RE: WACO YMF    Gallery
Logged in as Guest
Users viewing this topic: mogman
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: WACO YMF - 10/29/2006 8:22 AM
Hughes500E
Score: 105
Last Login: 6/19/2013
Status: offline
Here's an updated picture, looks like I'll be starting on those wing fillets myself soon
I'm thinking I may have bent my landing gear a little off!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Hughes500E)
       Post #: 176
RE: WACO YMF - 10/29/2006 1:17 PM
Stickbuilder
Score: 346
Status: offline
The mains are 4" I used the no bounce Sullivan's. The tailwheel is a 1 1/4 something or other... (sorry don't remember the brand)
Wives are like that. Mine wants the WACO for herself, so I'm going to have to blow another one up to have one for me. That's my excuse, and I'm sticking to it.
Bill, AMA 4720
WACO Brotherhood #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 177
RE: WACO YMF - 10/29/2006 1:20 PM
Stickbuilder
Score: 346
Status: offline
If you are not happy with the amount of toe-in on the mains, now is the time to mend the situation. You will probably have to re-solder the joint if you add heat to bend the gear. They need about 1 degree of toe-in to track straight.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 178
RE: WACO YMF - 10/29/2006 1:36 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: old git
Hi again Stickbuilder,
I wonder "what" you are buffing after using 2000 grit. Painting vehicles, the only time I used 800+ was to remove the edges of stripes that had been produced by masking. The rest of the work was done with rubbing compound on a sponge using a dual action (DA) air sander. I am only asking for clarification, I am not and never was very good at producing a good finish (great at watching and making suggestions) I have used a hard masked edge and a rolled edge on the top (for stripeing) so the finish had finer "edge-less" paint at the masked edge.
It's about fifteen years since I did any painting (I've been retired over 8yrs) but I have just replaced the compressor I built over 40yrs ago, I didn't trust the receiver any more. I bought a 14cu ft FAD and a couple of proper guns to replace my old constant bleed gun and the one I LOANED to a friend.
The purpose of my questions is to see how relevant my experience of spraying will be on model aircraft. For models, I previously used shrinking dope, silver cellulose (for lightness) and covered it with a coat of automobile colour followed by single pack (furniture) polyurethane for fuel resistance and got an amazing gloss despite the occasional ugly nibs showing.
The model I have in mind for painting is the Bud Nosen Mr Mulligan kit I purchased on eBay with the new Zenoah G-38 to power it. I rather foolishly paid full price for the motor from a hobby shop in the USA. It arrived with the full price declared and the revenuers took great pleasure in charging me a considerable sum in import duty.
By the way, much as I love the Golden Age aircraft, I still think you are hiding a Spitfire somewhere, LOL.
old git - - - - -aka John L.
Hiding a Spitfire somewhere? ... Hmmmmm...
If you could talk me into building any Supermarine designed airplane, It would, in all probability, be a Spitfire. Perhaps a Reconnisance model, one of the light blue ones with the camera pod, perhaps a Mk IV with the Hood. It is a fairly obscure version, but I think that it would be well received within the scale world. What do you think? I'm not opposed to, just tired of seeing the same old P-51/P-47 non scale outline pieces of crap that crowd the flightlines. I'm so over the run of the mill planes that have been done to death. I've been thinking about one of the Biplane carrier fighters of the United Kingdom, but the R-variant of the Spit sounds pretty good. I have a Moki 3.6 inline twin that would make one of these really sing. A pair of tuned pipes ducted to scale outlets would sound pretty good. Will need a scale 3 or 4 blade prop for this to work well. It would need to be a fairly large model for the big Moki to work well with. This is a large engine. It's about 10" from the backplate to the prop washer and there is a C&H ignition package that has to be accounted for. With the shorter nose moment and longer tail moment, it sounds about right for the Spit/Hurricane. Keep digging at me... I might just roll over for this one.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to old git)
       Post #: 179
RE: WACO YMF - 10/29/2006 6:52 PM
Jim Henley
Score: 120
Status: offline
Bill,
I guess it is like reworking an old house, first you have to tear the place up, then you fix it correctly. I don't see a datum line on the plans what / where do I measure against? I had placed a short level on the motor mount, blocked the fuse to bring that motor mount level, then used another level to check the stab. That was where I discovered that the stab appeared to have 0 degree incidence. Is using the motor mount the correct way to establish my base line or is there a better way? Also guess I need to pick up an incidence meter to make sure I am right on.
