome that, more thrust (higher speed) is needed to generate more lift. Higher speed means more drag. So addition of power is needed with weight change. It's back in balance again. I believe the relationship still holds.
Hide Signatures
(in reply to sensei)
       Post #: 15876
RE: WACO YMF - 1/17/2013 1:49 AM
sensei
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: hopkimf
Bob,
I agree, after reviewing the post over and over, that is why I change my question.
Bob
_____________________________
Fly It Like You Stole It!!!
Hide Signatures
(in reply to hopkimf)
       Post #: 15877
RE: WACO YMF - 1/17/2013 1:56 AM
Jaybird
Status: offline
I think the answer to your question is yes! All of those elements, in steady state (not accelerating or decelerating etc.) are balanced. Change one element and the others will automatically adjust. To get a specific result though, an element will have to be intentially changed.
Jaybird
Hide Signatures
       Post #: 15878
RE: WACO YMF - 1/17/2013 2:10 AM
hopkimf
Status: offline
Jaybird,
Appreciate your comments. But I still don't know where the center of lift for wing and tail are. If you draw a simple moment diagram, you could need tail down force or tail up force depending on location of centers of lift.
Hide Signatures
(in reply to Jaybird)
       Post #: 15879
RE: WACO YMF - 1/17/2013 2:25 AM
Jaybird
Status: offline
I'm baffled too when it comes to the models. The flight training manuals and operating handbooks for the full size aircraft I fly clearly show the center of gravity ahead of the center of lift which is where the tail downforce is needed to balance. The full size obviously have total weight limits for combinations of fuel, passengers and cargo. Performance changes depending on that total weight. It also has to be be within a certain acceptable range which varies with the total weight. Too much weight too far forward and you may not have enough tailforce to pick the nose up at slower speeds (like during the landing flair). Too much weight too far back and you may not have enough tailforce to push the nose down once it is airborn. I believe the full size trainer planes are designed with the C of G ahead of the C of L so that they will be more stable and "better behaved" and have a tendancy to seek a balanced state without a lot of pilot input. Perhaps higher performance aircraft have the two closer together so that they are less stable and therefore easier to move around it's axis.
For any particular aircraft design, the points where those elements occur are part of the engineering process. Most model plans only show a center of gravity point and not center of lift.
Jaybird
Hide Signatures
       Post #: 15880
RE: WACO YMF - 1/17/2013 2:52 AM
hopkimf
Status: offline
Jaybird,
I fly full scale as well. Much better than RC planes. Never wrecked one yet. I brought this up because I thought the subject has been ignored by the model side. Just balancing it isn't enough in my view. I would really like to know the theoretical approach needed to get the answers. Beside me is a text by Barnes McCormick,who was a prof at Penn State and a world class expert on Aerodynamics. I'm not about to grind through all of that, but would like a more simplified answer appropriate to RC planes.
Hide Signatures
       Post #: 15881
RE: WACO YMF - 1/17/2013 3:34 AM
Jaybird
Status: offline
Sorry, didn't mean to preach to the chior.
I agree 100%...the model side of aerodynamics seems more of a mystery than full scale. I look at a big Telemaster for instance and notice that the stabilizer is a large flat bottom UPRIGHT airfoil just like the wing! How can that NOT produce upward lift all the time? I look at my 1/6 scale Concept Fleet and the stabilizer is also a flat bottom upright airfoil with positive incidence. That kind of puts the tail downforce out the window too, or at least would seem so.
Calculating the information you are looking for is far beyond anything I could get even get close to.
I do know the GP WACO ARF has -1 incidence on the top wing and +2-1/2 on the symetrically shaped stabilzer and it flies great!
Good luck on your search. If you do find a answer please share it.
Jaybird
Hide Signatures
       Post #: 15882
RE: WACO YMF - 1/17/2013 12:05 PM
sensei
Status: offline
quote:
ORIGINAL: Jaybird
Jaybird
All airfoils with the exception of an asymmetric airfoil require a AOA component to produce lift, when your flying your wing will assume it's own AOA needed to carry the load, but that doesn't necessarily mean that your horizontal stab is carrying any + or - AOA, it is really more of how the designer set up the aircraft, the chosen airfoil, the AOI in regards of wing, fuselage center line and horizontal stabilizer relationships and so on. In this picture you can clearly see that I set up the horizontal stabilizer with 3 degrees positive AOI, and had the wing set at 0 AOI in relation to the FCL. Note that the paint trim line is running parallel to the FCL.
Bob
Click to see fullsize image.
