RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  71 72 [73] 74 75 76 77 78 79 80   next >   >>
Login
RE: WACO YMF - 4/2/2007 12:57 AM
Nightstalker
Score: 100
Last Login: 1/25/2010
Status: offline
quote:
ORIGINAL: Stickbuilder
There is no need to wait for One April for you to feel that way (gotcha).
Bill, AMA 4720
WACO Brotherhood #1
Nicest thing anyone's said to me lately.
Good lookin' work as well Bill. Will be interesting to here about the H-Stab function when you fly'er. You seem as if you've built a model or two in your day.
Nightstalker
Doggie 47
Hide Signatures
(in reply to Stickbuilder)
       Post #: 1801
RE: WACO YMF - 4/2/2007 1:24 AM
r/c John
Score: 100
Last Login: 5/13/2013
Status: offline
Perhaps you had better take another look. I am sure that you will see that Cox bought up the rights to produce Pica models and it is now being offere in both 1/5 and 1/6 ARF
Hide Signatures
       Post #: 1802
RE: WACO YMF - 4/2/2007 1:31 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
I agree with Nightstalker. Your plane is lookin' good. Comparing your structure to how the ARF is put together, I'm thinking that the little doohickeys that hold the wheelpants on are the only things Cox didn't change. Even if the trim adjuster on your H-stab turns out to be less than necessary for flight trimming, the scale detail was worth the effort, as is the two piece H stab. It really looks great.
I have all the sheeting done to the fuse, all that is left is a circular piece around the front edge. I'm going to mask a line around the front of the sheeting, and lay a couple layers of glass and epoxy around the front edge, then remove the tape. This will leave a slight relief, and then I'll sand it smooth. I'll post some pics whenits done. The sheeting looks pretty good, I think.
_____________________________
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
(in reply to Nightstalker)
       Post #: 1803
RE: WACO YMF - 4/2/2007 3:23 AM
skylarkmk1
Score: 210
Last Login: 5/21/2013
Status: offline
r/c john,
Most of us in the WACO Brotherhood and on this thread are aware that Cox bought the rights to the Pica YMF and are producing the ARFs and rumor has it, may produce kits. Khodges is redoing a 1/5th Cox/Pica YMF ARF and adding a lot of detail that Cox left out. Stickbuilder and others are building the 1/5th or 1/6th from old Pica kits and/or will be building from "scratch", once all the formers and such are traced, copied and forwarded to those interested in doing so. The basic plans (side and top views as originally supplied by Pica) are available from the AMA and we in the Brotherhood (ie: stickbuilder) and others are trying to complete the plans with the templates of the formers etc. and instructions.
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to r/c John)
       Post #: 1804
RE: WACO YMF - 4/2/2007 5:22 AM
Jim Henley
Score: 120
Last Login: 5/20/2013
Status: offline
Well, another windy rainy weekend in Omaha, gives me an excuse to hibernate down in the basement. Got the top wing in Coverite and bottom of the bottom wing also in Coverite. The tail feathers are covered, here are some shots w/o wings.
Ken, understand the "aroma" issue, that is why I gave the Coverite a try. I use the Balsarite, it drys quick, has minimal odor.
The other advantage is that Coverite is fuel proof right off the roll, and it shrinks beatifully with the iron. Still think I'll give the Klass Kote epoxy a try, sounds like good stuff.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
(in reply to skylarkmk1)
       Post #: 1805
RE: WACO YMF - 4/2/2007 7:25 AM
khodges
Score: 126
Status: offline
Jim, your build looks great, we're pretty close together in where we are. Your engine installation is slick as heck. I love how the blister locations were perfect for the Saito. I notice that yours is a true YMF cowl with the equal spacing, I'm sure you've discussed that at some point. I guess I'm gonna call mine a UMF when people see it at fly-ins and want to know "what kind of Stearman is that?"
I tried a different tack on the forward edge of the fuse. I cut strips of 1/32 balsa and glued them down around the circumference, butted against the sheeting; I'll sand them to thickness and harden them afterward with thin Ca. It's about 3/4 done, and will give the look I'm after.
Well, I danced with my daughter tonite, did the shag and also a waltz. As she has been dancing since the age of three, and competing for four years, I let her lead . I didn't look quite like a drunk on a swaying ship, but close.
And we think WE can fly:
Click for fullsize
< Message edited by khodges -- 4/2/2007 7:44 AM >
Hide Signatures
(in reply to Jim Henley)
       Post #: 1806
RE: WACO YMF - 4/2/2007 3:24 PM
Stickbuilder
Score: 346
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: r/c John
r/c John,
Please flesh your comments out. I have no idea what point you are trying to make. Cox has given the AMA the plans to the Kit version, and that would lead one to surmise that they have no interest in producing the kit version of the YMF. The ARF version does not resemble the structure of the kit model in form or design. What are you trying to say?
Bill, AMA 4720
WACO Brotherhood #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 1807
RE: WACO YMF - 4/2/2007 11:25 PM
Stickbuilder
Score: 346
Status: offline
I guess that r/c John is a hit and run. I've never seen him in here before. Hope he comes back.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 1808
RE: WACO YMF - 4/2/2007 11:39 PM
khodges
Score: 126
Status: offline
Bill, AMA 4720
WACO Brotherhood #1
If you noticed, he joined in July '02, and that was his first post. Suppose it took him that long to figure out how?
Doppledecker John:
Click for fullsize
Hide Signatures
       Post #: 1809
RE: WACO YMF - 4/3/2007 12:03 AM
skylarkmk1
Score: 210
Status: offline
Since this is a thread about Bi-Planes, wouldn't that be a Bi-John?