Jim
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
(in reply to Stickbuilder)
       Post #: 180
RE: WACO YMF - 10/29/2006 10:48 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Jim Henley
Bill,
Jim
The fuselage crutch should be the datum line, but yes, you should invest in an incidence meter. This won't be the only time that you will use it. Using the motor mount might work, I've never used it as a datum line though. There are too many ways to mess that one up. Did you notice that the plan does not call for any down or right thrust. I have never needed any with this one. The full scale does not have any down thrust or right thrust built into the engine mount as well. That's what the stick and rudder pedals are for.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to Jim Henley)
       Post #: 181
RE: WACO YMF - 10/30/2006 1:35 AM
old git
Score: 100
Last Login: 12/26/2011
Status: offline
Hi Bill,
I was just having a silly prod at your "sand off the excess" signature ending. I appreciate what you say about the commonplace but they are not commonplace to me. A blue spitfire should be rather fetching, I'd venture there's probably one at OSKOSH (Spelling?) Nevertheless I really love your Waco. Dicknadine in another thread was planning an Arc en Ciel Airliner, that was a really uncommon aircraft. Alas it came to nothing, his house was demolished by Katrina and he lost everything but his life and wife.
quote:
ORIGINAL: Stickbuilder
Hiding a Spitfire somewhere? ... Hmmmmm... - - - - -
- - - - - -If you could talk me into building any Supermarine designed airplane, It would, in all probability, be a Spitfire. Perhaps a Reconnisance model, one of the light blue ones with the camera pod, - - - - -... I might just roll over for this one.
Bill, AMA 4720
WACO Brotherhood #1
For some reason I am unable to upload pic's. I found a two seat job that is I believe flown by the widow of the builder/rebuilder. She gives rides which must be a real buzz for non pilots. My uncertainty is if this is the self same aircraft
Two seat Spitfire
Supermarine 509 Spitfire T9
Fishburn - Morgansfield / West House Farm
UK - England, August 25, 2005
G-CTIX / PT462/SW-A Built as an HFIX single seat variant, 462 flew with 253 Sqn in WW2 and latterly with the Italian and Israeli Air Forces. Converted to a TR9 two seat by Charles Church, she now resides in Wales.
old git - - - - aka John L.
Hide Signatures
       Post #: 182
RE: WACO YMF - 10/30/2006 3:10 AM
Stickbuilder
Score: 346
Status: offline
I screwed it together this evening. Still need to do the cream color (colour for John) trim, but I'm getting real close.
Bill, AMA 4720
WACO Brotherhood #1
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 183
RE: WACO YMF - 10/30/2006 4:49 AM
Jim Henley
Score: 120
Status: offline
Verrry Nice! Cream trim, will it be along the same lines as the decal sheet or do you have more magic up your sleeve?
BTW, thanks for the advice on the datum line. I checked the measurements on the plans then checked the stab position on my model, and they are very close. However I still want to check with an incidence meter just to be sure.
Jim
Jim,
Hide Signatures
       Post #: 184
RE: WACO YMF - 10/30/2006 5:29 AM
Stickbuilder
Score: 346
Status: offline
Jim
Decals? Decals? Notnunname!! I have been at it on this one since March, and No Decals for me. Magic? Not hardly Pilgrim...
Just more %%$#@@@** hard work.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 185
RE: WACO YMF - 10/30/2006 5:51 AM
Jim Henley
Score: 120
Status: offline
Sorry, I didn't make my question clear. I meant to say: will the trim paint be the same design as the decals, or do you have something more elaborate in mind like scallops or flames or???
Jim,
Hide Signatures
       Post #: 186
RE: WACO YMF - 10/30/2006 7:15 AM
Hughes500E
Score: 105
Status: offline
Hi Jim,
I was thinking about you today when I hacked my tail off my plane
My horizontal stab was perfect but I made a dato cut in it before I pinned and mounted the vertical. Not thinking that I had to offset my horizontal stab, I never made any changes to the dato. My vertical was out by a hair, just enough to drive me crazy! No one else could see it of course
I took these for you. If you do change it, it has to be perfect, I can send you a template of the pieces. Quite a simple job really!
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 187
RE: WACO YMF - 10/30/2006 7:24 AM
pimmnz
Score: 148
Last Login: 6/15/2013
Status: offline
Chaps,
I have been following this thread with interest, cause I built one of these time machines a few years ago and I'm thinking about another one, cabin version maybe, you know, one of those `Gentleman's Aerial Carriages'.
Evan
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 188
RE: WACO YMF - 10/30/2006 7:30 AM
chris1949
Score: 100
Last Login: 1/10/2011
Status: offline
Hi instead of going to the licquor store go to the drug store and mix a little winter green oil with the dope,dont worry its compatible.I hope your wife likes the smell of pine trees really it works and it lasts along time.Just dont have it out at christmas you will have lights and tinsle all over it thanx Chris
Hide Signatures
       Post #: 189
RE: WACO YMF - 10/30/2006 7:39 AM
chris1949
Score: 100
Status: offline
Lookin! real good Bill time to take a deep breath and enjoy before the finish.Keep up the good work Chris
Hide Signatures
       Post #: 190
RE: WACO YMF - 10/30/2006 8:13 AM
Hughes500E
Score: 105
Status: offline
Interesting Chris, will have to remember that!
