RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  99 100 [101] 102 103 104 105 106 107 108   next >   >>
Login
RE: WACO YMF - 5/21/2007 4:55 AM
Stickbuilder
Score: 346
Last Login: 5/21/2013
Status: offline
Ken,
Even if I were using the same servo for the rudder and tailwheel, I would still consider using a spring drive (For what it's worth).
Bill, AMA 4720
WACO Brotherhood #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to khodges)
       Post #: 2501
RE: WACO YMF - 5/21/2007 5:50 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
quote:
ORIGINAL: Stickbuilder
Ken,
Bill, AMA 4720
WACO Brotherhood #1
I looked in a couple of catalogs (Sullivan and DuBro) at the LHS trying to find what is called a "servo saver", which is what I think you're describing. Correct me if I'm wrong; would you sketch what you're talking about?
What I'm thinking of goes on the servo end of the control rod, and the spring actuates when the servo travel is greater than the available movement in the control rod, and keeps the servo from stripping a gear or binding. It still gives positive control while in the limits of the control rod travel.
I shifted gears and am trying something along the lines John mentioned (or was it Jay?) about using the nose wheel mounts. I've come up with something that has a small spring that will compress about 1/2 inch.
Today, one of the local grass strips had their club day, with "rollers and sliders" and tater salad, slaw, etc. Wasn't as busy as in past years, but was an almost perfect day, just a bit breezy at times. I got to go up in a PA-18 for about 30 minutes. It is one of the Cub Crafters planes, this one was only three years old, has a 140 hp engine. That is Grandfather Mountain off the wingtip.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
(in reply to Stickbuilder)
       Post #: 2502
RE: WACO YMF - 5/21/2007 6:43 AM
damifino
Score: 100
Last Login: 8/11/2012
Status: offline
Here's the Tee info one more time. Sorry I have not updated the list yet, been really busy.
quote:
Your WACO TEE SHIRT Money Orders and Pay-Pal transactions have been coming in. If you haven't already, be sure to reserve your shirts by May 31!!
Here is the KICK OFF INFO one more time. PM me for mailing/Pay-Pal instructions. Thanks
The cost for 2 Tees, including shipping within the U.S., is to be $30.00 for S M L & XL. XXL and XXXL will be $35.00
The shipping, unfortunately, has driven the price a bit higher than I had hoped.
So, that's the deal guys. I sent a private message to each of you (I hope) with an address for your USPS Money Order payment and a Pay-Pal ID for those of you who wish to use that option. I wish to allow 3 weeks for you to send in your payment. I have tentatively scheduled the printing to be done the first week of June.
Please try to have the payments in by May 31, 2007. PLEASE include your mailing address, your RC Universe 'user name' and your shirt sizes. I have size info for all who requested shirts but it doesn't hurt to send it with your remittance.
KHODGES- Your ARFnot looks fantastic. That shot posted beside the black and white picture really says it all.
< Message edited by damifino -- 5/21/2007 6:45 AM >
Everybody knows you can''t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
Hide Signatures
       Post #: 2503
RE: WACO YMF - 5/21/2007 7:58 AM
skylarkmk1
Score: 210
Status: offline
ken (khodges),
The varnished sticks you asked about under the center tank sections on many WACOs serve two purposes; The center stick is structural and is part of the wing joining system (don't ask me how just yet). The outer sticks are attached to the tank bay plywood floor and are to help keep the plywood from warping. I was able to briefly talk to the mechanic today, they (mechanic, owner and helpers) had just mounted the upper wings on a QCF, NC 12428 (it is pretty in red with black scallops, I'll post a picture when it is complete).That brings the total to 14 WACOs at CCA that are complete (or nearly complete) and in flying condition (at least 2 more still need major restoration).
tomcraig,
Check the Aerofiles website (found in the Plans, Kits and Documentation PDF on the supplimental site http://www.houseofmoy.com/waco/ ). In the history section, although brief, YMF-3 was introduced in 1934, had a Jacobs 225 hp engine, load capacity 960 lbs. Was redesignated in 1935 to YMF-5 (dash # "usually" indicates first year of production), had a Jacobs 245 hp engine, load capacity 890 lbs. Max speed (if I read the info correct) was 147(YMF-3) 145(YMF-5), cruise at 129 and land at 47 (both the -3 and -5). The design was revived in 1990 by Classic Aircraft Corp. as YMF-5 Super. (website on list)
As noted before, the vertical tail was made taller/larger and the trim level was improved. The "New" CAC YMF-5 Classic (thru ser/number xx39 was "mostly" based on the 1934/1935 design. The "Newer" YMF-5 Super started with ser/num xx40 which in it's current versions have over 300 changes/improvements. Some of the more notetable improvements to the Supers are better steel and construction in the airframe allowing it to be certified for +5/-3 g's, 6" longer fuselage (2" in front cockpit, 4" in rear), 3" wider fuselage (in cockpit area), full instrumentation/avionic packages, and some have been fitted with a fuel injected engine (smoother, more efficent and since all cyliders are operating at optimum air/fuel ration, more power). Over 100 of the "NEW" YMF-5 have been produced compared to 18 of the original (according to Aerofiles).
