RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  196 197 [198] 199 200 201 202 203 204 205   next >   >>
Login
RE: WACO YMF - 12/18/2007 1:10 PM
Stickbuilder
Score: 346
Last Login: 5/22/2013
Status: offline
What I want for christmas is one of Santa's elves to stop by and finish this thing for me. Bought the ply for the wing Mods yesterday. You would think that 1/8" ply was made from pure Gold.
Bill, WACO Brother #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to Stickbuilder)
       Post #: 4926
RE: WACO YMF - 12/18/2007 5:09 PM
red1
Score: 100
Last Login: 8/21/2008
Status: offline
Skylarkmk1
Good Morning John. Thanks for the suggestions/recommendations and for the various source sites. I ordered, and received, the JTEC 1/6 color instrument panel decal sheet. In going through my PICA kit the other dayI found a number of major items missing...cabane struts, landing gear struts, cowl ring, etc. I later found them all in another box . I recently discovered that one of our local Staples has a large, continuous roll printer for doing oversize material so I was able to get a duplicate set of the plans made [$25]. I have picked up some weights and some devices for ensuring 90 degree angles, etc., so I guess I'm about ready to begin construction.
One question. Would all of the construction/materials modifications called out in the rewritten manual for the 1/5 also apply to the 1/6 [rescaled down of course] ?
Thanks, and Happy Holidays.
red 1
AMA IMAA
WACo Brotherhood #72
Hide Signatures
(in reply to skylarkmk1)
       Post #: 4927
RE: WACO YMF - 12/18/2007 5:59 PM
skylarkmk1
Score: 210
Status: offline
Don,
Scaled down, the mods will apply, especially the wing joiners (I would go with 1/8th ply). The other mods for dual aileron servos, new formers and parts for the firewall, tank and tail wheel former (F-14B) to relocate the tail wheel in a scale location will also apply. If you down load the PDF plans for both sizes from the House of Moy site and compare them, you will find that the construction is identical for most areas. The major difference I have found is the layout (due to size) of the fuselage and wing views between plans, the tail group on a separate page for the 1/5th and the 1/5th has a little more detail drawn in such a grain pattern.
When making the tank area mods, get your tank first before cutting anything, you will need to adjust the new parts to fit your selected tank. Specifically parts F-1, F-4B, F-16 and F-7B as listed in the Fuselage Subassemblies section.
Check your plans that you had made for distortion. Lay a straight edge down along major straight lines (wing spars, leading edge, crutch in the fuselage side view) and check to see if they curve or deviate in any way. I had a set of 1/6th plans made (at another store) from the PDF file and the rudder and tail were slightly distorted (the lines came out segmented). The Mark 1 Eyeball can make the correction to build from.
< Message edited by skylarkmk1 -- 12/18/2007 6:02 PM >
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to red1)
       Post #: 4928
RE: WACO YMF - 12/18/2007 7:18 PM
skylarkmk1
Score: 210
Status: offline
Bill and everybody,
Check this site out http://smartflix.com/ . It has DVDs on most anything including the English Wheel, Air Hammer, Working with Tubing, Sewing Welding and more. Don't know anything about the site, just recieved the link info from one of the Cedar Stripper Canoe sites.
Hide Signatures
       Post #: 4929
RE: WACO YMF - 12/19/2007 3:09 AM
Stickbuilder
Score: 346
Status: offline
You guys in the frozen North about dug/thawed out yet? I want to know which one of you sent that blast of frigid artic air down here last night. It was 42 this morning. Fought like the dickens to get to 65 today. It's supposed to be back up to 78 tomorrow. It needs to get back to normal. 42? Holy cripes, I thought I was gonna freeze my tukus off this morning.
Hide Signatures
       Post #: 4930
RE: WACO YMF - 12/19/2007 3:22 AM
Jim Henley
Score: 120
Last Login: 5/21/2013
Status: offline
Bill,
Sounds like you need to spend some time at the helm of a snow-blower. Makes you appreciate those 42 degree days
Jim,
WACO Brotherhood #3, AMA 816592, IMAA 41683,
Hide Signatures
       Post #: 4931
RE: WACO YMF - 12/19/2007 3:25 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Jim Henley
Bill,
Snow Blower? We arrest folks down here for blowing snow......Oops, wrong kind of snow and blow..... never mind.....
Hide Signatures
(in reply to Jim Henley)
       Post #: 4932
RE: WACO YMF - 12/19/2007 3:53 AM
Live Wire
Score: 6329
Status: offline
Bill
Interesting how much a lawn mower and a snow blower are alike
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 4933
RE: WACO YMF - 12/19/2007 4:45 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Live Wire
Bill
I don't remember ever shivering while running the lawn mower.