Click for fullsize
< Message edited by sensei -- 1/17/2013 1:18 PM >
Hide Signatures
       Post #: 15883
RE: WACO YMF - 1/17/2013 12:07 PM
Stickbuilder
Status: offline
The issue that we get into have to do with Reynold Numbers. Full Scale airplanes differ from models due to the effects of Scale Volume, not Linear scale. The bigger the model, the more like the full scale it becomes. For example, a cube that is 4"X4"X4" will have a volume of 64 cubic inches. (4X4=16X4=64) A quarter scale model of that cube is 1X1X1 which yields a volume of 1. Even though the linear scale is one fourth the size of the full scale, the volume is much different. Hope this helps you see the difference.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 15884
RE: WACO YMF - 1/17/2013 12:55 PM
sensei
Status: offline
quote:
ORIGINAL: Stickbuilder
The issue that we get into have to do with Reynold Numbers. Full Scale airplanes differ from models due to the effects of Scale Volume, not Linear scale. The bigger the model, the more like the full scale it becomes. For example, a cube that is 4''X4''X4'' will have a volume of 64 cubic inches. (4X4=16X4=64) A quarter scale model of that cube is 1X1X1 which yields a volume of 1. Even though the linear scale is one fourth the size of the full scale, the volume is much different. Hope this helps you see the difference.
This is actually a good point to bring up, for the very reason that the effects of scale volume are not linear. The larger an airframe, the more efficiently it will carry weight, that is why lets say a full scale Extra 300 weighing in at around 1400 lbs. empty performs very well at that weight. Now take a half scale Extra 300 and weigh it down 700 lbs. and it is not going anyplace, in fact at half scale weighing it down to 100 lbs. and it is a real pig. Now lets get down to small aircraft anything 1/4 scale or less. The smaller the airplane the more important it is to build as light as possible, because the Reynolds numbers are working against you from a load carrying efficiency standpoint.
Bob
< Message edited by sensei -- 1/17/2013 1:20 PM >
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15885
RE: WACO YMF - 1/17/2013 1:58 PM
Dash7ATP
Status: offline
This is a very interesting discussion.  One thing does not change. The wing has to fly at an angle of attack (AOA) at any given speed that will allow it (the wing) to produce enough lift to support the weight of the aircraft..If the plane appears to be "dragging it's tail", but still maintinaing altitude, then lift vs weight (gravity) is balanced.  The plane is either too slow, too heavy, or the wing is mounted at the wrong incidence angle on the fuse. What ever is going on with the stab/elevator is just what is neccesary to maintain that AOA.
IF the aircraft is tail heavy, You just can't trim it out to fly in a stable mannor; ie, hands off. I was a commercial pilot, and on a charter flight I did early on in my carrier, I flew a load of water bottles to a lab to be analyzed for a new treatment plant.  I was in a Cessna 206. All of the seats were taken out and the bottles, about ten gallons each, were spread out on the floor and strapped down with a cargo net.  As soon as I broke ground, the nose pitched up.  I went forward on the elevator, and it pitched down.  This continued all the way for the 300 mile flight. I pulled my seat as far forward as possible, but it was not enough.  I was afraid I would not be able to land as the oscillations continued all the way to touchdown.  We had all assumed we would be OK with the CG.  Wrong,
As for the lifting tails on some models, Guess what?  Some models are designed with a very aft CG . Competation  free flight models ,YES, often have a CG back around 50 to 60 percent of MAC, but they all have stabs that are a large percentage of the total area., and they produce lift. The idea is that it's more effecient to have all of the flight surfaces contributing to overall lift, rather than having the tail exererting a down force
I know, this has not helped this discussion, but only muddied the water.  It sure seems to me that a positive incidence on the stab (LE up), would seem to indicate a slightly aft CG by design. The large tail plane would seem to support that.
Joe
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
       Post #: 15886
RE: WACO YMF - 1/17/2013 2:25 PM
peterduplessis
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: sensei
Bob
Using your example of the Extra 300 weighing 1400 lbs (power to weight ratio of 0.2143)... a third scale would theoretically be 1/27th (3x3x3) =51 lbs .. (mm a little heavy on the wing loading!) with 11hp (300hp/27) same power to weight ratio... will fly probably quite realistically compared to the fullsize in terms of take-off and stall speed performance. As modellers, Have we not just become more accustomed to having more power to weight (that 1/3rd scale Extra would typically weigh around 30-35 lbs) to get the adrenalin pumping? Peter, #224
Peter du Plessis
Waco Brother #224
Hide Signatures
       Post #: 15887
RE: WACO YMF - 1/17/2013 3:50 PM
LesUyeda
Status: offline
" The wing has to fly at an angle of attack (AOA) at any given speed that will allow it (the wing) to produce enough lift to support the weight of the aircraft"
Only for symmetrical airfoils.
