RE: WACO YMF    Gallery
Logged in as Guest
Users viewing this topic: kochj
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  149 150 [151] 152 153 154 155 156 157 158   next >   >>
Login
RE: WACO YMF - 10/2/2007 12:03 AM
Live Wire
Score: 6329
Last Login: 5/23/2013
Status: offline
B B
As close as I can measure it is 5/8 inch
_____________________________
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to Big_Bird)
       Post #: 3751
RE: WACO YMF - 10/2/2007 12:24 AM
Stickbuilder
Score: 346
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Big_Bird
Thanks Bill, does this come with a secret hand shake?
Yeah, but if I show it to you, I'll have to confiscate all your planes.
Bill, AMA 4720
WACO Brotherhood #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 3752
RE: WACO YMF - 10/2/2007 12:43 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
quote:
ORIGINAL: Big_Bird
John, very good photos.
Surely someone out there knows what the spacing of the SIG corrugated sheet is.
I do, I used it on my UMF ailerons, works very well, although the spacing is not exact scale for 1/5, it is close.
The prices are about a year old, but:
SIGRPCP404A--sheets are 5-1/8" x 12", thickness is 0.010", rib spacing is 15/32". These sheets aren't long enough to get a complete aileron on the 1/5 scale without piecing it, but the rib spacing is closest of the three to 1/5 to scale, and is almost dead nuts exact for 1/4 scale. These are $1.99/sheet. If carefully cut, you could piece them, but you'd need two sheets each for top and bottom of each aileron in 1/4 scale, as they aren't wide enough to do both surfaces out of one sheet, or long enough either.
SIGRPCP2571--sheets are 8" x 17", thickness is 0.010", rib spacing is 21/32", the price is $2.59/sheet. This is the size I used for my ailerons. I think the scale # of ribs is 33 or 34 per aileron, this sheet will give you 21 ribs/aileron on the 1/5 scale, and the sheet is wide enough and long enough to do top and bottom of one aileron per sheet in 1/5 scale, don't think so in 1/4, though.
SIGRPCP2572--sheets are 6-1/2" x 13-1/2", thickness is 0.010", rib spacing is 23/32", price is $1.99/sheet. Very close to the one above.
The "other" Ken
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by khodges -- 10/2/2007 12:54 AM >
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
       Post #: 3753
RE: WACO YMF - 10/2/2007 12:45 AM
Big_Bird
Score: 105
Last Login: 5/17/2013
Status: offline
khodges, we were posting at the same time and I didn't see your information until I had posted, therefore, that is the reason that I edited this post. That is exactly the info that I needed.
Bill, I've decided that I don't need to see the secret hand shake. Thanks anyway.
< Message edited by Big_Bird -- 10/2/2007 1:07 AM >
Ken
WACO Brotherhood #70, Arlington TX home of the Dallas Cowboys, SupBowl45, Texas Rangers, World Series 2010, 2011
Hide Signatures
(in reply to Live Wire)
       Post #: 3754
RE: WACO YMF - 10/2/2007 1:29 AM
Tony V.
Score: 100
Status: offline
thank you all !
Tony, AMA 120246
WACO Brotherhood #71
Hide Signatures
       Post #: 3755
RE: WACO YMF - 10/2/2007 1:34 AM
skylarkmk1
Score: 210
Status: offline
Jim,
Three shots of ailerons, the Turquoise Blue from the YKS (bottom side), Light Blue from UPF-7, NC 173E (top) and the grey from UBF-2, NC 12002 (top). The rivet pattern is mostly on the inboard area of the aileron and in the 16th space from the tip rib (grey aileron). Khodges is correct, 34 ribs (or corrugations) and 35 spaces per aileron. Also note the different locations of the mounting plate for the aileron connection struts.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 10/2/2007 1:58 AM >
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to SuperCub Man)
       Post #: 3756
RE: WACO YMF - 10/2/2007 1:45 AM
Big_Bird
Score: 105
Status: offline
I just finished ordering 4 sheets of: SIGRPCP2571--sheets are 8" x 17", thickness is 0.010", rib spacing is 21/32", the price is $2.59/sheet plus $8.99 for shipping.