Hide Signatures
(in reply to Live Wire)
       Post #: 4934
RE: WACO YMF - 12/19/2007 5:23 AM
lazyace
Score: 100
Status: offline
bill
it is going up to 35 to 40 here tomarrow a real heat wave
charlie AMA 8916
WACO brotherhood #67
Hide Signatures
       Post #: 4935
RE: WACO YMF - 12/19/2007 6:27 AM
ctflyboy
Score: 101
Status: offline
Hey Bill,
The weatherman said tonight it should be around 9 degrees,and tomorrow (Wed) a possible high of 27 with snow showers in the afternoon,
IT GOING TO BE A WARM ONE I'M GOING TO PUT ON THE SKI'S AND GO FLYING.
GEORGE
WACO Brother # 5
Remember, Man''s 2nd greatest adventure is FLYING, LANDING is his FIRST.
Hide Signatures
(in reply to lazyace)
       Post #: 4936
RE: WACO YMF - 12/19/2007 7:44 AM
HarryJ
Score: 100
Status: offline
Bill,
Don't feel bad, we had a dose of that frigid artic air hit us last night too. Had to resort to a sweatshirt to fly. That is just not normal here. Global warming my hiney!
Harry J
Waco Brotherhood Lucky #13
Hide Signatures
(in reply to ctflyboy)
       Post #: 4937
RE: WACO YMF - 12/19/2007 1:29 PM
Stickbuilder
Score: 346
Status: offline
You guys who brave those frigid temps have my respect. If it were 9 degrees down here, the entire state would shut down. There would be absolutely nothing operating. The homes are not built for such low temps. Of course, you guys up North probably wouldn't survive a Hurricaine either, your homes are not built for that (course some of ours ain't either).
I'm with Harry. When Mom Nature drops us a little chill, we put on the sweat shirts and go fly.
Hide Signatures
(in reply to HarryJ)
       Post #: 4938
RE: WACO YMF - 12/19/2007 6:48 PM
TexasSkyPilot
Score: 438
Last Login: 5/17/2013
Status: offline
I can't believe that I've never found this thread. 198 pages of WACOs, I may have died and gone to Heaven. Well, I guess I'm going to have some terrific reading for the next couple of weeks! I love Bipes, and I can't help but covet any YMF 3 or 5 I've ever seen. I go nuts every time I see a photo of Mike Barbee's Scale model flying.
I really don't want a giant scale though, too much trouble with the transportation and storage (otherwise I'd want a HUGE one..). I think that something in, say, the Saito 100 range (maximum) would be great. So, I have a few questions for you fellows. Since I don't have time to build one all the way up, do you know where I might look for one that's already built? ARC would be just fine. I doubt there is an ARF for this anywhere.... And last but certainly not least, how could I become a member of the WACO Brotherhood? Sounds like the best club I ever hoped to be in!
Jim
J.M. Surra, author of AERODYNAMIC, and T.I.T.O.R. - In July of 1947, something crashed in Roswell, New Mexico. . .
Hide Signatures
       Post #: 4939
RE: WACO YMF - 12/19/2007 7:30 PM
SuperCub Man
Score: 105
Status: offline
Yahoo!! Picked up my cowls and pants today - and they are beauties. Well worth the wait and the price. Yes Bill the pants are a little wide to scale, but they fit my soft Dubro wheels perfectly and so shall remain as is. The tail of the pant is nice and pointed so it is right on scale - not like the generic pant from Fiberglass Specialties. The cowl is a perfect fit to the nose as I've built it and will look great with the standoffs to hold it in proper place.
Yes, that is a scale operating landing gear set I'm making. Aluminum main gear with internal spring and brakeline tubing struts. We'll see how it goes!! The sprung tail wheel "a la Ken and Jay's thinking" - worked out perfectly. So now on with the build!!
Off to the bench!!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Jim, MAAC #5343
WACO Brotherhood #56
Hide Signatures
(in reply to TexasSkyPilot)
       Post #: 4940
RE: WACO YMF - 12/19/2007 9:03 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Mainer_Jim
Jim
NEW BROTHER ALERT
Jim, Welcome to the Brotherhood. You are Brother #86. I hope that you enjoy it. If you think that you can get through it in two weeks, you are a better man than I am. Hope you don't get this one stolen.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 4941
RE: WACO YMF - 12/19/2007 10:20 PM
Stickbuilder
Score: 346
Status: offline
Jim,
Cox offers the YMF (Actually it's a UMF) as an ARF in both the 1/5 and the 1/6 sizes. From all reports, it is pretty nice for an ARF. KHodges has done a redo of one and it turned out really well. Of course, he is a great builder to start with.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 4942
RE: WACO YMF - 12/19/2007 10:39 PM
Tony V.
Score: 100
Status: offline
Jim,
The 1/6 scale is all they have left...There was a review in RC Report....
Tony, AMA 120246
WACO Brotherhood #71
Hide Signatures
       Post #: 4943
RE: WACO YMF - 12/20/2007 1:21 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Tony V.
Jim,
I feel reasonably sure that there is going to be another production run of the fifth scale version soon. Cox has never been one to leave rocks unturned. There is a dollar there, and they will be after it.
