RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  77 78 [79] 80 81 82 83 84 85 86   next >   >>
Login
RE: WACO YMF - 4/15/2007 8:56 PM
Stickbuilder
Score: 346
Last Login: 6/19/2013
Status: offline
Last coat? That sounds pretty final. Kind of like, "I'm going to fly this one one last time", and usually the prophecy is correct.
Hope you don't find any pin holes (I ususlly do) and I want to see it with the first coat of primer. Don't try doing something dumb and dry fitting the wings with a fresh coat of primer. I had to rework the center section of the bottom wing after trying that.
Did you add any pads for attaching the flying wires at the fuse bottom?
Bill, AMA 4720
WACO Brotherhood #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to khodges)
       Post #: 1951
RE: WACO YMF - 4/16/2007 12:06 AM
Nightstalker
Score: 100
Last Login: 1/25/2010
Status: offline
Just make it shiny. (It drives NightStalker nuts).
Bill, AMA 4720
WACO Brotherhood #1
[/quote]
I was nuts long before the "Shiney Airplane" thing came up...Shiney is in the eye of the beholder... and a five year old at that! I've had non-shiney airplanes all my Doggie life, and until a certain Master Chief posted a picture of a Tink piloted Shiney red and gold WACO on Christmas eve, it would still be a non-issue. Little kids are great... can't tell you how many times since Christmas my Li'ln has asked me about the Shiney Tinkerbell plane... memory like a steel trap I tell ya.
Todd
Doggie 47
Hide Signatures
(in reply to Stickbuilder)
       Post #: 1952
RE: WACO YMF - 4/16/2007 12:25 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
quote:
ORIGINAL: Stickbuilder
Jahwol, Herr Master Chief. I almost forgot, and was getting ready to prime the fuse, but the little black "x's" I had made in the respective locations reminded me. There are two on top of the fuse for the intercabane wires, and two on the lower fuse, just above the gear legs, for the forward flying wires. I used male electrical spade terminals and screwed them in place with a #2 button head screw. I previously put hardwood blocks under the balsa skin to make hard points for them and also did that to the wing locations.
The spades have a sleeve for the wire that is perfect for the elastic cord I will use for wires. I just thread the cord through the sleeve, tie a knot and pull it back into the sleeve to conceal the knot, and apply a drop of Ca. The other end, that attaches to the underside of the top wing, will have a fitting that allows me to disconnect the "wires" if I need to remove the wings. When I mount them, I'll make pics and further describe them.
I was at the workshop of one of my clubmates yesterday, and he showed me how well Rustoleum Clean Metal Primer fills the weave of Koverall when brushed on with a foam brush. I still believe in dope for this, but I will brush on the first coat of primer, and then do a light spray coat to even out any streaked spots and eliminate brush strokes that remain. I am using this primer anyway, I'll just change the manner I was going to use it.
The other thing I've done today is figure out how to mount the front windscreen so it would be solidly mounted, but still allow easy removal. I glued a couple of short lengths of aluminum tube to the inside of the windscreen frame, and used a couple of spade electrical terminals (anybody notice a pattern here? ) to make brackets at the bottom of the screen. I drilled two holes in the fuse, forward of the front 'pit, and with the windscreen in place inserted a piece of piano wire down through each small tube, into the fuse (there is a former there that the wires also pass through, establishing the angle of the windscreen). These wires hold the screen against prop blast and airstream. The two brackets will have a #2 buttonhead screw that keeps the screen from sliding up the wires. All I have to do to remove the screen is take out the screws and pull out the wires. you hardly notice these when its mounted.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by khodges -- 4/16/2007 12:28 AM >
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
       Post #: 1953
RE: WACO YMF - 4/16/2007 4:46 AM
Skinny Bob
Score: 100
Last Login: 6/16/2013
Status: offline
Brothers, I have changed my building plans to the following. I decided to use the parts interlocking method like Team Genesis is doing. I have most of the parts drawn in Coral Draw and will have them laser cut when completed.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Skinny Bob -- 4/16/2007 5:37 AM >
Skinny Bob - AMA 713081
WACO Brotherhood #10
Hide Signatures
       Post #: 1954
RE: WACO YMF - 4/16/2007 4:47 AM
Skinny Bob
Score: 100
Status: offline
Bad pics, will try again.
