Stickbuilder
Score: 346 Joined: 11/20/2005 Last Login: 5/18/2013 From: Wildwood,
FL, USA Status: offline
I bought the Pica YMF 3/5 on ebay yesterday. I have offered it to 2 kit cutters to see if they would be interested in reproducing this one. I believe that the Copyright has expired on this kit, and PICA is no longer in business. I need a little help here. all who would be interested in a new kit of this model, please let me know. These are business people, and they will want an idea of the demand for this one prior to making this kind of investment. <<Moderator Edit: Edited to add thread index at the request of the members of this thread.>> Pica Waco YMF Index (Just click on the post number and it will take you to that post) Most items of interest are included and this index also references the Barth YMF, Jim Pepino YMF and other threads that may have information pertinent to the subject. It is likely that some items have been overlooked and not all items listed. Suggest looking at a few posts before and after the selected post to see if your question is answered. Or post your question. Thanks to SuperCubMan (WB #56) for compiling most of the index (I added a few more), CTflyboy (WB #5) for tipping me off on the index and putting me in touch with Ken Isaac, RCU Moderator, who gave me the format to convert the index and for inserting it in this thread. Skylarkmk1 (WB #26). Additional info can be found on the House of Moy supplemental Site http://www.houseofmoy.com/waco/ Ailerons 1878, 2307, 2849, 2854, 3041, 3054, 3079, 391(Barth), 3809, 3811, 1491, 1509, 3747, 3754, 4006, 83(Barth), 91(Barth), 4097, 3373 Cockpit 174, 172, 2324, 2590, 2843, 2849, 2993, 2997, 116, 108(Barth), 410(Barth), Cockpit – 1930s 1920, 2995, 3335 (SRE), 3646, 3650, 3651, 3652, 3659, 3660, 3670 Cockpit – Classic and Supers 2993, 2997, 1929 Covering 1783, 1784, 1785, 1786, 1787, 1792 Cowl 3401, 3402, 4202, 4208, 4221, 4228, 4432, 4874, 4877, 4878, 4881, 4890, 4941 Flying Wires 195 (Barth), 199 (Barth), 201 (Barth), 2322, 4087, 4093, 4499 Fuselage – Construction 1801, 1806, 1595, 2009, 2221, 2545, 2687, 3126, 1 (Barth) Fuselage – Hatch – Model 98 (Barth), 1386, 1395, 1404, 1694, 2319 Full Size 213 (Pepino), 3304, 3323 Windscreen 172 (Barth), 1591, 2194 Front Cockpit 1412 Landing Gear – Sprung 1471, 3898 Aluminum Sheet 3028, 3036, 3053, 3063, 3129, 3132, 3138, 3208, 4701 Full Scale YMF Fairings 2909, 2923, 2931 Center Spring Wire Gear 35 (Barth), 37 (Barth), 40 (Barth), 1646, 1649, 3993, 4526, 4530, 4546, 4548, 4550, 4551 Hatch 1628, 1649 Covering 4902, 4903, 4904 Engine – G-26 2829, 3853 Engine – Saito 160 Twin 16, 19 Engine – Saito 120 58 Engine – Saito 170 Radial 155, 2996 Full Size 1959, 1963, 1964, 1965, 1969, 4059, 4111 Dummy 883, 931, 4055, 4057, 4058, 4060, 4062, 4085, 4121, 3675 Exhaust 722, 337 (Barth) Fuel Dot 1696 Prop 4067, 4069 Rudder Trim Tab 3102, 3103, 3112, 374 (Barth) Rudder Details 2933, 2938 Rudder Control Horns 1690, 1791 Adjustable Stab 1620 Struts and Cabanes – Wing 3126, 350 (Barth), 351 (Barth)], 353 (Barth), 3889, 4882, 4887, 4888. 4889, 5009, 5012, 5243 Strut – Brazing 4971 Tail Wire Bracing 4921 Wheels – Full Size Tail Wheel 2786, 2803, 78 (Pepino), 2963 Model Tail Wheel 719, 720, 1050, 1051, 1052, 1063, 2221, 68 (Pepino), 69 (Pepino) Tail Wheel – Spring loaded 2512, 2538, 2575, 2937, 3024 Wings – Struts 351 (Barth), 353 (Barth), 754, 755, 2907 Wing Tips – Model 2395, 2398, 2540, 2946 Wing Tips – Full Size 2542, 2543, 2699 Wing/Fuselage Fairing 159, 167, 455, 2522, 5235 Wing Dihedral/Brace 80, 85, 88, 300, 2686 Wing – Tank Cover 2951, 4157, 4161 Wing Servo Mounts 754, 755 Wing Aileron Hinges 3995 Lights – Wing Tip – Navigation – Landing 3439, 3442, 3661, 3678, 3679, 3681, 3683, 3684, 3777, 3786, 3787, 4065, 403 (Barth), 4386 General Detail – Logos – Data Plates 1924, 3000, 1407, 4115, 4118, 4376, 4384, 16 (Barth), 4352 Locks, Latches, Screws and Panels 1910, 3336, 1818, 1833, 1859, 47 (Barth), 54 (Barth), 64 (Barth), 67 (Barth) Completed Models 59, 60 (Barth), 101, 128, 184, 189, 257, 306, 348, 383, 462, 498 (Barth), 499 (Barth), 3637 2318, 2319, 2320, 2322, 2324, 1858, 1863, 4125
< Message edited by RCKen -- 2/18/2008 8:06 AM >
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