I can cover both sides of the aileron with one sheet. This will give at least 25 ribs per aileron on 1/4 scale. Not scale I know but khodges looks good.
< Message edited by Big_Bird -- 10/2/2007 1:55 AM >
Ken
Hide Signatures
(in reply to khodges)
       Post #: 3757
RE: WACO YMF - 10/2/2007 3:07 AM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: Big_Bird
B.B., you don't know where his hand's been, be careful
Hide Signatures
       Post #: 3758
RE: WACO YMF - 10/2/2007 4:43 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: khodges
quote:
ORIGINAL: Big_Bird
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 3759
RE: WACO YMF - 10/2/2007 1:48 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: khodges
quote:
ORIGINAL: Big_Bird
The very idear, I'll have you to know that I washed that hand (actually both of them) last week. Of course, you Officers were taught to wash your hands after you go to the bathroom, while Master Chiefs know not to use the bathroom on your hands.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 3760
RE: WACO YMF - 10/2/2007 6:46 PM
Nightstalker
Score: 100
Last Login: 1/25/2010
Status: offline
quote:
ORIGINAL: Stickbuilder
quote:
ORIGINAL: khodges
quote:
ORIGINAL: Big_Bird
Bill, AMA 4720
WACO Brotherhood #1
You guys need to try utilizing the "CRT" (Crew Relief Tube) in the back of a pitching MH-47 Chinook... at night even. Man I used to go through a lot of Nomex flight gloves...
Oh and Lt. - This may be a dumb question (I know... you'd expect such from an ARMY Doggie), but what would be so difficult about making the aelerons out of sheet balsa and square stock to resemble the plastic ones. You said they are not quite 1/5th scale, so why not make wood ones that are 1/5th scale? Sounds like something even I could do Unless it's a weight thing.
Out Here,
Todd
WACO Brotherhood #47
Hide Signatures
(in reply to Stickbuilder)
       Post #: 3761
RE: WACO YMF - 10/2/2007 7:22 PM
Stickbuilder
Score: 346
Status: offline
Todd,
I did a set using 1/16" square stock (sanded to shape) and it looked good. It did, however, seem to take forever to make them.
They were fairly light, but there are materials out there that lend themselves to the process in a much easier manner.
If you guys would fly your Hooks at a more reasonable altitude, you wouldn't have had that problem.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to Nightstalker)
       Post #: 3762
RE: WACO YMF - 10/2/2007 7:40 PM
Nightstalker
Score: 100
Status: offline
Todd,
Bill, AMA 4720
WACO Brotherhood #1
Well, your soybean field was looking a little dry, so we were just helping you out with a little aerial irrigation . What's so unreasonable about 10 feet AGL at 150 knots? Unless you REALLY gotta go #2
Todd
Hide Signatures
       Post #: 3763
RE: WACO YMF - 10/2/2007 9:03 PM
lazyace
Score: 100
Status: offline
stickbuilder
hi this is brotherhood 67 just got my kit from e-bay all the wood looks pretty good but no plans were sent in the kit, got your updated manual , sent an e-mail to the shipper , but who knows I guess I got taken , so were do I get a set of plans , my shop is waiting for this build to start can't wait to get started thanks , oh by the way b&b has a mount for the fuji 23 that lets you not cut out the back of the firwall I think you need 71/4" to prop nut from the back.
charlie
charlie AMA 8916
WACO brotherhood #67
Hide Signatures
       Post #: 3764
RE: WACO YMF - 10/2/2007 9:11 PM
trlambsr
Score: 100
Last Login: 11/15/2011
Status: offline
Charlie
I have been given a 1/5 pica kit to dispose of. I was debating about duplicating the drawings before I do that. If you would pay the cost of extra copies I would order more then one
TR
WACO BrotherHood # 69
Hide Signatures
(in reply to lazyace)
       Post #: 3765
RE: WACO YMF - 10/2/2007 9:23 PM
SuperCub Man
Score: 105
Last Login: 5/21/2013
Status: offline
Trying to spot if the YMF Classic has a strobe on the belly that I can't see in this shot. Too lazy to drive to the airport and with todays weather, he probably wouldn't be home anyway! It looks like landing lights and wing tip lights only! Is this correct?