Curious though, how would one find that out
Hide Signatures
(in reply to chris1949)
       Post #: 191
RE: WACO YMF - 10/30/2006 1:54 PM
Stickbuilder
Score: 346
Status: offline
As they used to say on the Saturday Matinee....We'll Soon find out !!! I will tell you this much, Flames are definately out. This one will be most unusual. The Pilot will (in honor of the wife) be none other than the ever lovely Tinker Bell. Let your imigination run with that one, and stand by. (we'll be right back after station identification) Yeah, the wife won. This is going to be her airplane.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 192
RE: WACO YMF - 10/31/2006 4:26 AM
chris1949
Score: 100
Status: offline
Hi again I believe it was in rc modeller years ago or a hobby shop that I went to the owner told me tried it works great.
Hide Signatures
       Post #: 193
RE: WACO YMF - 11/1/2006 2:41 AM
Jim Henley
Score: 120
Status: offline
Perhaps we need to figure out how to get those templates down to Omaha. I was looking at your photos, my fuselage, the plans, your photo, and it struck me. The guy that started this kit has glued the stab down with the T.E. even with the tail post. From your photos, and from what I see on the plan, the stab should butt up against F-13T, which would leave the T.E. forward of the tail post about 1/2 inch. So, even if the incidence is correct the stab is still in the wrong location. I guess I'll be removing the head rest, vertical and horizontal stab and starting over.
Jim
Jim,
Hide Signatures
       Post #: 194
RE: WACO YMF - 11/1/2006 5:35 AM
Hughes500E
Score: 105
Status: offline
Hi Jim,
It's a fairly simple job. Send me an email via my profile and I'll send you the templates.
Hide Signatures
       Post #: 195
RE: WACO YMF - 11/1/2006 6:22 AM
Jim_McIntyre
Score: 100
Last Login: 2/1/2011
Status: offline
Wow!
I have to come back to this thread more often, some nice work here!
I managed to shoot both wings with base paint (white) this past weekend, sanding and trim (red) work next. Ive begun trim on the fuselage, maybe she will fly next season.
This is my first Latex paint job, very forgiving, fast drying, easy to color-match, I'm loving it. No more lacquer for these lungs.
pimmnz; the "Waco Cabin Model" is another classic. that and a Beech Staggerwing are on my short'er' list of future projects.
http://scalebuilder.org
Hide Signatures
       Post #: 196
RE: WACO YMF - 11/1/2006 6:48 AM
pimmnz
Score: 148
Status: offline
Jim,
Both models are on my list too, the old UPF is getting lonely and needs a companion. Could be a YKS, G17 or SR9. I have detail drawings for each, just need to turn them into a building plan, but which one?
Evan.
Hide Signatures
(in reply to Jim_McIntyre)
       Post #: 197
RE: WACO YMF - 11/1/2006 9:53 AM
chris1949
Score: 100
Status: offline
Hi Jim I took a break from modelling for a while Im an old silk and dope guy.Darn near impossible to find that any more.Spencer Aircraft has it for full size fairly cheap.Question is what kind of latex paint are you using and what other options are available.Maybe we will still meet at Rhinebeck one day you never know thanx Chris
Hide Signatures
       Post #: 198
RE: WACO YMF - 11/1/2006 5:09 PM
Jim_McIntyre
Score: 100
Status: offline
I too am more comfortable with Silk & Dope but have made the transition to Supershrink Coverrite. I really love the stuff, all the benefits of silk & dope (strength, durability) with a few extras like ability to shrink with a heatgun (not as much as plastic, but still welcome). I still use Nitrate to assist the glue backing.
I'm new to latex but, I'm using Behr premium exterior latex thinned with common windshield washer fluid. With electronic color matching I can take my chips in for a perfect match every time. Drying time between coats is literally minutes when running a dehumidifier. Cleanup is a breeze too, simple soap and warm water is enough for skin, and I run straight windshield washer through the gun to clean up. Overspray is also much less than with other paints I've used and simply wipes up with a damp rag.
Rhinebeck ... sigh ... hope to make it next year but their scale rally conflicts with annual fiscal year-end software release testing. Still, the regular shows are worth the trip and I have literally Gigabytes of documentation from this year's trip. That Hanriot really grew on me... too unweildy for competition but one beautiful piece of flying furniture.
... I began a G17 in cad from factory 3-views some time ago, I must to get back to her.
Hide Signatures
       Post #: 199
RE: WACO YMF - 11/2/2006 3:35 AM
Stickbuilder
Score: 346
Status: offline
Jim
Jim, The trailing edge of the horizontal stab has to miss the tailpost in order to allow room for the elevator joiner dowell. I used a few scraps to fair in the area, and it really makes the after end of this WACO look right. Sorry about your luck, but better to find it out now, than after you had expended hours of time only to need to tear it all out.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.066RCU1
