RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  636 637 [638] 639 640 641 642 643 644 645   next >   >>
Login
RE: WACO YMF - 1/19/2013 5:10 AM
RCBOATMANIAC
Score: 100
Last Login: 5/2/2013
Status: offline
quote:
ORIGINAL: hopkimf
On my Pepino 1/4 scale Waco, I went with two servos for ailerons. Why does the GP need four?? Pretty easy to link the second aileron. Or am I missing something??
Mike Hopkins
Nope not missing anything it's just for some reason Great Planes thought that is was a good idea to setup both wings with servos and it doesn't come with any control rod to use between the ailerons. I think it is a waste if two servos.
_____________________________
Dave, WACO BROTHERHOOD #88/Club Saito #576
Happiness: Smell of burnt nitro in the air linked to a high speed boat.
Hide Signatures
(in reply to hopkimf)
       Post #: 15926
RE: WACO YMF - 1/19/2013 8:18 AM
RCplanman
Score: 105
Last Login: 4/24/2013
Status: offline
rcboatomatic, Dave what I've done is sandwitch the rod between2 pc.''s of maybe 3/32 balsa & then sand that to a airfoil shape. Out at that thin edge you could also put a small piece of 64th ply top & bottom and then cover that w/ your covering would make it pretty strong. A thought.
Bill
WB126
Hide Signatures
(in reply to RCBOATMANIAC)
       Post #: 15927
RE: WACO YMF - 1/19/2013 10:40 PM
Jaybird
Score: 112
Last Login: 5/18/2013
Status: offline
Finished up mounting the javelins to the flying wires and made up some telescoping aileron connecting rods today...great fun! I used some piano wire, brass tubing, aluminum airstream tubing, brass threaded solder ends and metal clevises to make the pushrods. The horns are cut down nylon horns that were heated up and bent to the correct angles for both sides. The top clevis is on a section of rod riding inside a brass tubing sleeve with a short section soldered to the end to act as a stop. Once mounted in the aluminum it can slide freely about an inch but is trapped and won't fall out. I have left them the bare aluminum at this point as it's quite cold in the house and even colder outside so spray painting will have to wait until spring. It took a bit of fiddling to get the first one to slide smoothly but the second one was a piece of cake.
While I had it all together I took the opportunity to weigh it...it comes in around 13 lbs best I can tell with bathroom scales.
Now I can take the wings back off and start on the center section fuel tank detail and then the dummy engine. The flying wires are anchored to the fuselage and clip to brackets on the wings for quick assembly.
Good day to be inside!
Jaybird
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to RCplanman)
       Post #: 15928
RE: WACO YMF - 1/19/2013 11:29 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: CAPT. DAN
Stickbuilder,
I recently bought a Byron FPN7 Waco. The price range you quoted was in line with what the previous owner was asking,
and the incidence +2 Top Wing, 0 Bottom Wing , and +2 Stab was also in the same general area. i hope these planes catch the eye
of modelers since they are in my opinion great looking and supposedly very good flyers.
Dan
I'd expect a little difficulty in your landings with that incidence set-up. Why positive incidence on the upper wing? That will make it stall first.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to CAPT. DAN)
       Post #: 15929
RE: WACO YMF - 1/23/2013 12:07 AM
WacoNut
Score: 175
Last Login: 5/19/2013
Status: offline
Hmmmm,
Nobody doing anything with their Waco's? I will start covering the 1/3 again this weekend.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15930
RE: WACO YMF - 1/23/2013 12:09 AM
Jaybird
Score: 112
Status: offline
I've been working on my ARF (see above) and continue to work on the dummy engine. I plan to mount it to the battery box and firewall rather than to the cowl. I also picked up some parts to make the simulated fuel caps on the center section.
Hopefully that counts!
Jaybird
Hide Signatures
(in reply to WacoNut)
       Post #: 15931
RE: WACO YMF - 1/23/2013 12:17 AM
WacoNut
Score: 175
Status: offline
Yes it does
Just been awful quiet here the past few days, figured I would wake someone up
Anthony
Hide Signatures
(in reply to Jaybird)
       Post #: 15932
RE: WACO YMF - 1/23/2013 1:01 AM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: WacoNut
Yes it does
Anthony
Looks like your going to have her back in the air real soon.
Bob
Fly It Like You Stole It!!!
Hide Signatures
       Post #: 15933
RE: WACO YMF - 1/23/2013 2:30 AM
WacoNut
Score: 175
Status: offline
Bob,
The Waco will take a good long while to cover, detail and paint. I don't think it will see a re-maiden until May or early June. I am sure the plane will be ready before the pilot I will get plenty of stick time on my other planes before the Waco will see the air.
