RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  124 125 [126] 127 128 129 130 131 132 133   next >   >>
Login
RE: WACO YMF - 7/20/2007 2:09 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
quote:
ORIGINAL: Stickbuilder
Next thing you know, you'll see a built in program where the guys push a button on the RTF model, and the engine will start, the model will accelerate, take off, fly the full aresti pattern, land and shut down. Bah!!! That ain't flying!!!!!
Sounds like the Airbus RTF model
_____________________________
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
(in reply to Stickbuilder)
       Post #: 3126
RE: WACO YMF - 7/20/2007 4:30 AM
airplanegeek
Score: 100
Last Login: 5/22/2013
Status: offline
Hi All,
I would like to point out an issue with using trim tabs on models. As stated earlier you would be loading the servo with the aerodynamic forces produced by the tab. Also I would like to point out that these tabs work in the reverse direction that one would assume. For example if an aircraft is yawing left and requires right rudder input, the tab must be moved LEFT. The tab hanging in the slip stream will produce force on the rudder moving it to the Right. This works on full scale aircraft becuase control surfaces find there own natural center, the pilot just takes it from there.
But it's all pointless for models - just use servo trim, i just thought this was an interesting discussion.
Hide Signatures
(in reply to khodges)
       Post #: 3127
RE: WACO YMF - 7/20/2007 6:51 AM
khodges
Score: 126
Status: offline
More progress on the replacement gear for my UMF. Everything's done except fo paint. I fine sanded to 400 grit and then put a layer of 0.75 oz fiberglass over all the wood parts, and then another coat of finishing resin, which was sanded with 400 grit again. The original gear on the ARF, and maybe the Pica kit as well, has a trailing edge of the fairing that ends forward of the leading edge of the lower wing; the full scale's gear fairing extends under the wing for a short way. I added a wood strip behind the metal leg to extend the trailing edge to the leading edge of the wing, it looks much better, IMO.
1st pic is the original gear, 2nd is the new gear with the trim strip (also has one on the leading edge), 3rd, 4th, & 5th are the new gear in place. 7th is the full scale
#6--this plane looks good as a low-wing monoplane, sort of like a GB-Y.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by khodges -- 7/20/2007 6:58 AM >
Hide Signatures
(in reply to damifino)
       Post #: 3128
RE: WACO YMF - 7/20/2007 7:03 AM
aminiet
Score: 115
Last Login: 5/12/2013
Status: offline
Nice job on that gear.
As we say around this here parts in Tex Mex Spanglish.
Betty good man, Betty good.
Angel
B 58
SO MANY WACOS, SO LITTLE TIME.......
Hide Signatures
       Post #: 3129
RE: WACO YMF - 7/20/2007 7:25 AM
jim schroer
Score: 100
Last Login: 12/31/2012
Status: offline
Brothers, there in a radial engine on Ebay worth drooling over. But I.m afraid the engine collectors will sent this one sky high without a plane. It's a Morton 5 cylinder of the vintage of our Wacos. Item #170131921741 Jim #9
Hide Signatures
       Post #: 3130
RE: WACO YMF - 7/20/2007 7:42 AM
skylarkmk1
Score: 210
Status: offline
Ken,
Are you going to add the Inner Wheel Pant Fairing? The photos are from the YMF, NC 14081, at the Fly In. The drawing is from the drawing of the Pica Subject, NC 14031 by Paul Matt for the Historical Aircraft Album.
Click for fullsize
Click for fullsize
Click for fullsize
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 3131
RE: WACO YMF - 7/20/2007 8:13 AM
Ken Kehlet
Score: 110
Last Login: 5/21/2013
Status: offline
Hi Everyone,
The PICA WACO is now being reproduced as an ARF, Both sizes are being distributed by of all people "COX"
The 72" wing model was released in February 2007, I Have One.
kbkopy
Hide Signatures
(in reply to Ernest-T)
       Post #: 3132
RE: WACO YMF - 7/20/2007 8:52 AM
skylarkmk1
Score: 210
Status: offline
Ken K.,
The pictures of the Red and Cream Waco in the above pictures by khodges is a COX 1/5th Waco. Ken H totally stripped the original covering, added a lot of scale details and recovered it. He had a bit of trouble with the original landing gear and hence the new sheet metal gear. It looks good and you can't call it an ARF anymore.
Take a browse through the thread and see what the guys have been doing making their own Wacos and modifying the Cox planes. The discussion does get off a little subject briefly a few times, but quickly gets back on track. There is a lot of good and interesting information scatted through out.
Hide Signatures
(in reply to Ken Kehlet)
       Post #: 3133
RE: WACO YMF - 7/20/2007 4:10 PM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: skylarkmk1
Ken,
I suppose I ought to try; if I do, I'll need to space the pants out a bit, maybe three washers worth.I've thought a lot about how to do it and get the curvature right, but haven't come up with any good way except to mold clay around the area, lay fiberglass over it, and then remove the clay. It's always something I can do later; as the saying goes, you never finish a scale model, you just stop working on it. I'm about tired of working on this one , I want to fly it some.