Les
Hide Signatures
(in reply to peterduplessis)
       Post #: 15888
RE: WACO YMF - 1/17/2013 4:10 PM
sensei
Status: offline
quote:
ORIGINAL: peterduplessis
quote:
ORIGINAL: sensei
Bob
Using your example of the Extra 300 weighing 1400 lbs (power to weight ratio of 0.2143)... a third scale would theoretically be 1/27th (3x3x3) =51 lbs .. (mm a little heavy on the wing loading!) with 11hp (300hp/27) same power to weight ratio... will fly probably quite realistically compared to the full size in terms of take-off and stall speed performance. As modellers, Have we not just become more accustomed to having more power to weight (that 1/3rd scale Extra would typically weigh around 30-35 lbs) to get the adrenalin pumping? Peter, #224
No, the smaller you go, the less efficient the lifting capacity is, your forgetting about the Reynolds numbers working against you the smaller you go.
Bob
Hide Signatures
       Post #: 15889
RE: WACO YMF - 1/17/2013 4:13 PM
sensei
Status: offline
quote:
ORIGINAL: LesUyeda
'' The wing has to fly at an angle of attack (AOA) at any given speed that will allow it (the wing) to produce enough lift to support the weight of the aircraft''
Les
All airfoils need AOA to produce lift with the exception of an asymmetric airfoil.
Bob
Hide Signatures
(in reply to LesUyeda)
       Post #: 15890
RE: WACO YMF - 1/17/2013 4:16 PM
Jaybird
Status: offline
Don't all airfoils need some AOA to the relative wind to produce lift?
AOA (angle of Attack) happens during flight in relationship to the relative wind and is different than AOI (Angle of Incidence) which part of the structural design.
What was the question again?
Jaybird
Hide Signatures
       Post #: 15891
RE: WACO YMF - 1/17/2013 4:26 PM
sensei
Status: offline
quote:
ORIGINAL: Jaybird
Jaybird
Yes, except an asymmetric/cambered airfoil. Don't take my word for it, Google it.
Bob
Hide Signatures
       Post #: 15892
RE: WACO YMF - 1/17/2013 8:12 PM
nine o nine
Status: offline
Who is this guy Reynolds??? Why did he screw everything up??? Lift generation??
According to the Bernoulli venturi principle it's the "separation of air molecules" allowing a low pressure area on the top surface of the wing????? That's what I taught when I was a certificated flight instructor....how many years ago was that???
Just kidding around. The whole basic aerodynamics discussion is fun. Mitch
Hide Signatures
       Post #: 15893
RE: WACO YMF - 1/17/2013 8:15 PM
Jaybird
Status: offline
Almost as much fun as the "why don't people build kits anymore" converstion on the other thread!
Jaybird
Hide Signatures
(in reply to nine o nine)
       Post #: 15894
RE: WACO YMF - 1/17/2013 8:23 PM
FMBB
Status: offline
Hi Joe,
symmetrical airfoil was chosen to have a better inverted flight performance. If you fly upside down with Clark Y your AoA has to be awfully high which in my opinion does not look nice. With the symmetrical airfoil you AoA is much lower and your nearly can fly straight and level. That was the reason for this airfoil. A customer did built it with the Clark Y flies good as well but inverted see above.
Peter
Waco Brother #170
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15895
RE: WACO YMF - 1/17/2013 8:32 PM
FMBB
Status: offline
Barry,
sorry fro not mentioning the CG in the plans but the CG is max. 2 cm in front of the aft cabane struts on the upper wing center section if you weight it in more to the front it is nose heavy which is not such as critical as tail heavy but....
Peter Waco brother #170
Hide Signatures
(in reply to bhall01)
       Post #: 15896
RE: WACO YMF - 1/17/2013 8:41 PM
FMBB
Status: offline
To All,
just to make it clear:
upper wing 0 to minus 2 degrees
lower wing 0 degrees
horizontal stab 2 degrees leading edge up
CG just in front of the aft cabane strut about one to two fingers width.
That's how the Barth Wacos should fly and I do fly them.
Peter
Waco brother #170
Hide Signatures
(in reply to WacoNut)
       Post #: 15897
RE: WACO YMF - 1/17/2013 8:55 PM
Dash7ATP
Status: offline
quote:
ORIGINAL: FMBB
Hi Joe,
Peter
Waco Brother #170
Thanks, Peter,
I assumed it had to do with aerobatic preformance, but I wanted to make sure I wasn't missing something.
Joe
Hide Signatures
(in reply to FMBB)
       Post #: 15898
RE: WACO YMF - 1/17/2013 9:24 PM
sensei
Status: offline
The designer bearers the burden of making all these structural and aerodynamic decisions, and he must consider many tradeoffs along the way.
Bob
< Message edited by sensei -- 1/18/2013 12:59 AM >
Hide Signatures
       Post #: 15899
RE: WACO YMF - 1/18/2013 8:37 AM
RCplanman
Last Login: 4/24/2013
Status: offline
jaybird,What is the incidence of your bottom wing.?
Bill
Hide Signatures
       Post #: 15900
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.453RCU1