Later!!
Anthony
Hide Signatures
(in reply to sensei)
       Post #: 15934
RE: WACO YMF - 1/23/2013 11:21 AM
lazyace
Score: 100
Status: offline
not a waco but I have been working on a plans built 32% dr-1 almost done
Click for fullsize
Click for fullsize
Click for fullsize
charlie AMA 8916
WACO brotherhood #67
Hide Signatures
       Post #: 15935
RE: WACO YMF - 1/24/2013 10:19 PM
Dash7ATP
Score: 130
Status: offline
I'm awake!  Just been busy on the Waco. I finally attached the stab and rudder. Over the weekend, I made up my first set of wires for the tail bracing.  I thought it might be of interest to anyone looking for a nice set of hardware. The fork ends (as they are called by Mick Reeves) and flat wire, as well as the pinked tape came from Mick Reeves.  This is the 1/16" wide wire. I also have some 3/32" I'll be using on the flying and landing wires when I get to the wing. While I"m not 100% satisfied with my final results on how the silver soldering looks, I started with the tail for practice.  It's a simple matter to go back and heat it up again and re-do it. The trick is to make it appear as though the wire joint is coming from the center of the threads and are a part of them...  I have a little ways to go with that.
As for the rudder / stab joint, I'm doing some filling with the light spackle to try to make it appear as a screwed on fairing. We'll see how that goes in a few days.
I stuck my thumg in one of the shots for size reference.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to lazyace)
       Post #: 15936
RE: WACO YMF - 1/25/2013 12:06 AM
chuck l
Score: 108
Status: offline
Dash7ATP
What covering are you using?
Chuck
WACO Brother #233
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15937
RE: WACO YMF - 1/25/2013 12:17 AM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: chuck l
Dash7ATP
Chuck
HI Chuck,
I went with KoverAll. At this point it has four coats of 50/50 (reduced) NItrate dope and two coats of MinWax PolyCrylic.  I'm about ready for some color as soon as I finish up the fillits, etc.
Joe
Hide Signatures
(in reply to chuck l)
       Post #: 15938
RE: WACO YMF - 1/25/2013 3:02 AM
chuck l
Score: 108
Status: offline
Joe,
What did you thin the nitrate with?
Chuck
WACO Brother #233
Hide Signatures
       Post #: 15939
RE: WACO YMF - 1/25/2013 3:04 AM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: chuck l
Joe,
Chuck
Sig dope thinner.
Hide Signatures
       Post #: 15940
RE: WACO YMF - 1/25/2013 3:58 PM
LesUyeda
Score: 151
Status: offline
" While I"m not 100% satisfied with my final results on how the silver soldering looks,"
If you were to find some heat shrink tubing in a color close to your base, or trim color, and cover the joint, it may please you better, and no one else would be able to see.
Les
Hide Signatures
       Post #: 15941
RE: WACO YMF - 1/25/2013 4:15 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: LesUyeda
Les
HI Les,
Thanks for the suggestion. It's a little too late for that now without de-soldering one end to slip the heat shrink over the wire.  I'll give that a try on my next set of wires to see how I like it.  I can always go back.....
The trick to making these look like they should is to grind an angle on the end of the threads. When the flat wire is soldered to it, then ground down properly, it should look pretty close to the ends of the full scale wires or even the ones sold at our scale that are made in Europe and high $$$.
Thinking ahead a little, I'm just wondering how you guys are doing the javilin on the wing wires and still have the ability to take the wings off or adjust the tension. You have to rotate the wires to make any adjustments or to loosen them up for disassembly.  The closer I get to finished, the more I'm concerned that I won't be able to get this in my Caravan fully assembled. Has anyone else tried that?
Joe
Hide Signatures
(in reply to LesUyeda)
       Post #: 15942
RE: WACO YMF - 1/25/2013 5:07 PM
mogman
Score: 100
Status: online
quote:
ORIGINAL: Dash7ATP
Joe
Joe, on my 40% I have used very small rubber bands, "O"rings etc,(picture) but the vibration kept breaking some of them. I now use very small zip ties...no more issues. Not very scale, I know, but no one notices when it's flying past. My Waco is not a "scale" model, it looks and sounds good in the air. That works for me.
Cheers,
Dave.
W/B #180
Sorry, I don't know why the post appeared like this...
Click for fullsize
< Message edited by mogman -- 1/25/2013 5:36 PM >
Hide Signatures
       Post #: 15943
RE: WACO YMF - 1/25/2013 5:49 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: mogman
quote:
ORIGINAL: Dash7ATP
Joe
Cheers,
Dave.