Wouldn't want to be an employee of the company, it says a whole lot about the way the employees are treated.
< Message edited by skylarkmk1 -- 4/3/2007 12:05 AM >
Hide Signatures
(in reply to khodges)
       Post #: 1810
RE: WACO YMF - 4/3/2007 12:14 AM
Nightstalker
Score: 100
Status: offline
Bet the basement is really nice. A builder's paradise
Nightstalker
Doggie 47
Hide Signatures
       Post #: 1811
RE: WACO YMF - 4/3/2007 1:00 AM
Skinny Bob
Score: 100
Last Login: 3/3/2013
Status: offline
I think I might have worked there!
Skinny Bob - AMA 713081
WACO Brotherhood #10
Hide Signatures
       Post #: 1812
RE: WACO YMF - 4/3/2007 2:37 AM
Stickbuilder
Score: 346
Status: offline
Bet you could rent the basement out to Nightstalker, and he could sub-let it to the Jar-Head, or the Lt.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to Skinny Bob)
       Post #: 1813
RE: WACO YMF - 4/3/2007 3:05 AM
Nightstalker
Score: 100
Status: offline
Wouldn't be so bad for stick and tissue jobs - lot's of free covering material... I prefer flat black aircraft, but brown and yellow's OK
Nightstalker
Doggie 47
Hide Signatures
       Post #: 1814
RE: WACO YMF - 4/3/2007 3:21 AM
khodges
Score: 126
Status: offline
Bill, AMA 4720
WACO Brotherhood #1
Here's one from some unnamed Naval Base, a bit more "upscale". Officers upstairs, enlisted below. Master Chiefs get their own "porta-potty", they're usually so full of it, they can "go" all the time
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1815
RE: WACO YMF - 4/3/2007 3:22 AM
Nightstalker
Score: 100
Status: offline
quote:
ORIGINAL: skylarkmk1
With ll due respect Master Sergeant... bet it reminds you of your Air Force days. Hey at least you weren't a Chief Master Sergeant (I'm assuming)... that's all this thread needs is 2 ret. Echo Niners
Nightstalker
Doggie 47
Hide Signatures
       Post #: 1816
RE: WACO YMF - 4/3/2007 3:27 AM
khodges
Score: 126
Status: offline
Fuse is pretty much finished, ready to start doping.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1817
RE: WACO YMF - 4/3/2007 4:17 AM
skylarkmk1
Score: 210
Status: offline
Nightstalker,
Retired as E-7. (Un)Fortunately, my last unit had just a few junior officers and the top 3 enlisted had to help them out with duty officer rotation so occasionaily we got to use the top floor.
Hide Signatures
       Post #: 1818
RE: WACO YMF - 4/3/2007 4:59 AM
Nightstalker
Score: 100
Status: offline
Nightstalker,
At least the Air Force had indoor latrines... closest I ever got to using the top floor was flyin' at night, low and fast over farms in Tennessee in my Chinook... skivvies down, ramp level... a$$ hanging out... and bombs away .
Nightstalker
Doggie 47
Hide Signatures
       Post #: 1819
RE: WACO YMF - 4/3/2007 5:32 AM
Nightstalker
Score: 100
Status: offline
quote:
ORIGINAL: Nightstalker
Nightstalker,
Nightstalker
Doggie 47
Think I'm kidding???
[image][/image]
Click for fullsize
Hide Signatures
       Post #: 1820
RE: WACO YMF - 4/3/2007 5:38 AM
khodges
Score: 126
Status: offline
Yeah, and we can all see your "mini gun" too!!!!! But only with binoculars
Hide Signatures
       Post #: 1821
RE: WACO YMF - 4/3/2007 5:45 AM
Jim Henley
Score: 120
Status: offline
Ken,
She's looking real good. when you get the 1/64 ply doped will it still have the panel lines?
I got the bottom wing finished this afternoon, that leaves the fuselage, but before I start, think I'll set it up
one more time to make sure the incidence is correct on the wings and stab, just in case I need to tweek anything.
Jim,
Hide Signatures
       Post #: 1822
RE: WACO YMF - 4/3/2007 5:57 AM
Nightstalker
Score: 100
Status: offline
quote:
ORIGINAL: khodges
NOTE: No Poultry, Livestock, Produce or BARN ROOFS were harmed in the filming of this Humanitarian "Relief" Operation
If only the Air Force could conduct such surgically precise "bombing"...
Out Here (for now),
Nightstalker
Doggie 47
p.s. Lt (or anybody) PM me and school me on picture posting here... I am as digitally inclined as a Jareeeeen - snd your pictures look great even without binoculars... I got your six Lt
Hide Signatures
       Post #: 1823
RE: WACO YMF - 4/3/2007 6:30 AM
Nightstalker
Score: 100
Status: offline
I got your six Lt
[/quote]
Or as my wife says " I got your 5 and a half"
A "Mini Gun" is just that... small by design... and shoots REALLY fast... good, bad or indifferent...
You guys are spending entirely too much time on your aero-machines - 'tis Happy Hour here in AZ... on a Monday even... gotta love Mountain Standard Time.. Damn it's hot!!! Out to the cement pond
Nightstalker
Doggie 47
Hide Signatures
       Post #: 1824
RE: WACO YMF - 4/3/2007 8:17 AM
funkymusic
Score: 100
Last Login: 12/30/2012
Status: offline
All I can say is 'Wow' the attention to detail you guys are applying to these planes is incredible. I'm really enjoying khodges koverall tutorial. I'm sorry I can't contribute to the ribbing tonight, I just got in from class and OSU lost so I'm not in the best moods.
Chuck
WACO Brotherhood #33
Hide Signatures
       Post #: 1825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.063RCU1