BTW, I spoke again Monday with Aaron at Ikon, he assured me the UPF kit would be here either today or tomorrow. We'll see. he's pleasant to talk to, but he sounds like a guy with a lot on his plate. He promised it in three weeks, it's been over four, and it's taken me two long distance calls to keep it moving; he has almost $300 of mine and I don't yet have anything to show for it. I don't want to seem impatient, but a deal's a deal.
< Message edited by khodges -- 7/20/2007 4:16 PM >
Hide Signatures
(in reply to skylarkmk1)
       Post #: 3134
RE: WACO YMF - 7/20/2007 5:25 PM
damifino
Score: 100
Last Login: 8/11/2012
Status: offline
Ken, If you want to attempt the wheel pants fairings try modeling them out of Dow Blue foam, the house insulation foam board. It sands beautifully and is perfect for the lost foam method of 'glass lay up. I use automotive bondo to glue multiple layers together for thicker parts because the bondo sands easily. Around here all we can get at the home centers is 3/4" thick, but our Brothers up north can find it easily in up to 2" thicknesses. The other brand is pink and works equally well.
Everybody knows you can''t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
Hide Signatures
       Post #: 3135
RE: WACO YMF - 7/20/2007 5:37 PM
mobyal
Score: 110
Status: offline
quote:
ORIGINAL: Ken Kehlet
Hi Everyone,
So do I. Have you been able to get the wheel pants to stay on it?
MobyAl
Hide Signatures
       Post #: 3136
RE: WACO YMF - 7/20/2007 5:51 PM
trlambsr
Score: 100
Last Login: 11/15/2011
Status: offline
What I did for Bob Gonzalez's Plane is we got the Peter Barth fairings from Proctor and modified them. As you can see they are two small for the 33 and I in-larged them. Also if one takes great care in fitting them to the landing strut it will help hold the wheel pants in place. Of course one needs to make them strong enough. They would be close for your Size. Lots of fun at the WACO Play house in Bethesda MD
TR
WACO BROTHERHOOD # 69
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by trlambsr -- 7/20/2007 6:04 PM >
Hide Signatures
       Post #: 3137
RE: WACO YMF - 7/20/2007 7:35 PM
khodges
Score: 126
Status: offline
Hi Everyone,
Have you flown it yet? What are you using for power? The Brothers are pretty much covering the spectrum, from big single 4-strokes to big twin 4-strokes to bigger 3-cylinder radials, and even several gasoline engines, like mine. examine several things closely; the landing gear has the potential to break about an inch above where the axle is, and there are NO replacement parts, unless Cox has decided to part-out some of their ARF kits. I gave up and designed my own replacement and damifino was kind enough to provide the materials and labor (I'll be paying on it for a looong time ) to make it for me. Another thing that will probably go Tango Uniform are the wheel pant collars/brackets, as mobyal said. See the last four or five pages for my fix. As skylarkmkI said, mine is the ARF, as are several others here, but most are scratch or kit building the original Pica kit that the ARF is designed from.
Wanna be a Brother? Don't cost nuthin', all ya gotta do is like WACO's. The Master Chief, originator of this thread, will assign you a number. Here' another view of mine; G-26 gas engine, Koverall fabric, and lots of reverse engineering.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3138
RE: WACO YMF - 7/21/2007 5:28 AM
damifino
Score: 100
Status: offline
Speaking of landing gear, I made most of the mod to my 1/5 PICA/WB/AMA WACO main gear mounting area tonight. The main gear I made for Khodges works so good I'm gonna put one on mine. Biggest difference will be that mine will be a 2 piece gear consisting of right and left legs. The 2 piece arrangement allows me to keep all the formers and sheeting as called out in the plans. The gear will be bolted into place before covering much like the stock wire gear is glued in as called for in the plans. If things ever get damaged too much the covering will have to be removed anyway. My Bruce Tharpe Venture 60 sport plane came with a split gear and it holds up just fine. I'll post some pictures of the mod soon.
Yours is looking fine, Ken.
Hughes500E- How'd your scale qualifier go??
Hide Signatures
       Post #: 3139
RE: WACO YMF - 7/21/2007 4:10 PM
damifino
Score: 100
Status: offline
Check out this thread for some awesome detail work and construction of a WWI aircraft in 1/6 scale. The fellow posts great pictures.
http://www.rcuniverse.com/forum/m_5029692/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 3140
RE: WACO YMF - 7/21/2007 10:20 PM
khodges
Score: 126
Status: offline
That SE-5a cockpit looks like you could climb in and fly off. I've been to that thread before.
Well......... it's done.....Again Looks much better than the original gear, the trailing edge of the fairing is tapered instead of rounded, it fits against the leading edge of the bottom wing, if not completely under it (still have to be able to take the wing off). The wheel base is an 1-1/8 inches wider than before, maybe it'll be more stable on takeoff and landing. I'll post some pics later, gonna go to the field this evening, if winds are light I'll fly it. The gear came out about 4-1/2 ounces more than the original, but since it sits fairly close to the C/G, it didn't cahnge the balance; if at all, it's a tad nose heavier than before, but not noticeable when it's held at the balance point. We'll see if the trim changes.