Hide Signatures
(in reply to Tony V.)
       Post #: 4944
RE: WACO YMF - 12/20/2007 1:50 AM
TexasSkyPilot
Score: 438
Status: offline
Thanks!
Uh, Get through WHAT in two weeks? Never mind, I just remembered what I said. It'll probably take me a lot longer than that to read all 199 pages, but I'll savor the flavor. It's all WACOs (mostly), so it's all good!
I think the 1/6th scale PICA is pretty close to being the right size. Wouldn't a Saito 100 single fly that fairly well? I haven't checked the recommended engine range on that one yet, and I think the 1/5th is going to need a small gasser at least, by my guestimate. My Hog Bipe had a 54" span and ran a Saito .91 at 8.5 lbs and did a real nice job of it, even muscled through some maneuvers nicely. They say the Saito 100 is lighter and stronger than the .91. I'll have to look into that. I have two of them on my shelf, and that's about as big a model as I want to keep around from now on. As was mentioned, I had everything stolen, so I want to keep everything close to home and safe. Transportation and storage are extremely relevent to what I get from now on. Plus, I have to move all of it back to San Antonio in the next year or so. ("Ahhh, honey, we'll just leave that new sofa here in the yard and that should make enough room for my big Bipe!!")
The WACO Brotherhood...brings a tear to my eye... I actually feel cool. Gee, I've gotta change my signature line now!!
Jim
< Message edited by Mainer_Jim -- 12/20/2007 2:02 AM >
Hide Signatures
       Post #: 4945
RE: WACO YMF - 12/20/2007 3:52 AM
RICKSTUBBZ
Score: 139
Last Login: 5/20/2013
Status: offline
(Mainer Jim)—Jim,
Welcome aboard. It took me at least a month to get through the whole thread. But, it was worth every minute of it.
Rick, AMA 115812-WACO Brotherhood #75
To discover something better....You must be willing to try something different
Hide Signatures
       Post #: 4946
RE: WACO YMF - 12/20/2007 4:08 AM
RICKSTUBBZ
Score: 139
Status: offline
Jim (SuperCubMan)
Your building three? All at once? I thought I remembered you mentioning a while back -- two. I also had to flip back and forth a couple of times, but I see you have one landing gear that is after market and one your scratch building. Looking good.
Hide Signatures
(in reply to RICKSTUBBZ)
       Post #: 4947
RE: WACO YMF - 12/20/2007 4:24 AM
Stickbuilder
Score: 346
Status: offline
Jim,
Dick Pettit flew the one sixth version on the Saito .82 and reported it as being grossly overpowered. You will have to let the rocker boxes (and probably more) hang out in the breeze. There is no way to keep the Saito inside the cowl. You will find one of my fifth scale versions with an O.S. 160 Twin. The new one (under construction) is using the G-62. All fit inside the cowl except for the plug and plug wire on the gasser. Maybe something like the O.S. 70 4 stroke would be a better choice for the small one. If you look around, you just might find a fifth scale for sale.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 4948
RE: WACO YMF - 12/20/2007 5:08 AM
skylarkmk1
Score: 210
Status: offline
Jim,
The 1/6th Pica and Cox Wacos have a wingspan of 60" and the Pica plans indicate a .60 engine for power, Cox suggest .60 2s or .90-1.20 4s. The Pica profile of the .60 is a 2 stoke as would be appropriate for the time this plane was designed. Cox indicates a weight between 7.5 to 8.5 lbs. As Bill indicated, anything from a .70 4s (enough) to the 1.00 4s (probably overpowered) would be ok for the 1/6th Waco. I think Dick Pettits report was in RC Report, but I am not sure of the issue. The Cox Waco is based on the Pica Waco but the construction is different and has some deviations from scale.
If you haven't found it yet, The House of Moy http://www.houseofmoy.com/waco/ is the supplemental site with PDF files of both sizes of Pica Plans and .dxf and .jpeg files of the templates. The templates will have to be scaled to fit correctly and they don't print out to the correct size directly.
Hide Signatures
       Post #: 4949
RE: WACO YMF - 12/20/2007 5:19 AM
TexasSkyPilot
Score: 438
Status: offline
I have some new Saito 72 4-strokes on my shelf too. I'll have to look at the review Dick did on the smaller one. Anybody have a link to it if it's on the web? If the 1/6th scale is overpowered with an .82 and a 60" wingspan, I wonder if the 1/5th scale with a 72" span would be badly UNDERpowered with a Saito 100 or if it would have enough to do a few things and stay out of trouble. Obviously still some researching to do here.. I feel like one of these could be what I'm looking for. If it's the smaller one, I'm gonna HAVE to peel it and do it in a white with red theme. The blue absolutely does nothing for me, the white and red lights me up every time I see one.
Why are these UMFs rather than YMFs? I'll probably find many of my answers when I read the 198 pages.....
Jim
Hide Signatures
       Post #: 4950
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.268RCU1