Hide Signatures
(in reply to Skinny Bob)
       Post #: 1955
RE: WACO YMF - 4/16/2007 5:10 AM
Stickbuilder
Score: 346
Status: offline
Ken,
You about ready to retire to Sunny Florida????? We could get into a lot of trouble down here.
Nightstalker...Your 5 year old is right. She knows a shiny airplane when she see's one. I'll give her another look at it.
I've got lots more pictures if you would like to see some....
Bill, AMA 4720
WACO Brotherhood #1
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1956
RE: WACO YMF - 4/16/2007 6:28 AM
khodges
Score: 126
Status: offline
I've BEEN ready to retire, and I have enough trouble staying OUT of trouble up here. All I need is to get thrown in the brig with a sailor. Well, at least you could introduce me around .
I primed the fuse tonite, brushed a coat on like my friend showed me, but I think a couple of sprayed coats would give me the same result, plus not have any brush marks at all. I'll do the rest of the plane like I had planned. I had just a few pinholes, surprisingly; not as many as on my last Koverall project. The Rustoleum primer flows nicely, and evens itself better than some primers I've used. The foam brush is nice, you can "dab" with the tip better than with a brush.
That WACO is gorgeous, Master Chief. Post all the pics you want.
Hide Signatures
       Post #: 1957
RE: WACO YMF - 4/16/2007 7:29 AM
skylarkmk1
Score: 210
Last Login: 6/18/2013
Status: offline
Bill,
As promised I got to the airport today and in a private hanger a cabin WACO was being restored with the Jacobs L-4 in an engine hoist. I got about 30 pictures, front, back, side and close up. Here are a couple to tease. I post some more later.
Click for fullsize
Click for fullsize
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 1958
RE: WACO YMF - 4/16/2007 7:43 AM
skylarkmk1
Score: 210
Status: offline
Ken,
Got some pictures and info for you also, close ups of fasteners. Picture one is the screws (sloted, not philips) at the front of the door, picture 2, with the Dsuz Fastener, is near the forward cabne strut, both on UBF-2 NC 2091K. Picture 3 shows the cowl fastener on the right front, Picture 4 is a close up, both are from UBF-2 N 155Y. All the sheet metal needs to be removed for inspection, so lots and lots of screws, both front and rear.
The ID Plate is not located on the out side of any WACO, according to the mechanic. They were located in various places on different WACOs. On the UBF, they were located on the front panel (instrument) on the left side.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 4/16/2007 7:46 AM >
Hide Signatures
       Post #: 1959
RE: WACO YMF - 4/16/2007 5:42 PM
kestrel0222
Score: 105
Last Login: 12/6/2011
Status: offline
John,
Those are some great shots of the Jacobs L-4!!! Keep 'em coming.
< Message edited by kestrel0222 -- 4/16/2007 5:47 PM >
Tom - AMA Member Since 1973
WACO Brother #39
Hide Signatures
       Post #: 1960
RE: WACO YMF - 4/16/2007 6:26 PM
Stickbuilder
Score: 346
Status: offline
I don't know how successful that I will be, but I want to try and replicate the Jacobs L-4 for mine. If I can find a cylinder that closely approximates the Jacobs, I will have higher hopes of being successful. The 7 cylinders that I have found are wrong for this plane. I'll keep looking, but right now, it looks as if I need to make one to have the correct appearance.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to kestrel0222)
       Post #: 1961
RE: WACO YMF - 4/16/2007 6:50 PM
skylarkmk1
Score: 210
Status: offline
Bill, Kestral and the rest of you engine builders,
After a little sorting and editing (cropping and straightening) here are the Jacobs L-4 pictures. This is from a Cabine WACO being restored (it was in the bare bones, so no model type) in an unrestored condition, so it shows all the oil leaks, paint chips, rust and other signs of use. Restored, all that character will be removed and the engine will look like new (see previous post of a Contenental in a UBF).