< Message edited by skylarkmk1 -- 5/21/2007 8:14 AM >
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 2504
RE: WACO YMF - 5/21/2007 3:51 PM
Stickbuilder
Score: 346
Status: offline
The servo saaver that you described is exactly what I'm talking about. Something like a quick connector goes on the servo arm, and no set screw is used. this allows the pushrod to move within the keeper. Two collars are used, and a spring goes between each collar and the quick connector. The spring actually drives the tailwheel, and the collars limit the movement of the springs. I will sketch it out tonight, and post it for you.
Skylark.... You are on the money as usual.
Bill, AMa 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 2505
RE: WACO YMF - 5/21/2007 11:23 PM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: skylarkmk1
I have another question for them............."Can I have a job?"
Jay--Have you said yet how much more we need to get you for the extra shipping?
< Message edited by khodges -- 5/21/2007 11:27 PM >
Hide Signatures
(in reply to skylarkmk1)
       Post #: 2506
RE: WACO YMF - 5/22/2007 12:47 AM
skylarkmk1
Score: 210
Status: offline
Ken,
Below is the photo of the QCF (NC 12428) just after the wings were mounted. Front and rear "N" struts and additional flying wires still need to be added. Note the top cowl panel in front of the windshield open for access to the cabane wire mountings. This is the same aircraft that I photographed the earlier photos of the tail wheel looking down into the fuselage about a month or so ago (+/-) with the stabilizer removed.
The second photo is of the tank bay of the YKS wings, you can see the screws in the bottom to hold the stiffeners used to keep the plywood flat.
Made a mistake in my last post, forgot a UPF-7 in a private hanger. There are 14 Waco’s in the CCA/HARM collection in flying (or soon to be) condition plus at least one (the UPF-7) for a total of at least 15 Waco’s at CCA. Besides the great collection in HARM, CCA is a living museum in itself.
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 5/22/2007 12:50 AM >
Hide Signatures
       Post #: 2507
RE: WACO YMF - 5/22/2007 1:24 AM
Michaelj2k
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: khodges
On another note, today at our local airport (Hickory Regional) there was the official opening of the Sabre Society's museum. It has a loooong way to go to approach the likes of HARM or Udvar-Hazy, but for an out-of-the-way backwater of aviation, not too bad. The museum has about half dozen static warbird jets, including the very last F-14 to ever fly. There are some loaner birds that do fly, including a British Vampire, and an A-1E Skyraider. There were a few EAA members flew in and displayed their planes, from Super Cubs to ultralights. I think, though, the prettiest plane to grace the flightline at HKY in years was this SR-8 Stinson Reliant:
Excellent photos but I'd like to add a correction on the aircraft. It's a Warner 165 powered 1946 Fairchild 24W (F24W46).
“He’s crazy Lew, he builds toy airplanes”.
Capt. Frank Towns - Flight of the Phoenix
Hide Signatures
       Post #: 2508
RE: WACO YMF - 5/22/2007 1:40 AM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: Michaelj2k
quote:
ORIGINAL: khodges
I stand corrected. It's STILL the prettiest plane to grace the flightline. If I'd had my thinking cap on, I guess the Winged Pegasus and the big FA on the tail and rudder pedals should have been a giveaway. I focused on the notched wing center, humpback turtledeck and windscreen.
Click for fullsize
Click for fullsize
< Message edited by khodges -- 5/22/2007 1:49 AM >
Hide Signatures
(in reply to Michaelj2k)
       Post #: 2509
RE: WACO YMF - 5/22/2007 1:43 AM
Michaelj2k
Score: 100
Status: offline
quote:
ORIGINAL: khodges
quote:
ORIGINAL: khodges
I stand corrected. It was STILL the prettiest plane to grace the flightline.
And they fly like a Caddy!