I had problems with getting the smoke system to work when I last flew it. Ground check and setup went fine, but for some reason the pump didn't come on during preflight. A cursory inspection while working on the gear didn't find any loose or disconnected wiring, and the battery has plenty of juice. For now, I say screw it, I just want to fly the thing and get used to it. I had six flights when the main gear broke, just starting to get the "feel", now it's going to be like the maiden flight all over again. If everyone feels a sudden shift in wind direction and velocity, it's just me puckering, don't worry
Hide Signatures
       Post #: 3141
RE: WACO YMF - 7/22/2007 12:44 AM
skylarkmk1
Score: 210
Status: offline
Hey Ken,
We made the American Waco Clubs "Waco World News", July/August edition as new members. Ours mugs are on page 16 of the Waco-People-Places-Plans section. There is also a nice shot (B&W) of the DH-4 (air to air) and another of 4 Wacos in formation on the way to Saturdays breakfast. Brings back some wish it was longer memories.
Good luck with your second "maiden" flight on the UMF.
That SE-5 is a work of art, he really needs to do a larger version as this one is only 1/6th scale (53" ws). Something to strive for guys.
Hide Signatures
       Post #: 3142
RE: WACO YMF - 7/22/2007 4:53 AM
khodges
Score: 126
Status: offline
Can't wait to see that issue, haven't got it yet. I got a packet a couple weeks ago with July/Aug '06 through May/June '07, and haven't got through them yet.
I made it to the field, but the wind was doing weird things; the wind sock was hanging, but when I flew my L-4, it was getting bounced around at 100 feet up, and was too much like work to fly it, so I put off any attempt on the WACO until tomorrow. I did make some pics on the runway, see below.
I have FunAero's 1/5 (or so) SE-5a kit, 60 inch wingspan and will build it some day, plan on a .91 Saito. I want to detail it but doubt I'll go to the same pains he did in the cockpit.
Wonder where the new "Ken" went (Kehlet?) I feel like a hit and run. "Where'd he go? Where'd whoooo go?" (remember Top Gun[movie]).
Click for fullsize
Click for fullsize
< Message edited by khodges -- 7/22/2007 5:08 AM >
Hide Signatures
       Post #: 3143
RE: WACO YMF - 7/22/2007 6:30 AM
jagnweiner
Score: 100
Last Login: 2/8/2013
Status: offline
quote:
ORIGINAL: damifino
. . . as long as we're a little off topic. Did you notice that the SE-5 is CONTROL LINE!?! Amazing.
-Scott
WACO Brotherhood #61
Hide Signatures
       Post #: 3144
RE: WACO YMF - 7/22/2007 6:48 AM
skylarkmk1
Score: 210
Status: offline
Scott,
That maybe so about the SE-5, but he was going to build it as a R/C until he ran out of room for the radio. You must admit though that the work is very well done and can be applied to either type.
Hide Signatures
(in reply to jagnweiner)
       Post #: 3145
RE: WACO YMF - 7/22/2007 4:30 PM
damifino
Score: 100
Status: offline
Those new legs make your bird look 'complete'. GOOD job!
Hide Signatures
       Post #: 3146
RE: WACO YMF - 7/22/2007 6:33 PM
jagnweiner
Score: 100
Status: offline
Scott,
Oh, I agree that the work is well done. I was just commenting that I have never seen such amazing detail in a control line plane. Of course I don't really follow control line scale, other than the occasional column in Model Aviation.
-Scott
-Scott
Hide Signatures
       Post #: 3147
RE: WACO YMF - 7/22/2007 9:24 PM
damifino
Score: 100
Status: offline
[/quote]
[/quote]
Just thought anyone's techniques can be relevant whatever the subject is. The guy's patience and skills are to be admired for sure.
Hide Signatures
       Post #: 3148
RE: WACO YMF - 7/22/2007 10:40 PM
mango12
Score: 100
Last Login: 5/16/2013
Status: offline
I saw a thread on rcscalebuilder( somewhere) where the modeler used a process called photo etching to make all of the parts for his cockpit. The entire process was fascinating, to say the least, and the parts were absolutely incredible. If I can find the thread again, I will post the link.
Scott
Scott
Waco Brotherhood #49
Hide Signatures
       Post #: 3149
RE: WACO YMF - 7/23/2007 4:38 AM
Skinny Bob
Score: 100
Last Login: 3/3/2013
Status: offline
Ken, that is one beautiful Waco!. I have followed your work on this plane and let me say you have done a very fine job. I hope I can do near as well with my project. Please keep us up to date with all you experience with this model.
Bob
Skinny Bob - AMA 713081
WACO Brotherhood #10
Hide Signatures
       Post #: 3150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.093RCU1