1 Overall shot
2 Straight down on # 2 Cylinder
3 Front upper # 1 Cylinder
4 Front at plug # 1
5 Front of Crankcase
6 Base of # 1
7 ¾ view Exhaust side
8 Top view both Rocker Arms
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 4/16/2007 6:55 PM >
Hide Signatures
       Post #: 1962
RE: WACO YMF - 4/16/2007 6:57 PM
skylarkmk1
Score: 210
Status: offline
Next 8.
9 ¾ view Intake side
10 Data Plate
11 Intake front
12 Intake ¾ side (opps, its the last picture now)
13 Crankcase rear Starboard
14 Exhaust connection
15 Intake connection
16 Exhaust termination
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 4/16/2007 7:07 PM >
Hide Signatures
(in reply to skylarkmk1)
       Post #: 1963
RE: WACO YMF - 4/16/2007 7:15 PM
skylarkmk1
Score: 210
Status: offline
Last bunch.
17 Crankcase rear Port c.u.
18 Crankcase rear
19 Rocker Cover (cylinder # 1 intake was blank, all the rest had Jacobs on them)
20 Intake Rocker
21 Exhaust Rocker
22 Top of Baffle Plate
23 Crankcase rear Port side
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1964
RE: WACO YMF - 4/16/2007 9:34 PM
Stickbuilder
Score: 346
Status: offline
John,
Thanks for the pictures.
I just got off the phone with Jackie Schalberg (Archivist at AMA Museum Plans Service). She told me that they do, in fact, have the parts templates in hand, and that she was going over to see when we might expect to see them available through the plans service.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 1965
RE: WACO YMF - 4/17/2007 1:32 AM
khodges
Score: 126
Status: offline
John, that data plate on the Jake says "Air Force Model xxxxxxxxx "(can't read it) underneath where it says Jacobs Aircraft Engine. Reckon it's one of the impressed models?
Man what a great set of photos. The Master Chief can put his signature line to work on that:
"Glue all the pieces together and sand off everything that doesn't look like a Jacobs engine."
< Message edited by khodges -- 4/17/2007 1:33 AM >
Hide Signatures
       Post #: 1966
RE: WACO YMF - 4/17/2007 2:37 AM
skylarkmk1
Score: 210
Status: offline
Bill,
The Williams Bros Wasp Cylinder is very similar to the Jacobs cylinder from the front with similar extra cooling fins on the exhaust rocker tower, fins on the lower section. A little work on the rocker covers, your own crankcase for 7 cylinders, a little paint and weathering and I believe you would have a reasonable Jacobs L-4 for your bird. In looking at the data plate a little closer, this may be a 245 hp engine and not a 225 hp (Engine Spec L 245).
Ken,
The data plate was hard to read in person, even with my glasses. I see where the flash caused the oil sump plug to put a shadow over the last part of the words "Air Force Model...). It was partially hidden behind the intake and only a little bit off the floor (engine was resting on the lower 2 cyliders). If the owner had been available, I would have asked to raise the engine for a better shot, but I suspect he was in the office at the local EAA monthly meeting/lunch or visiting with another owner in another hanger. When (big question) they start restoring the engine, I will try to get a better picture. The pictures are of the aircraft (a Cabin WACO)in its current state, so the engine restoration may be awhile.