Click for fullsize
Jim, MAAC #5343
WACO Brotherhood #56
Hide Signatures
(in reply to trlambsr)
       Post #: 3766
RE: WACO YMF - 10/2/2007 9:35 PM
Stickbuilder
Score: 346
Status: offline
Charlie,
You can order the plans from the AMA plans service, or let TR run a set for you.. If you opt for the copied sed, check the measurments for square, since some copy machines can and will skew the drawings.
Super Cub Man,
It depends on the plane. You can specify lighting for the application with the Classic. I would think that all newer planes would have the strobe package. Check with Mike Barbee, since his third scale Genesis is about the best detailed one that I have seen. Doesn't mean that there is not one nicer, but I haven't seen it. Mike is a Brother, so he should be happy to give you the info.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 3767
RE: WACO YMF - 10/2/2007 11:15 PM
khodges
Score: 126
Status: offline
............. to use the bathroom ................
How long you been out of the Navy, Bill? You've stopped using NavySpeak, anyway. I thought the proper phrase for an old salt was "make a head call"
Hide Signatures
       Post #: 3768
RE: WACO YMF - 10/2/2007 11:21 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: khodges
I've been out 19 years 1 month and 23 days. I would have used the term, "Head", but would have needed to retrain the rest of you. Just wait until I start talking about Charlie Noble, and the Scuttlebutt, and the Geedunk.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 3769
RE: WACO YMF - 10/2/2007 11:23 PM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: SuperCub Man
Here's a couple of pics showing the belly strobe, plus the antennae, on NC 14081. The best I can tell from the angles, the strobe sits centered just forward of the trailing edge of the lower wing.
Click for fullsize
Click for fullsize
< Message edited by khodges -- 10/2/2007 11:27 PM >
Hide Signatures
       Post #: 3770
RE: WACO YMF - 10/2/2007 11:48 PM
Stickbuilder
Score: 346
Status: offline
Ken,
On your G-26, did you use 8-32 bolts, or did you open them up to 10-24?
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 3771
RE: WACO YMF - 10/3/2007 1:18 AM
Tony V.
Score: 100
Status: offline
Supercub man.
Look up from the red flag in your picture.( Strobe Light ) . Got my cox waco today lots of work now....
Tony
Tony, AMA 120246
Hide Signatures
       Post #: 3772
RE: WACO YMF - 10/3/2007 1:34 AM
Suprfort
Score: 100
Status: offline
Supercub man,
The Waco YMF-5 I modeled was built in 1998 by the Classic Waco Company in Michigan. At that time they did offer a strobe oiption but the owner of N56ED elected not to get it. The strobe is mounted center of lower wing both ways.
Hope this helps.
Mike Barbee
Waco Brotherhood #44
FYI Stickbuilder My Waco INF plans are progressing nicely
Hide Signatures
(in reply to Tony V.)
       Post #: 3773
RE: WACO YMF - 10/3/2007 1:36 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Tony V.
Supercub man.
Tony
That means that you should be about ready to join the Brotherhood.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 3774
RE: WACO YMF - 10/3/2007 2:40 AM
SuperCub Man
Score: 105
Status: offline
quote:
ORIGINAL: Tony V.
Supercub man.
Tony
Got it!!
Thanks Tony and also Mike. I guess I'll have to crawl right under to see it!
Jim, MAAC #5343
Hide Signatures
       Post #: 3775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.219RCU1