Hide Signatures
       Post #: 2510
RE: WACO YMF - 5/22/2007 2:01 AM
khodges
Score: 126
Status: offline
Like this? I'll have it hooked up tonite. Also, here's what the old tailwheel mount versus the new one looks like. I included pics of what the tail framework looks like, and how the new setup fits. I can change the spring tension by simply changing the spring. This one works pretty good. I think with this and the other gizmo hooked up at the servo, the servo should be fairly well isolated.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2511
RE: WACO YMF - 5/22/2007 2:12 AM
khodges
Score: 126
Status: offline
I'll bet it is a nice ride, although the "dash" is a bit more like a '54 Chevy . Kind of spartan, but the seats and upholstery was nice.
Here's a hot rod for you. This was at a grass strip I visited Sunday, he came zooming in. I couldn't figure it out; the tail didn't match the nose. It's a clipped wing Monocoupe 8-A. The owner said it cruised at 140 mph, and that it was for sale (mid 50K). It was re-engined about 5 years ago, it has a flat-four Lycoming in it, 200 hp. He said it was a lot less maintenance and a lot more reliable than the original radial, plus faster.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2512
RE: WACO YMF - 5/22/2007 3:19 AM
damifino
Score: 100
Status: offline
I have not found out yet. The printing and shipping of WACO Brotherhood Tees will go as planned. If the difference in postage is significant I'll let everyone know. I got a little behind on other things while keeping up with the orders and payments so I decided to catch up this week. Again, everything is a go.
trlambsr- Where can I get the picture CD with all the WACO YMF shots?
< Message edited by damifino -- 5/22/2007 3:21 AM >
Hide Signatures
       Post #: 2513
RE: WACO YMF - 5/22/2007 3:42 AM
flyguy888
Score: 100
Last Login: 4/1/2013
Status: offline
I don't understand this. Why is vasek responding to vandelay when the post is for damifino. And Vandelay wasn't yelling. only asking a question. Even if it was an uncomfortable question, or interogative question, I'm not sure if this is the right response. Is this the proper resonse to people who do not think like we do?
Am I going to get yelled at for asking this question?
And in my opinion, I could be wrong, 25% of the posts have nothing to do with waco's.
That is not vandelays doing. He just started here.
quote:
ORIGINAL: vasek
HEY VANDOLEY >>> let it go, don't know what your problem is & I DON"T CARE!!!!!!!!
this is a nice place to talk WACO talk. so talk Waco ....
Capish?
If you love to build you have to pay the price
Waco Brother #7
Hide Signatures
(in reply to vasek)
       Post #: 2514
RE: WACO YMF - 5/22/2007 4:20 AM
damifino
Score: 100
Status: offline
I chose not to respond to Vandolay simply I've decided not to get involved any deeper. I did not ask for a 'full disclosure' and my profile is as compete as it needs to be. If Vandolay is serious about kit cutting he needs to go ahead and do it, floating business ideas on an open forum is an invitation to all sorts of responses. Sorry he did not get what he wanted here. We are not sitting around lamenting the unavailability of kits anyway. In regard to VASEK's response? Who knows, maybe he knows something we don't. Or maybe he is comfortable with the status quo of the thread.
Hide Signatures
(in reply to flyguy888)
       Post #: 2515
RE: WACO YMF - 5/22/2007 5:56 AM
khodges
Score: 126
Status: offline
One last pic of the servo setup, finished and in place. Works great, as does the sprung tailwheel. Italso got rid of the small binding problem I was having with the rudder centering itself.
Click for fullsize
Hide Signatures
       Post #: 2516
RE: WACO YMF - 5/22/2007 6:27 AM
damifino
Score: 100
Status: offline
Looks good. I thought you were talking about a servo saver like that. Should work fine. Got my wing saddles fitted and glued in place tonight. I'll get some pics posted soon.
Hide Signatures
       Post #: 2517
RE: WACO YMF - 5/22/2007 7:29 AM
mrdhud
Score: 110
Status: online
khodges
I have been looking at your tail wheel set up and am impressed. Is this set up on the plans or is it something you or some one else has designed? I will be getting my plans from AMA soon and trying to do my home work. Thanks and please keep the pics coming they are priceless to me as this will be my first build from plans only.
Dan Hudson WACO Brotherhood #45
GIT-ER-DUN "Build a WACO"
Hide Signatures
(in reply to damifino)
       Post #: 2518
RE: WACO YMF - 5/22/2007 7:45 AM
Nightstalker
Score: 100
Last Login: 1/25/2010
Status: offline
quote:
ORIGINAL: ronj10
quote:
ORIGINAL: vasek
Capish?
Ron - I gotta ask... what's YOUR problem???... not that I care... but I am curious (and I do care to some degree).
I flew outta bounds... maybe... slightly (with my reply to Vandolay... yesterday... or Saturday regarding his post) and you jump in with a post (which I read before you editied / deleted your reply #2500)... which had nothing to do with WACOS, so what gives?