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 4/17/2007 3:08 AM >
Hide Signatures
       Post #: 1967
RE: WACO YMF - 4/17/2007 3:30 AM
skylarkmk1
Score: 210
Status: offline
Bill,
Here is a comparison of # 1 Cylinder of the real Jacobs and a shot of Williams Bros. P&W Wasp cylinder. If you use those, you could save yourself a ton of work. The last picture is of a P&W model, 14" in diameter that shows the 2 tone cylinders better.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 4/17/2007 3:42 AM >
Hide Signatures
       Post #: 1968
RE: WACO YMF - 4/17/2007 5:05 AM
Jim Henley
Score: 120
Status: offline
Ken,
Your detail is just amazing! I like the idea of the electrical connectors for your flying wires. I made small hooks that I CA'd into the fuselage, then made small loops in the elastic wrapped with thread and CA. All I have to do is hook the elastic in the hooks, fast and easy field setup and on the Stearman ARF, it looks pretty good.
Bill,
Congrats on the "Judgeship" I'm confident you will do an excellent job.
Do not have any recent photos, we had nice weather this weekend and I made it to the field both days!
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
       Post #: 1969
RE: WACO YMF - 4/18/2007 1:00 AM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: Jim Henley
Ken,
Thanks, much Jim. Coming from one of the Brothers, that's high praise indeed. I have been racking my brain trying to come up with some kind of "quick release" for the other ends of the wires. It was always some kinds of hook and hook type thing, where I had a hook on the wire and one on the wing. Stupid me, I never thought of just making a loop on the elastic itself. I couldn't see the forest for the trees What I will probably use for the hardware end are small hooks (like brassiere clasps) screwed into the top wing underside, and the elastic tension will easily hold it in place. It will be a much easier and less obtrusive method like you've done; thanks much for passing it along.
Hide Signatures
(in reply to Jim Henley)
       Post #: 1970
RE: WACO YMF - 4/18/2007 2:38 AM
Jim Henley
Score: 120
Status: offline
Ken,
This thread has been a huge help to me so if this small idea is helpful I am glad to share. I have posted a couple of photos if anyone has an interest, I am sure this can be improved on.
Click for fullsize
Click for fullsize
Jim,
Hide Signatures
       Post #: 1971
RE: WACO YMF - 4/18/2007 2:50 AM
damifino
Score: 100
Last Login: 8/11/2012
Status: offline
Hope you guys will be interested in a shirt like this-
I will announce in this thread how to purchase these shirts in the coming month. I'll make it easy for you to obtain these 100% Cotton Hane's BEEFY-T shirts. This is an original design by myself and a close friend who is a professional graphic designer. This is a non-profit venture intended for the WACO Brotherhood to enjoy and for anyone else starved for neat Aeroplane themed sportswear. Hope you all like it! Stay tuned. Thanks for your comments STICKBUILDER.
Click for fullsize
Click for fullsize
< Message edited by damifino -- 4/24/2007 4:16 AM >
Everybody knows you can''t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
Hide Signatures
       Post #: 1972
RE: WACO YMF - 4/18/2007 3:01 AM
skylarkmk1
Score: 210
Status: offline
Jim,
In those immortal words "Whatca talkin' 'bout Willis?" you do a very nice job yourself on detail and finish. Attached is a Stearman, similar to yours, getting a little maintenance at CCA.
Click for fullsize
Hide Signatures
       Post #: 1973
RE: WACO YMF - 4/18/2007 3:05 AM
skylarkmk1
Score: 210
Status: offline
D,
That is one nice design, one of the best I have seen for WACOs. Let us know when Pay Pal is set up and put me down for 2 -XL.
< Message edited by skylarkmk1 -- 4/18/2007 5:13 AM >
Hide Signatures
(in reply to damifino)
       Post #: 1974
RE: WACO YMF - 4/18/2007 3:37 AM
Jim Henley
Score: 120
Status: offline
Yes! Yes! Keep us posted and put me down for 2 also, sizes to come later...
Jim,
Hide Signatures
       Post #: 1975
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.734RCU1