W/B #180
Dave,
Thanks for your remarks.  I can see how the rubber bands could be a problem.. The zip ties could work on my model as well. The bottom line is that they have to be easily removed and replaced.  This gives me something to work with.
Joe
Hide Signatures
(in reply to mogman)
       Post #: 15944
RE: WACO YMF - 1/25/2013 5:59 PM
Jaybird
Score: 112
Status: offline
I used 2-56 pull-pull set with threaded couplings and clevises from DU-BRO on my smaller GP WACO ARF. See posts 15844 and 15928. The wires are the nylon coated cable included in the kits which are anchored to the fueslage and upper wing center section and clipped to small brackets on the upper and lower wings. The javelin is secured to the wires and when the four lines are unclipped from the wing it can just hang or be stuffed into the cabanes for transport. All wires can then be adjusted at the threaded couplings if needed.
The 4-40 pull-pull cable set might be closer the right size for the larger model.
Jaybird
p.s. Sorry, looking again (now that the other pictures are there) i can see my system won't help with yours since you have to spin the whole flying wire and not just the clevis on the end.
< Message edited by Jaybird -- 1/25/2013 10:04 PM >
Hide Signatures
       Post #: 15945
RE: WACO YMF - 1/26/2013 12:04 AM
WacoNut
Score: 175
Status: offline
Chuck,
I do not use dope for filling the weave just atatching the fabric. When I thin the dope I use a good quality laquer thinner. If I were going to be using the dope for filling the weave and finish color with dope I would use the dope thinner to match the dope I am using.
I have not seen any ill effects from using laquer thinner to thin the dope for attaching the fabric. I had a tough time removing the fabric from my 33% Waco after the crash to access the damage.
As far as the Javelins on the flying wires go I have seen Waco's with the wires thru the javelin and secured by wrapped string coated with a sealer(dope?) and a couple that were actually secured with zip ties. I had mine secured with zip ties and on display at the Waco museum and a spectator made mention that my plane looked great but he thought the javelins just didn't look right with the zip ties holding them on. About a half hour later he came back and appologized for his comment as there were 2 Waco's parked that had zip ties holding the javelins on
I installed new flying wires the day before the crash and had the wires going thru the javelins. Will most likely do the same this time around.
Later!!
Anthony
Hide Signatures
       Post #: 15946
RE: WACO YMF - 1/26/2013 1:12 AM
chuck l
Score: 108
Status: offline
Guys I need help. I'm trying to bend the leading edge sheeting on the tip of the third scale Waco wing. The piece of balsa is about 8" long by 3mm thick and wraps ok in the flight direction. However it is really tough to bend in root to tip direction. Soaking the balsa with 50/50 ammonia/water helps, but not much. How can the balsa be softened more so it will stretch and conform to the shape. One option is to go to a thinner sheet. Any and all suggestions would be appreciated.
Chuck
WACO Brother #233
Hide Signatures
       Post #: 15947
RE: WACO YMF - 1/26/2013 1:38 AM
Dash7ATP
Score: 130
Status: offline
Chuck,
Ohe option would be to cut a thin sliver of a wedge to allow it to make the bend. It should not take much. If you are carefuyl, and use a wood (white) glue in the joint, it will sand without liaving a ridge and you'll never know you cut it.  Compound curves can be a problem sometimes.
Are you a member of the Waco Brotherhood? I don't see you mentioining it here. (Not that it makes a difference).  If not all you need do is mention it and Bill will take care of that!
Joe
Hide Signatures
       Post #: 15948
RE: WACO YMF - 1/26/2013 3:24 AM
Jaybird
Score: 112
Status: offline
I finished up the center section on my GP ARF this evening. I made up some fuel filler caps with dowels and fuel line plugs and the tank vents with assorted brass and steel parts. I think they came out pretty well and give the illusion of detail. Next is the dummy engine. But tomorrow is a trip to Owls Head to drop off the 1/6 scale Top Flite SE5a that they have accepted as a donation. There is also a seminar on bird and aircraft flight characteristics that should be fun. Then I'll visit my daughter-in-law and 3 month old grandson who live nearby.
Jaybird
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15949
RE: WACO YMF - 1/26/2013 3:39 AM
skylarkmk1
Score: 210
Status: offline
Guys,
These pictures are of the Javilin on NC 14081 a 1987 YMF built by Waco Classic Aviation. This is just one example on a full scale Waco.
Click for fullsize
Click for fullsize
Click for fullsize
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 15950
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