I may not always be on topic, usually never, but come on!!! The majority of us like this thread on topic or off.
PM me if you want and we can discuss this off line. I used to like your posts several weeks ago. You seem to be a talented builder, albeit sensitive. I'll give you my phone number and we can talk if you want.
Todd
WACO Brotherhood #47
Hide Signatures
       Post #: 2519
vasek
Score: 147
Status: offline
quote:
ORIGINAL: ronj10
I don't understand this. Why is vasek responding to vandelay when the post is for damifino. ...
Sorry to all if i have over-reacted BUT i feel it's a shame when people start arguing about something they could do in PM's
the reason being when one looks for "past data" on a valuable thread like this and there are too many "non Waco related posts"
That's all. I don't want to offend anyone or mind anyone's else's business but my own
Regarding the profile info > it struck a nerve because i tried to change my "status" (i am Canadian but live in Europe now) BUT could NOT find the proper RCU page to change it ... still can't maybe the reason i overreacted
That's all folks, no harm done (i hope )
Cheers to all (including Vandolay)
Remember: Speed is life!
Hide Signatures
       Post #: 2520
RE: WACO YMF - 5/22/2007 3:44 PM
flyguy888
Score: 100
Status: offline
The reason I edited out my post is on hindsite I realized it was inappropriate.
It was only up for a few minutes. Have you ever said something you wanted to take back?
I apologize for letting my emotions get the best of me.
Discretion is the better part of valor.
Anyway, this is how a faired my wing into the fuse on the bottom. The pica kit did not really have any method for doing this. I also added an extra dowel in front. The one per plan may be enough, I dunno, Its not something I wanted to find out during a loop. I built lots of sixty size ships with two dowels, I was a little nervous when I saw that this bigger airplane had only one.
Also, I now wish I had added ply blocks in the wing on the T.E. for the wing screw hold down areas. The balsa is too soft, the big heads of the plastic screws have already made deep impressions in the soft balsa after taking the wing on and off a bunch of times.
Click for fullsize
Click for fullsize
< Message edited by ronj10 -- 5/22/2007 3:56 PM >
Waco Brother #7
Hide Signatures
(in reply to Nightstalker)
       Post #: 2521
RE: WACO YMF - 5/22/2007 4:47 PM
SoCalSal
Score: 105
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: damifino
Hi, I tried to send you an e-mail last night. Your spam blocker won't let me get to you. It says it can't find the original message so I am blocked out.
Anyhow I would like to order 2 XXl "t" shirts. I can pay via PayPal. I just need to know who to send the funds to. Also Are there any hats to go along with this shirt? if so how much?
Let me know the cost including shipping to zip 91978
Steve Waco Brotherhood #46
Let''s be open minded.... But not so open that your brain falls out
Hide Signatures
       Post #: 2522
RE: WACO YMF - 5/22/2007 4:55 PM
Tripp2loo
Score: 100
Last Login: 9/27/2011
Status: offline
Off any subject, but still Waco..., anyone have a spare $135K kicking around. I need a 0% intrerest loan, over 60 years..
I am drooling over this thing, not sure why I keep watching it, but I do
Dream Waco
BTW, I say $135K, as this will give me about 7K to get a licese...
Cheers
Tripp, Waco Brotherhood # 19
Hide Signatures
(in reply to SoCalSal)
       Post #: 2523
RE: WACO YMF - 5/22/2007 4:59 PM
SoCalSal
Score: 105
Status: offline
Hi guys and Gals. Here are a couple of photos of my Barth Waco YMF5. I'm looking forward to this "Brotherhood" "Miss Linney" is without a doubt my favorite plane to fly.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SoCalSal -- 5/22/2007 5:02 PM >
Hide Signatures
       Post #: 2524
RE: WACO YMF - 5/22/2007 5:44 PM
Stickbuilder
Score: 346
Status: offline
To All:
I'm going to say this once again. This is a Brotherhood. We discuss things other than WACO aircraft here. If the thread srtictly stuck with only the details about building the YMF/UMF, it would be very dry reading, and friendships would not be allowed to grow. If you have a problem with this, why not start your own thread? This historicially has been a very problem-free thread, and I don't want to see it grow problems. We do not always agree with each other, but let's not let it grow into a urinating contest. Keep it civil, and the Moderators won't be in here with both guns blazing. If necessary, I will begin to do what I never wanted to do...Impose rules for membership. Look in the mirror and breathe deeply 5 times before you post something that is guarenteed to start a fight. This is all I will say on this subject.
Bill, AMa 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 2525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
8.875RCU1
