evdo
NJ, USA Status: offline
Bill - Thanks for the dimensions on the 160 twin mount, it looks like it's just the right size to be annoying with the way the original builder decided to install the hardwood rails up to the firewall (which are tapped & have blind nuts for whatever original engine mount). One fairly simple approach which may work is if I cut a new 5/8" plywood firewall (smaller then the entire firewall), install blind-nuts on it, and then sandwich it up against w/ epoxy & bolts to the existing ply firewall, which has to be about 5/8" already--- otherwise i'd have to replace the entire firewall, rails, etc -- the sheeting is already on as well so i'd hate to have to try and cut the firewall out. Any drawbacks to this type of an approach other then additional weight of the "extra" firewall? Maybe i'll try and get some pics. -Tom
